Author Topic: Post your GH60!  (Read 185871 times)
Offline dirge
Re: Post your GH60!
« Reply #50 on: Thu, 31 January 2013, 06:10:06 »
No fancy stuff here (except for imsto's thick PBTs, of course). I can't prove its not a poker. You have to believe it's GH60 next to a prototype of the upcoming GHPad;)
Here was me assuming you used ISO!  I need another set btw ;) still can't find the bad solder joint! (will had anther go over the weekend)
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Offline kabar
Re: Post your GH60!
« Reply #51 on: Thu, 31 January 2013, 11:19:32 »
So beautiful.
Offline Glissant
Re: Post your GH60!
« Reply #52 on: Thu, 14 February 2013, 10:24:57 »
J.D's purple GH60 is my dream board right now. White on black cherry's with GMK white on purple mods + Carpurple case = MMMMMMMMMMMMMMMMMMMMMMMMMMMMM.
Offline SmallFry
Re: Post your GH60!
« Reply #53 on: Thu, 14 February 2013, 10:25:48 »
Well... yes... NERDGH60ASM!
Offline Viz
Re: Post your GH60!
« Reply #54 on: Sat, 16 February 2013, 13:59:27 »
Dirge: Damn, that's creative. And nice!
komar: Wow, nice desk setup. what OS?
Also; please straighten up that keypad.
Offline komar007
    • komar's blog
Re: Post your GH60!
« Reply #55 on: Sun, 17 February 2013, 09:12:51 »
Thanks. Gentoo/xmonad
Why straighten up?
Offline singaporean123
  • I like keycaps and I cannot lie
Re: Post your GH60!
« Reply #56 on: Sun, 17 February 2013, 09:24:00 »
where can I get one?
Offline komar007
    • komar's blog
Re: Post your GH60!
« Reply #57 on: Sun, 17 February 2013, 09:41:47 »
Here, very soon.
I'll start the groupbuy shortly.
Re: Post your GH60!
« Reply #58 on: Sun, 17 February 2013, 10:26:26 »
Here, very soon.
great!
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: Post your GH60!
« Reply #59 on: Sun, 17 February 2013, 13:42:09 »
uno momento. trying to find a cleanish brush to scrub the flux off the back
Offline mkawa
Post your GH60!
« Reply #60 on: Sun, 17 February 2013, 14:12:16 »
ok now someone tell me what this is supposed to do :))
Offline Batmann
Re: Post your GH60!
« Reply #61 on: Sun, 17 February 2013, 14:29:41 »
first pic is a bit blurry but still soldering job looks clean (some pins look like they are not soldered though)
I may have missed something but the plate is already done?
Post your GH60!
« Reply #62 on: Sun, 17 February 2013, 14:31:00 »
That's a Vortex Poker plate :)
Offline SmallFry
Re: Post your GH60!
« Reply #63 on: Sun, 17 February 2013, 14:32:03 »
Bah. You beat me to it JD!
Offline Batmann
Re: Post your GH60!
« Reply #64 on: Sun, 17 February 2013, 14:32:15 »
Thanks for the input jd,
does it mean that Beast poker plate will fit GH60?
Post your GH60!
« Reply #65 on: Sun, 17 February 2013, 14:33:10 »
But I do have some plate designs ready to go. One is compatible with a Poker, and another is compatible with a Pure, so people could order for those, as well.
Post your GH60!
« Reply #66 on: Sun, 17 February 2013, 14:37:04 »
Yes, any Poker plate will work. If you want a standard ANSI layout. You won't be able to open some of the switches with the Beast plate without desoldering, since they are rotated 90 degrees. Unless komar is changing the design. But my plate design is like WFD's and has openings for the tabs on rotated switches also.
Offline Batmann
Re: Post your GH60!
« Reply #67 on: Sun, 17 February 2013, 14:37:28 »
That's a good news, I still have a poker plate left from Beast GB  :D
Offline mkawa
Re: Post your GH60!
« Reply #68 on: Sun, 17 February 2013, 14:38:17 »
the joints are all good (i just tested the board -- see the betatesting thread). i solder with 0.025 and a loupe so i just made sure there was a joint and moved on; i didn't bother flowing across the pad unless that was the only way to make the joint.
Post your GH60!
« Reply #69 on: Sun, 17 February 2013, 14:40:48 »
Lazy. :P
What if you want to desolder? I sometimes have to add more solder if there isn't enough to get it all out.
Offline mkawa
Re: Post your GH60!
« Reply #70 on: Sun, 17 February 2013, 14:46:39 »
if i want it desoldered i'll send it to someone with an 808 :))
Post your GH60!
« Reply #71 on: Sun, 17 February 2013, 14:52:57 »
That's a really good idea. That way you won't mess anything up. I really need to get an 808, but I can't afford it with all these keyboards and caps I keep buying. :P
Offline Luke
    • My Technology Blog
Re: Post your GH60!
« Reply #72 on: Sun, 17 February 2013, 15:32:34 »
Not really sure this is the right place to post this question but I was just thinking of how much I should save up for one of these beauty's, I've seen people say that they are going to be a similar price to the phantom but I haven't been around long enough to know about that. I'm just looking for an average price, wont be anything fancy ;) Cheers Guys :D
Offline mkawa
Re: Post your GH60!
« Reply #73 on: Sun, 17 February 2013, 15:39:34 »
as with anything diy, ymmv. things will get clearer as the team starts talking seriously to manufacturers
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Post your GH60!
« Reply #74 on: Sun, 17 February 2013, 15:52:38 »
If you are prepared to scrounge parts from used market, you could potentially get all your keycap, switch and stabilizer from an old G80 or whatever under $30, $20-30 for a plastic poker/pure case, and whatever the final cost of the pcb. I guess I would estimate $80-90 for such a build to be conservative and then up to whatever $400+ depending on case and keycap options and so on.
Offline Luke
Re: Post your GH60!
« Reply #75 on: Sun, 17 February 2013, 15:58:18 »
so it's pretty much my choice then, amiryt? this is still probably going to be at the latter end of the scale knowing me  :p Thanks :D
Offline Viz
Re: Post your GH60!
« Reply #76 on: Sun, 17 February 2013, 17:23:11 »
Why straighten up?
Kk. FreeBSD/SpectrWM here.
idk, maybe just my "freakish" cleanliness? I like to allign everything.
Offline SmallFry
Re: Post your GH60!
« Reply #77 on: Sun, 17 February 2013, 17:25:00 »
I'd say that the $100 is about right, I got my Phantom, through trades etc, for under $100 total.
Offline TheQsanity
  • SmallFry Lovin'
Re: Post your GH60!
« Reply #78 on: Tue, 19 February 2013, 22:10:51 »
Black Plates should be made. They look sexy :p
SmallFry! <3
Re: Post your GH60!
« Reply #79 on: Fri, 08 March 2013, 15:00:01 »
Finally got around to taking a few picture of mine...
MX red with black on space, super black on caps lock, and lock on right shift. Cherry white on black, dolch and red esc doubleshots with PBT space in a Pure plastic case.
Offline baldgye
  • Will Smith Disciple
Re: Post your GH60!
« Reply #80 on: Fri, 08 March 2013, 15:01:50 »
why would you use that lock on the shift and not caps lock ?
Re: Post your GH60!
« Reply #81 on: Fri, 08 March 2013, 15:18:30 »
Shift lock and caps lock have different behavior. I mostly only used it because I had it, and thought it would be interesting.
Offline baldgye
Re: Post your GH60!
« Reply #82 on: Fri, 08 March 2013, 15:20:59 »
fair enough :P
Re: Post your GH60!
« Reply #83 on: Fri, 08 March 2013, 15:22:11 »
See my answer here, and the posts following. I guess this needs to go into the wiki.
Offline Loligagger
Re: Post your GH60!
« Reply #84 on: Sat, 09 March 2013, 00:59:36 »
How'd you get your hands on one of those?
Re: Post your GH60!
« Reply #85 on: Sat, 09 March 2013, 11:21:46 »
It happened to be on spacebar switch on an old minicom I picked up.
Offline RougeR
Re: Post your GH60!
« Reply #86 on: Sat, 09 March 2013, 12:31:32 »
mmm gh60 doesnt look bad, also i should eventually have 2x mx super blacks on the way.
Buckling spring warrior!
Offline baldgye
Re: Post your GH60!
« Reply #87 on: Sat, 09 March 2013, 12:33:15 »
ahhh that makes alot of sense... I guess you'd need to go to alot of touble to make it work diffrentally
Offline codyeatworld
Re: Post your GH60!
« Reply #88 on: Sun, 10 March 2013, 20:13:35 »
Just seen this thread, love the gh60, MASSIVE thanks to komar.  Mate you're a ****ing legend.  Owe you a drink!
I didn't think a keyboard like this existed. Great job, its looks awesome!  :cool:
Now.... I must acquire a gh60 somehow...
Re: Post your GH60!
« Reply #89 on: Sun, 10 March 2013, 20:30:01 »
There will be a GB!  You just have to wait a little while and order one.
Re: Post your GH60!
« Reply #90 on: Sun, 10 March 2013, 20:32:19 »
Oh man....Ivan's board is so nice. And that custom layout...
Re: Post your GH60!
« Reply #91 on: Sun, 10 March 2013, 20:39:21 »
Oh I thought I JUST missed it.
I'll definitely be getting one then.
Re: Post your GH60!
« Reply #92 on: Sun, 10 March 2013, 20:41:25 »
Here's some info on the GH60: Link 1 and Link 2
Offline Dubsgalore
Re: Post your GH60!
« Reply #93 on: Sun, 10 March 2013, 21:26:02 »
thanks for the links! this looks interesting
Offline esoomenona
  • Gnillort?
Re: Post your GH60!
« Reply #94 on: Mon, 11 March 2013, 09:22:57 »
I think lysol's layout is cool, and if it fits him then that's great. I wouldn't be able to use it because I use the Windows key and other keys primarily with my left hand. The only one that really requires the second hand is Win+L.
Re: Post your GH60!
« Reply #95 on: Mon, 11 March 2013, 11:01:19 »
I have a huge focus on gaming. Left win is a nuisance, especially with a lot of older games that do not ignore it and you get dumped to desktop, often dying in the process. I had Lwin disable on my Pokers before, now I just don't even need to have that unwanted key there :) also I often do bind things to both control and alt in gaming, and having them next to each other this way is more comfortable and convenient.
At the same time I do find the win+ hotkeys very useful outside of gaming so total winkeyless was not ideal either. This layout was my solution to have it both ways as it were.
« Last Edit: Mon, 11 March 2013, 11:04:20 by IvanIvanovich »
Offline esoomenona
  • Gnillort?
Re: Post your GH60!
« Reply #96 on: Mon, 11 March 2013, 11:07:13 »
In that case, it does sound like a good layout.
Offline Glissant
Re: Post your GH60!
« Reply #97 on: Thu, 14 March 2013, 13:05:45 »
I just finished soldering switches to my GH60 PCB. Everything is working great so far. I just did the Poker layout, but I might change it in the future when I have more experience.
(I'm so sorry for horrible quality photo. My S3 can't deal with low light)
15659-0
The switches are red stem with black spring (one brown switch lol)
Thanks to WhiteFireDragon (he did the SMD and pre-programming for me too) and jdcarpe for the PCB.
Tomorrow I will be playing with programming the thing. YAY.
« Last Edit: Thu, 14 March 2013, 13:44:52 by Glissant »
Offline The_Beast
  • I like wood ಠ_๏
Re: Post your GH60!
« Reply #98 on: Thu, 14 March 2013, 13:20:33 »
I hate you
Alot
Offline TheQsanity
  • SmallFry Lovin'
Re: Post your GH60!
« Reply #99 on: Thu, 14 March 2013, 13:22:09 »
Use flash?
How did you get that led on the caps lock? Just any led on any switch?:))
SmallFry! <3
