Author Topic: [IC] Phoenix Wright : Ace Attorney's OBJECTION enter keys.  (Read 13169 times)
Offline takaki
« on: Thu, 31 January 2013, 13:06:05 »
Hi there,
This has always been something that I've wanted to do. I am a huge fan of Phoenix Wright Ace Attorney and I've always wanted to have a OBJECTION enter key.
I've contacted Melissa at SP and she said that this can be done, and I guess the only way to achieve this is to use the dyesub method to get the print onto the cap.
I hope to have a gauge of the number of people who will be interested in this so everyone can have one. :p
I'm thinking of just making it on a standard 2.25x Row 3 enter keycap
Imagine the sound that goes off in your head every time you hit the enter key
The print that will be going on the key
Your honest feedback will be most welcomed.
I hope we can get a GB going on this!
« Last Edit: Thu, 31 January 2013, 14:44:51 by takaki »
Offline jeroplane
Re: [IC] Phoenix Wright : Ace Attorney's OBJECTION enter keys.
« Reply #1 on: Thu, 31 January 2013, 18:37:45 »
Try also contacting imsto to see what he can do. His dye-sub seems to be much more precise than SP's process, but that doesn't mean SP won't be able to do it either.
My signature hasn't changed since 2012. I should really update it.
Offline takaki
« Reply #2 on: Fri, 01 February 2013, 00:33:17 »
I think that would mean contacting KBC, I sometimes hope I don't have to contact them again :/
Offline YMSNoms
« Reply #3 on: Mon, 04 February 2013, 03:59:46 »
I'd like on of these :) I think Dye-subbed would look cool on a white key.
Leopold FC700R
Filco Majestouch-2 Multicamo
Korean FR4-87 Lambo Orange Custom
« Reply #4 on: Mon, 04 February 2013, 11:25:12 »
I would love to see this on an RA set  :))
