Author Topic: CMStorm QuickFire XT Release Date?  (Read 17494 times)
Offline cyberdeath
« on: Mon, 28 January 2013, 12:19:35 »
Hello,
I have read through several of the topics on here and viewed several videos on the CMStorm QuickFire XT but I do not see a definitive release date.  Is that because one has not been targeted or am I missing it somewhere?
Was really trying to get an ETA for release (including prepurchase, if available).  I'm in need of a new keyboard now but am trying to hold off until the XT is released...
cyberdeath
Offline CM-Rajiv
  • CM Storm Rep
  • * Moderator
Re: CMStorm QuickFire XT Release Date?
« Reply #1 on: Mon, 04 February 2013, 17:12:34 »
Hi,
No definitive release date. Will update you when we get one :)
Cooler Master USA - CM Storm Marketing Team - [CM Storm Trigger CherryMX Green Switch]
Offline missalaire
  • Great Finder of Great Finds
« Reply #2 on: Sun, 10 February 2013, 16:07:16 »
Any update on when the Quickfire Stealth will be out?
Offline CM-Rajiv
  • CM Storm Rep
  • * Moderator
« Reply #3 on: Tue, 12 February 2013, 18:45:39 »
March most likely
Offline Tempest790
« Reply #4 on: Wed, 06 March 2013, 20:59:23 »
The Quickfire XT with green switches looks good.  Unfortunately, the Trigger is too big for me to use on my keyboard tray at work, so I need a standard size keyboard.  I definitely want a backlit model though (preferably red, but I'll take green or blue if I had to).
Offline cingkrab
« Reply #5 on: Sun, 17 March 2013, 16:51:47 »
Any update on the QuickFire XT release date?
Offline bazemk1979
« Reply #6 on: Sun, 17 March 2013, 22:22:44 »
would like to know the same
Offline PointyFox
« Reply #7 on: Sun, 17 March 2013, 22:55:49 »
WTB a white Quickfire with MX Greens and purple backlighting!
Offline CM-Rajiv
  • CM Storm Rep
  • * Moderator
« Reply #8 on: Mon, 18 March 2013, 13:57:13 »
May/June timeframe at earliest...
XTS (backlit model) is a bit farther off as well.  We're working on it, though.
Offline PointyFox
« Reply #9 on: Mon, 18 March 2013, 20:55:11 »
Also, will that mouse be available for sale?  It looks like a white Recon mouse.
Offline SpartanW80
« Reply #10 on: Fri, 05 April 2013, 21:06:47 »
Will the XTS follow the same color scheme as the TK?
Offline flare4000
« Reply #11 on: Tue, 23 April 2013, 18:44:05 »
Is this release date still on track? I am asking because I am hesitating on waiting to buy the xt or go for a trigger.
Offline Carter
  • CM Storm Rep
  • * Moderator
« Reply #12 on: Tue, 25 June 2013, 18:02:12 »
TODAY
Offline Carter
  • CM Storm Rep
  • * Moderator
« Reply #13 on: Tue, 25 June 2013, 18:02:59 »
It will be soon. Where you see the red pad printed logo, will be changed to RGB logo to match the mouse wheel lighting effect.
Offline PointyFox
« Reply #14 on: Tue, 25 June 2013, 20:42:04 »
XT is in the CM Store now.  However it's not white, backlit, or stealth.  I guess those will come later  :))
I'll definitely get that mouse though if it comes in white  :)
« Last Edit: Tue, 25 June 2013, 20:44:03 by PointyFox »
Offline Carter
  • CM Storm Rep
  • * Moderator
« Reply #15 on: Tue, 25 June 2013, 21:04:36 »
They keyboard pictured is a white "Quickfire Ultimate" which is a fully backlit version of the Pro.
