Author Topic: Signature Plastics  (Read 3702 times)
Offline jooks1184
Signature Plastics
« on: Sat, 19 January 2013, 12:01:23 »
Does anyone have any experience ordering from Signature Plastics? Was thinking about ordering some keycaps from them. For those that have ordered from them, what's the price range for a set of PBT keycaps (104). Thanks in advance for the help.
Re: Signature Plastics
« Reply #1 on: Sat, 19 January 2013, 12:19:57 »
http://www.keycapsdirect.com/key-capsinventory.php
They sell over run parts of PBT caps that you can buy. It's apparently $1 for each cap but since you're buying 104, you might be able to get a discount. Check out the site and hopefully some other ppl can chime in with some info as well.
Offline jabar
« Reply #2 on: Sat, 19 January 2013, 15:12:43 »
Can anyone hint at what sort of discount is available when buying a full 104 set? I know some people here have ordered these overruns.
$1 each is ludicrous considering they're also blank (they do ship blank, right? legending would be extra, if even possible?).
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Sat, 19 January 2013, 15:22:25 »
None, they don't offer any discount on blanks unless you are buying in large volume. A single full set of blanks will cost $104. Also often times they won't have all the needed keysize in a particular color force to mix and match. Thier doubleshot sets are a better value. For PBT blanks there are cheaper sources with just as good or better keycaps though more limited color selection.
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #4 on: Sat, 19 January 2013, 15:24:42 »
Try contacting them and asking :)
Yes they're all blank, currently SP only offers blank (extras), dyesub (expensive), and doubleshot (only arrows) in PBT.
