Author Topic: Any audio of cherry mx green?  (Read 3383 times)
Offline ValerieV
« on: Sat, 26 January 2013, 07:56:05 »
I am interested in trying a cherry mx green but i want to hear what it sounds like. Can anyone here post an audio or video link to how it sounds? Thanks.
Offline alaricljs
  • I be WOT'ing all day...
Re: Any audio of cherry mx green?
« Reply #1 on: Sat, 26 January 2013, 08:35:45 »
It sounds almost identical to a Cherry blue.  However I don't have one at hand to record for you.
Filco w/ Imsto thick PBT
Offline jabar
« Reply #2 on: Sat, 26 January 2013, 09:36:26 »
Not really for me. MX Blues produce a much higher pitched click probably because of the force one exerts through the actuation point since the spring is so light. For MX Green, I get a gentler, deeper clunk.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline ValerieV
« Reply #3 on: Sat, 26 January 2013, 09:45:29 »
So is it heavier? More force needed? Because i hate the cherry mx blacks! Can you tell me what the force is (ie. 45, 55, 30)? Thanks!
Offline jabar
« Reply #4 on: Sat, 26 January 2013, 10:24:21 »
Yes, they require a lot more force than Blues (~50 cN) and Blacks (~60 cN); MX Greens are rated at 80 cN for actuation. Great for high accuracy typing, bad for gaming (which is ironic that CM markets their Green board as a gaming keyboard, but it's still a nice keyboard).
If Blacks are too much for you, you won't want Greens.
Phantom 7bit
Offline ValerieV
« Reply #5 on: Sat, 26 January 2013, 11:36:52 »
You just saved me some money! Thanks. I appreciate your help.  :D
Offline AKIMbO
  • HHKBro
« Reply #6 on: Sat, 26 January 2013, 11:41:44 »
It's a tad more muted than cherry mx blues.  Still one of the louder cherry switches.
| KBD75 (box reds)
Offline Warduke
« Reply #7 on: Sat, 26 January 2013, 12:36:00 »
(around 1:45)
Unicomp Customizer 104 - Rosewill RK-9000 - CM Storm QuickFire Rapid - CM Storm QuickFire Stealth -
Pok3r
Offline ValerieV
« Reply #8 on: Sat, 26 January 2013, 14:22:27 »
Thank you for the audio. I can't see myself buying the greens when they don't really sound different than the blues and they are harder to press. Thanks again.  :D
Offline Loligagger
« Reply #9 on: Sat, 26 January 2013, 15:34:37 »
I doubt this number is accurate. It's probably the force at the bottom of the keys travel. I did a very rough test with my mx whites and they actuated around 55-60g. I can't imagine mx greens would be that much heavier than whites.
Offline ValerieV
« Reply #10 on: Sat, 26 January 2013, 18:47:13 »
ValerieV: if you have any doubt join the tour/lottery: http://geekhack.org/index.php?topic=39640.0
I think i will. How long do i have to decide to get into the lottery?
Offline jabar
« Reply #11 on: Sat, 26 January 2013, 18:57:59 »
Well, 80 cN is what Cherry has on their official spec sheet. Ripster has done lots of tests and produced these experimentally determined numbers: http://imgur.com/a/RJqM4#1
All Cherry estimates are at point of actuation, 2 mm into spring compression (4 mm = bottom out). As a side note, "Korean" springs reference force required to fully compress, which is why 62g isn't roughly the same as a Cherry spring used in a 60 cN actuation switch. (1 g = 0.981 cN according to Ripster)
Phantom 7bit
Offline Loligagger
« Reply #12 on: Sat, 26 January 2013, 19:48:37 »
It appears the 80cN number is the peak force. Stacking milk bag land nickels on a switch before it gives results in 80g +/- a gram or two. The force at actuation should be lower than this number, then.
Offline jabar
« Reply #13 on: Sat, 26 January 2013, 21:50:06 »
Yeah I haven't tested it myself. That's what Cherry reports, and it's obvious across several switches that the actual actuation number isn't what they report.
Phantom 7bit
Offline ValerieV
« Reply #14 on: Sat, 26 January 2013, 22:06:52 »
Okay, thanks.
Offline missalaire
  • Great Finder of Great Finds
« Reply #15 on: Sun, 27 January 2013, 00:52:06 »
