Author Topic: [Quotes In!] - Aluminum GH60 Case - Anodizing Samples In!  (Read 101135 times)
Offline regack
Re: Aluminum GH60 Case - Input/suggestions welcome
« Reply #50 on: Thu, 14 February 2013, 14:53:06 »
Need USB hole. :P
I have no idea where it is on the number pad
Well, it's not really made yet, but I think the thought was to have it mimic the poker in positioning of USB (and some of the PCB mount points)
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #51 on: Thu, 14 February 2013, 15:15:19 »
Progress lookin' mighty fine my friend :cool:
Offline The_Beast
  • I like wood ಠ_๏
« Reply #52 on: Thu, 14 February 2013, 15:18:43 »
Need USB hole. :P
That's what I thought, but I never make assumptions
^___^
Offline The_Beast
  • I like wood ಠ_๏
« Reply #53 on: Fri, 15 February 2013, 14:48:42 »
Drawings for the case are done. Being sent to bro's to check then to the machine shops for quoting.
I'll do the drawings for the number pad this weekend, I've had my fill of AutoCAD today
« Reply #54 on: Fri, 15 February 2013, 17:36:14 »
The_Beast, this case is looking...beast  :cool:
Offline salmo
    • messmore.org
« Reply #55 on: Sat, 16 February 2013, 10:18:50 »
I like what you got going on here.  Simple, and has what I want as-is.  Hope it's not too pricey, since I've been burning through my toys budget lately.
Offline Hubbert
« Reply #56 on: Sat, 16 February 2013, 16:48:34 »
Excellent work, including the ledges / crotches between modifiers.  Of course, being a keyboard nut, I'm looking to do something similar...but different :)
1) Are you thinking of getting any prototypes from Shapeways before going to metal?  Is it easy to use the same CAD files for Shapeways and CNC?
2) Could you give some details on the volume and weight of the main section, the separate numpad, and your weighting system?  I know that other metals would be more expensive to CNC, but I'd like to calculate how much of an impact they'd have on the weight.
Current: ThinkPad, Modified Model M, Customozed Unicomp on order.
Occasional: Acer (rubber with sharp edged keycaps)
Storage: Kinesis Advantage (Cherry brown), PC Concepts split keyboard (ALPS white)
Scorpius M10 (Cherry blue)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #57 on: Sat, 16 February 2013, 18:11:55 »
I was going to get a prototype right from the machine shop. I'll look into shape ways more, but I've heard they are pretty expensive.
For the weight, I set materials in Solidworks. Solidworks did fancy volume measurements and found weight based on the density of the materials I picked. If I recall correctly the GH60 case was 3.16 pounds and the numberpad was around 1 pound. Everything is aluminum except the weight plate and the feet which are stainless steel (close to, or the same density as brass).
Offline Hubbert
« Reply #58 on: Sat, 16 February 2013, 20:31:12 »
3.16 lb *0.45359 kg/lb * 1000 g/kg / 2.7 g/cm3 = 530.87 cm3
The "strong & flexible plastic" is $1.40/cm3, so $743  :eek:.  Sandstone is $0.75, so half that.
I am a little confused / disappointed because I thought I read a post about getting an ErgoDox case printed for $35.
Maybe Shapeways could make a scale model.
But to my materials question, it seems that the densities of brass, bronze, and steel are within about 10% of each other, and about 3x aluminum, so a full keyboard+numpad case would go from ~4 lb to ~12 lb.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #59 on: Sat, 16 February 2013, 20:36:07 »
See what I mean about shapeways prices. I don't think a prototype will cost half that to make out of aluminum.
The problem I see with a scale model is it will be pretty much useless to check over measurements with a real GH60 PCB and I'm sure will have trouble finding fasteners and tapping the holes that are required for the case.
Like I said the majority of the case will be aluminum, only the weight plate and the feet will be stainless:
The weight plate case be seen here:
I would love to make a 100% stainless case (I'm sure others would be interested as well) but I'm sure the machining time of aluminum and steel are different since steel is so much harder/harder to machine when compared to aluminum.
:D
« Reply #60 on: Sat, 16 February 2013, 20:49:15 »
You can look up material properties to find densities.
Offline Hubbert
« Reply #61 on: Sat, 16 February 2013, 21:12:39 »
I did: 2.7 g/cm3 for aluminum, somewhere in the 8's for other metals, which is how I calculated 12 pounds.  Part of my vagueness is that a materials scientist told me that copper-based alloys like brass and bronze were less dense than steels, when what I see on the Internet seems to be the opposite and is unsourced.  I almost went to the library for a CRC, but didn't.  But in any case, I was surprised that the densities of the other metals were all within about 10% of  each other.
Offline Hubbert
« Reply #62 on: Sat, 16 February 2013, 21:17:44 »
:D
How much does the weighting plate weigh?
I have asked osrix some questions about casting in another thread.  Perhaps you could make a mold from your CNC aluminum case which could make copies in in other metals.
For me, casting may let me avoid creating a CAD model, since I'd have to start from scratch (even though what I want to do is probably 90% similar to existing cases).  Ironically, CAD was one of my early reasons for getting interested in computers, and now I'm talking about using wax and Bronze Age fabricating techniques to avoid it.
« Last Edit: Sat, 16 February 2013, 21:23:24 by Hubbert »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #63 on: Sat, 16 February 2013, 21:23:06 »
:D
I have asked osrix some questions about casting.  Perhaps you could make a mold from your CNC aluminum case which could make copies in in other metals.
I don't have solidworks on my personal computer, but I thought it was just over 1 pound. Again, IIRC it was 1.06 lbs
Molds are a whole 'nother beast if you're talking about injection casting. If you're just doing sand casting, you're not going to get a very good resolution and might have to end up milling anyways.
« Reply #64 on: Sat, 16 February 2013, 21:28:14 »
What about doing a plaster casting for a ceramics mold?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #65 on: Sat, 16 February 2013, 21:31:28 »
I know very little about molding right now. However, I'm in a metals class right now and we'll be casting some stuff later in the semester. I know I'll be asking about molding caps......
Offline Hubbert
« Reply #66 on: Sat, 16 February 2013, 21:50:13 »
:D
Thanks, a pound is close enough.  I'm still curious about casting, though...I don't require a perfect finish.  I'm thinking of making another thread about CAD; maybe that's easier, and certainly more portable, than setting up my own foundry.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #67 on: Sat, 16 February 2013, 21:59:09 »
:D
Well if you're casting, you're going to need a foundry. They aren't very hard to make from what I've seen. That is if you're doing aluminum. Steel is a whole nother beast
Offline Hubbert
« Reply #68 on: Sun, 17 February 2013, 07:16:25 »
I could use someone else's foundry.  But even a mold is something that I would be reluctant to ever throw away.
But back to CNC prototyping: would it be somewhat inexpensive to make a prototype in softwood via CNC?
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #69 on: Sun, 17 February 2013, 09:15:12 »
That might depend on the shop. But I don't think prototyping with another material is ideal, especially since The_Beast has these files already and is ready to get a real prototype.
« Reply #70 on: Sun, 17 February 2013, 09:24:23 »
I'm not so sure its the material as much as the shop time and setup that would drive the cost of the prototype. Especially since you're wanting a one off.
Offline laden3
« Reply #71 on: Sun, 17 February 2013, 10:06:28 »
Prototype a steel one and mass produce aluminum ones= win ;D
I rrrove brrracks.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #72 on: Sun, 17 February 2013, 16:00:18 »
I'll ask about a stainless steel one, but please don't get your hopes up about one.
Offline kboardvintage
« Reply #73 on: Sun, 17 February 2013, 16:58:23 »
That will HEAVY
Offline Hubbert
« Reply #74 on: Sun, 17 February 2013, 20:39:35 »
Only about 9 pounds without the numpad or 12 with: my personal goal is the weight of a Selectric II.  One unverified source said "20 pounds," but I've emailed a guy who owns some to see if he knows.  If I go for a "100%" keyboard, though, it's getting pretty close  :cool:
Offline laden3
« Reply #75 on: Tue, 19 February 2013, 20:26:42 »
Just wondering, how thick is the case? If it is too thick, it might put a lot of strain on our palm when we are typing unless there is a palm rest.
I rrrove brrracks.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #76 on: Tue, 19 February 2013, 20:31:49 »
~0.9375 tall
Offline Jocelyn
  • 조셀린
Re: Re: Aluminum GH60 Case - Input/suggestions welcome
« Reply #77 on: Thu, 21 February 2013, 12:31:52 »
Thanks, that's what I'm going for
I'll be send it out for quote sometime next week and should hear back within a few days
Any updates yet? :)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #78 on: Thu, 21 February 2013, 12:34:35 »
Any updates yet? :)
Drawings have been revised and someones checking them again before they get sent out for quotes. Should be tomorrow or Monday when I send them out and IDK how long it will take for the shops to get back to me
:D
Offline Jocelyn
  • 조셀린
« Reply #79 on: Thu, 21 February 2013, 12:36:29 »
Thank You :)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #81 on: Thu, 21 February 2013, 12:53:46 »
Beast and I did a first pass of the quote drawings earlier this week. Hopefully I won't get swamped at work and I can recheck/send them back to him when he's ready. Don't worry, The_Beast is still cranking on this project :D
Offline The_Beast
  • I like wood ಠ_๏
« Reply #82 on: Thu, 21 February 2013, 12:55:16 »
Don't rush :D
Rather have a good check over than a mistake in manufacture
« Reply #83 on: Thu, 21 February 2013, 16:44:53 »
Ben, are you interested at all in doing a TKL-sized alu case?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #84 on: Thu, 21 February 2013, 17:13:09 »
Not really
Offline Hubbert
« Reply #85 on: Thu, 21 February 2013, 20:14:53 »
Just by way of general encouragement (not that you need it), after all my noise about other materials, I encountered an aluminum enclosure today (not for a keyboard): it was surprising how solid it felt!  I think our perceptions of aluminum are warped (bah-dum-dum) by experiencing it in very thin, fragile applications.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #86 on: Fri, 22 February 2013, 16:18:32 »
I talked to a lab professor today about my design. He said it looks pretty easy to make except for the stainless steel weight plate. He said it may work harden when milling making it very hard and expensive to do. He even called a steel place. A 1/8" x 2 1/2" bar stock in stainless is $3.94 per foot, plain carbon was $0.84 per foot and would machine a lot better.
I'll ask about both, but I might end up doing painted steel for the weight plate. The weight I'd lose is minimal for the amount of machinability that I'd gain
« Reply #87 on: Fri, 22 February 2013, 16:43:46 »
I thought we had talked about using brass?
Offline SmallFry
« Reply #88 on: Fri, 22 February 2013, 16:46:39 »
Brass is more dense, no?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #89 on: Fri, 22 February 2013, 18:00:05 »
Brass is super expensive. 1/8" x 2 1/2" stock was $23 per foot, stainless was $3.94 and mild steel was $0.84 per foot with those same dimensions for bar stock by the foot. (only looked for brass at one company, but we're sure it would still be really expensive)
Out of the three, steel milled the easiest followed by brass and then the stainless. However brass and stainless were pretty close in terms of toughness to machine.
Brass may be slightly more dense, but it's only going to be a couple of grams in the grand scheme of things
« Reply #90 on: Fri, 22 February 2013, 18:06:11 »
Steel it is!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #91 on: Fri, 22 February 2013, 18:09:18 »
Steel it is!
I'm still going to ask about stainless steel and see how much it would be. But from what my friend was telling me, I'm not getting my hopes up too high
« Reply #92 on: Fri, 22 February 2013, 18:16:52 »
I think you were right with your first pass. A piece of thick stainless is probably too expensive. I think you're right with steel. Plus you won't even get to see it that often.
Offline SmallFry
« Reply #93 on: Fri, 22 February 2013, 21:49:31 »
Ah, I didn't realize brass was so expensive. My bad.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #94 on: Fri, 22 February 2013, 22:00:40 »
Yea, that's what my friend said.
I didn't either, still thanks for the input :D
Offline Hubbert
« Reply #95 on: Sat, 23 February 2013, 17:19:24 »
I wanted stainless for density, conductivity, and corrosion resistance.  Regular steel takes care of the first two*: would a plating of stainless over regular steel be practical?
*EDIT: Unless the surface is painted.
« Last Edit: Sat, 23 February 2013, 17:21:53 by Hubbert »
« Reply #96 on: Sat, 23 February 2013, 17:25:46 »
Stainless and steel together might lead to galvanic corrosion.
Offline salmo
    • messmore.org
« Reply #97 on: Sat, 23 February 2013, 20:18:16 »
Are you worried about spills?  Because I would think it would just develop a "patina" over time, being in the middle of the board.  And it shouldn't be externally visible, right?
Please correct me if I'm wrong here, I'm learning a lot reading this thread already.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #98 on: Sat, 23 February 2013, 20:31:38 »
The steel wouldn't be the one that would be most hurt, it would be the aluminum since it's the anode.
« Reply #99 on: Sat, 23 February 2013, 20:44:03 »
I'm not sure what the weather is like in Memphis but I know Cincinnati gets really humid in the summer. I don't know exactly what the environment needs to be for the corrosion to happen but I'd really rather just avoid the situation entirely. The_Beast and I had the same discussion concerning the feet on his case.
« Last Edit: Sat, 23 February 2013, 21:10:32 by CPTBadAss »
