Author Topic: keycaps for Pure keyboard  (Read 2251 times)
Offline Rafen
« on: Wed, 23 January 2013, 18:06:00 »
I was wondering if anyone knows if I can purchase aftermarket keycaps for the Pure? I tried to find info on it but had no luck. Thanks for the help I appreciate it.
Offline Jocelyn
  • 조셀린
Re: keycaps for Pure keyboard
« Reply #1 on: Wed, 23 January 2013, 18:16:35 »
I don't think there is anything made specifically for the Pure. Most sets should work fine, but you'll need a tsangan kit for the 1.75x R Shift and have to replace the tilde key with a blank or something else from the same row.
Offline Rafen
« Reply #2 on: Wed, 23 January 2013, 19:27:16 »
Thanks for the help. I was planning on making them all blank white keys.
