Author Topic: Ducky 108 White PBT key caps set?  (Read 5363 times)
Offline Rafen
« on: Thu, 31 January 2013, 16:01:12 »
I was wondering if any one knows where I can get a white PBT set to go on the Ducky 9008 G2? It has 108 keys and most of the sets I have seen are only 104. I looked on mechanicalkeyboards.com and he lists them as 108 but they are only 104 with 2 blue key caps. I would like to get a white set with the shortcut keys that located on the top right. Thanks for your help.
Offline Rafen
Re: Ducky 108 White PBT key caps set?
« Reply #2 on: Thu, 31 January 2013, 17:22:17 »
Yeah I seen those, but as I stated in the original post they don't have 108 even though they say they do. I counted them in the picture.
According to Ducky the only ones that have the shortcut keys are the ones that have the lights on the caps lock and number lock keys.
« Reply #3 on: Thu, 31 January 2013, 20:33:00 »
Strange.
The four that are missing are the repeat rate/calculator etc. keys in the top right corner.
Worst case you could replace those with blank white keycaps, or some custom legend ones from WASD (probably not PBT though).
Offline Rafen
« Reply #4 on: Thu, 31 January 2013, 20:52:20 »
Yeah thats what I am going to do if I cant find a set. I emailed Ducky to find out for sure.
