Author Topic: Realforce capslock key  (Read 2295 times)
Offline Yuuki
« on: Mon, 28 January 2013, 14:03:26 »
I don't know if it has already be said but I noticed something strange today.
I have at work 2 rf 87. One is a 10th anniversary, variable silent. The other is a rf 87 black variable.
On both, capslock and ctrl are inversed.
When I activate capslock, I noticed that only the letters are affected. So I can type something "normally" without having to "inverse my brain" for the other keys. I find that behaviour very neat.
At home I use a rf 105. I just tried the same thing but capslock has the same behaviour it always had. Just activate shift on every keys.
Is it something exclusive to the 87 ? Is it the same on other board that use topre switches ? (like HHKB)
Offline daerid
    • Rossipedia
Re: Realforce capslock key
« Reply #1 on: Mon, 28 January 2013, 14:08:16 »
I've never used a board that behaved that way. And I've used a lot of boards.
Whenever I turn Caps on, hitting "a" enters "A", and hitting "1" enters "1", not "!".
Offline jabar
« Reply #2 on: Mon, 28 January 2013, 14:22:50 »
I *think* my old Apple Extended Keyboard II worked like that, where capslock was a universal shift key (1 became !).
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline Yuuki
« Reply #3 on: Tue, 29 January 2013, 03:15:58 »
I didn't try with the digit But i did some testing :
WITH CAPSLOCK ACTIVATED :
QWERTYUIOP123456,./;'[]
It seems it does the same for F1 F12 keys (tried with some shortcuts)
Does anyone experience the same behaviour with a 87u ?
I have only a 10th and a black 87 here, and the 105 at home. So I can't tell if its 87 exclusive or not.
Offline koralatov
« Reply #4 on: Tue, 29 January 2013, 09:20:58 »
It doesn’t do that on my ISO/UK AEKII, or my ANSI AEKI.  The capslock key acts correctly.  Both were made in Ireland, though, so US/Mexican-made ones may act differently.
Offline Yuuki
« Reply #5 on: Tue, 29 January 2013, 11:37:49 »
So no one is reproducing ?
« Reply #6 on: Tue, 29 January 2013, 11:46:20 »
Everything works normally on my RF87u.  I thought you were confused about the ctrl/caps swap,  but I've never seen a keyboard that treats caps loxk as shift
Offline Yuuki
« Reply #7 on: Tue, 29 January 2013, 12:00:17 »
it's more like capslock only affect keys with letter, which is nice
Offline lazerpointer
  • ya gotta stay phresh
« Reply #8 on: Tue, 29 January 2013, 13:35:59 »
This is how it always is, regardless of what keyboard you use.
i type, therefore i geekhack
Offline isman
« Reply #9 on: Tue, 29 January 2013, 15:18:57 »
As a french myself, I have to add to the OP that in France, when caps lock is on, it behaves
Like a universal Shift upon the entire keyboard, don't really know if this feature is bound to the AZERTY ISO layout or more globally to euro boards.
Offline Yuuki
« Reply #10 on: Tue, 29 January 2013, 15:43:29 »
software side.
Mystery solved.
Thx
