Author Topic: Replacement W key  (Read 2877 times)
Offline nevica
Replacement W key
« on: Fri, 25 January 2013, 06:35:22 »
Hello,
I want to replace my W key on my CM Storm TK cherry MX red keyboard.
I have been looking to replace with a textured or profiled key to provide some tactile feedback for gaming.
Key needs to be:
Cherry MX
ABS
Profiled in some way
Any idea where I can get one of these?
Nevica
Offline Rafen
Re: Replacement W key
« Reply #1 on: Fri, 25 January 2013, 06:37:39 »
Welcome to GH!
Wasdkeyboards.com has some textured keys that will fit that profile. Just visit there website or you can go the the vendor forum and talk to them.
Offline MattBuzzy
« Reply #2 on: Fri, 25 January 2013, 06:39:57 »
First of all welcome to Geekhack!
As for your question I would recommend going here http://www.wasdkeyboards.com/index.php/textured-cherry-mx-keycap.html they can provide exactly what you want and have very fair shipping costs even internationally.
You would be looking for a R3 keycap to replace that W
Offline nevica
« Reply #3 on: Fri, 25 January 2013, 06:43:48 »
Hi there,
Thanks for the info. I was looking for something a bit more substantial. (like a large bump or dot).
And ABS not plastic.
Any pointers would be appreciated.
Nevica
Offline jeroplane
« Reply #4 on: Fri, 25 January 2013, 07:22:04 »
ABS is plastic.
My signature hasn't changed since 2012. I should really update it.
Offline nevica
« Reply #5 on: Fri, 25 January 2013, 07:25:16 »
Yes, your right. ABS is plastic. I meant to say grip coated as well.
Nevica
Offline Broadmonkey
« Reply #6 on: Sat, 26 January 2013, 09:27:57 »
These are textured :
You would need a R3 1x1 keycap.
