Author Topic: LBOTS Mechanical Gaming Keyboard  (Read 20632 times)
Offline Denonic
« on: Sat, 26 January 2013, 04:54:12 »
Stumbled upon this whilst looking through Taobao.
Did a quick search and only found a single reference for this board here but nothing really detailed.
12417-0
Unfortunately It's all in Chinese so I can't be much more detailed.  But it is quite interesting in that its similar to the Corsair boards that mount the switches onto the board rather than a receded plate.  Whats more interesting is it looks like you might be able to change the switches without desoldering.
12421-1
Could possibly get in there with a clip and pop the top half off.
Original link for anyone who can read Chinese and possibly translate.
LBOTS on Taobao
« Last Edit: Sat, 26 January 2013, 04:57:07 by Denonic »
Offline kaoSTheory00
Re: LBOTS Mechanical Gaming Keyboard
« Reply #1 on: Sat, 26 January 2013, 07:21:59 »
As a Chinese speaker, let me translate.
It says the frame is a unibody metal construction of 1mm thickness (they didn't specify the actual material, only that it's metal).
The keycap spacing is in line with most other Cherry switch boards.
It's using MX blacks.
The delete/insert cluster also doubles as 6 programmable macro keys, L1-L6.
And, apart from the usual marketing mumble jumble, that's about the only info that can't be interpreted from the pictures alone.
« Last Edit: Sat, 26 January 2013, 07:23:51 by kaoSTheory00 »
Offline ValerieV
« Reply #2 on: Sat, 26 January 2013, 07:52:36 »
The keys don't look like they are on right. They look like they are half on and that they can pop out. Otherwise, it looks nice as far as size goes. Thanks.
Offline MissMurd3r84
  • In IRC wondering why Kmiller8 is yelling.
« Reply #3 on: Sat, 26 January 2013, 08:09:20 »
They look as though they are on perfectly fine to me.. I even compared them to the keyring with a switch on it in front of me and the key on it goes down to the same point as that keyboard.
KBC Poker - Red switches. Noppoo Choc Mini - Black switches. Leopold FC700R (White) - Blue switches. Ducky YOTD - Brown switches. Razer BW - Blue switches and rusted.
Offline Denonic
« Reply #4 on: Sat, 26 January 2013, 08:43:47 »
Anything about nkro or the LEDs on the caps lock etc?  One picture had no window on the key cap so if there's a variant without LEDs it would be perfect for custom switch combinations.  The fact that there isn't really a frame makes it a little smaller than most tenkeyless boards whilst not giving up much else to do so.
Integrating macros into that existing key cluster is also a nice touch.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Sat, 26 January 2013, 09:16:55 »
There are 2 or 3 other 'brands' of this keyboard. Some of them the metal casebody comes in several color not just black an dosen't have the logos all over it.
Offline deltr
« Reply #6 on: Sat, 26 January 2013, 09:27:08 »
Is this available in the states? I loved the look of the corsair boards due to the lack of a bezel, but hated the reds and the tenkey.
Offline jabar
« Reply #7 on: Sat, 26 January 2013, 09:38:34 »
Yeah it looks like the Neo brand that qtan sells in his store, not sure if it's also a metal body:
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/shop-mechanical-keyboard-by-br/neo-87-mechanical-gaming-keybo/lid=34054277
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
« Reply #8 on: Sat, 26 January 2013, 09:56:02 »
The LEDs are green and are under the keycaps as was shown. The only picture that didn't have the LED windows looked more like a concept render.
It's said to have full NKRO, but I'm assuming it'll be the standard 6KRO over USB and NKRO over PS/2.
Also, Fn + Prntscr activates "Gaming Mode" (I'm assuming this locks the windows key and enables the macro key cluster) and Fn + Win makes the WASD keys and the arrow keys interchangeable.
And if it wasn't clear before, the keyboard is named "The Mechanic".
Offline Denonic
« Reply #9 on: Sat, 26 January 2013, 09:56:22 »
Any idea what the others were?  Just looked at the NEO from qtan and didn't like the lack of right winkey.
Offline Denonic
« Reply #10 on: Sat, 26 January 2013, 10:10:58 »
Awesome.  Thanks for translating all that =)
« Reply #11 on: Sat, 26 January 2013, 11:05:16 »
I don't remember what the other brands were called, but there were some threads here about them if you want to comb through topics for it.
Offline FoxWolf1
  • 154
« Reply #12 on: Sat, 26 January 2013, 11:05:20 »
They also do a backlit full-size:
Offline Denonic
« Reply #13 on: Sat, 26 January 2013, 19:23:57 »
Think this might be it.
Flashget g600.
Silver looks really nice.
« Reply #14 on: Sat, 26 January 2013, 20:13:39 »
Yes, that was one, and there was another that did not have any logo printed on it anywhere if I remember right. I think that was the one supposedly available in 7 anodize colors.
Offline Denonic
« Reply #15 on: Sat, 26 January 2013, 21:26:01 »
I think that might be the NEO Zelia from qtan.  That's a little bit different though as its pcb mounted exposing the entire switch. Maybe not though as I can only seem to find it in black.
Offline geekTH
« Reply #16 on: Wed, 03 July 2013, 05:19:57 »
FlashGet G600, actually it will sent with red keycaps, just like this hot and sexy :-*
Offline geekTH
« Reply #17 on: Wed, 03 July 2013, 05:42:36 »
hey guys, I found that Labot Mechanical Gaming Keyboard is available in Banggood.com  :cool:
Offline Techno Trousers
  • ʘ_ಠ
« Reply #18 on: Wed, 03 July 2013, 14:57:49 »
hot and sexy :-*
Wow, that's gorgeous with the translucent red keys. Must... not... buy... another.... Cherry MX board!
Offline geekTH
« Reply #19 on: Thu, 04 July 2013, 09:50:36 »
hot and sexy :-*
YOU love it  ? ;D  Now you'll find it available here http://tinyurl.com/no7cfvx
