Author Topic: Replacement Keycap for a Poker  (Read 3196 times)
Offline Cobertt
    • Control on Caps
« on: Thu, 31 January 2013, 17:29:42 »
I am missing the 6 keycap from my kbc poker. Any idea where to get one? When I took all my keys off my "throw up" board I must have misplaced the 6 key. Any ideas on what I can do? I am in Midwest USA by the way.
HHKB Pro2 | Mira SE | FJELL | KARA HAZE | CW88 FNF WKL Wine | HHKB Prophet | Al.6 | Tengu | Prototype CW60 HHKB Skunkworxxx | Prototype K80 | Tokyo60 | Gingko65 |  Midway LE |  Kei | Frog TKL | Saturn60 | NRD Kaze | Panda Korn | Iron 165 FE | Caerdroia | Safa TKL
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: Replacement Keycap for a Poker
« Reply #1 on: Thu, 31 January 2013, 18:15:32 »
It won't be a perfect match, but your best bet is probably to get a replacement key from WASD Keyboard. They sell single key caps in the same profile as what's on your Poker.
Hope that helps!
Offline Cobertt
    • Control on Caps
« Reply #2 on: Thu, 31 January 2013, 18:49:52 »
I don't think that they do the side printing for the F6, do they?
Offline mashby
    • Mashby
« Reply #3 on: Thu, 31 January 2013, 19:00:34 »
I don't believe they offer side printing, no.
Offline laffindude
Offline mashby
    • Mashby
« Reply #5 on: Sat, 02 February 2013, 08:24:43 »
Corbett,
The link that laffindude just posted is for a complete set of Poker key caps in ABS. There's a member here called IMSTO who is a broker for Taobao and you can contact him directly should you want them. According to Google, 50 Yuan is roughly $8. That's pretty cheap if that's correct.
You can contact IMSTO directly via PM, or post a thread in his vendor sub-form here on GeekHack as well.
Hope that helps!
