Author Topic: Greetings from Manhattan -- "new" Model M  (Read 4072 times)
Offline QuidNYC
« on: Thu, 31 January 2013, 21:31:50 »
Although I recall owning a Model M back in the days of Windows 3.1, I have only recently come to understand and appreciate how much better they were than the commonly manufactured keyboards of today.  This message board is likewise new to me -- despite having read a fair bit in recent weeks, I feel as though I have quite a lot of catching up to do.
I'm going to try to attach pictures of my new setup, a Model M (1391401; produced in 1989) obtained on ebay a couple of weeks ago.  I have cleaned it up thoroughly, replaced all of the keys with a black unprinted set from Unicomp, and connected it to my home computer with an SDL to USB adapter cable (the black LED overlay is also from Unicomp).
I liked it enough that I've gone ahead and replicated the setup exactly (with a 1991 board from ebay) in the office.  It's turned more than a few heads from passersby (thankfully with our office setup I don't believe the noise will be an issue).
One question for the Model M experts here:  it seems the keyboard I use in the office was used a bit harder than my other one, and it seems there are at least a few keys that have a somewhat softer response than the others (even after reseating the plastic key several times).  Is there an easy remedy for this?  Should I consider trying to replace those buckling springs?
Re: Greetings from Manhattan -- "new" Model M
« Reply #1 on: Thu, 31 January 2013, 22:09:09 »
Welcome to Geekhack!
A lot of Model M enthusiasts joining lately, surely one of them will know about the variable spring strength.
Offline daerid
    • Rossipedia
« Reply #2 on: Fri, 01 February 2013, 03:29:31 »
That is a mighty fine looking board you got there.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #3 on: Fri, 01 February 2013, 03:52:34 »
some keys on my ssk also have a softer feel then the others. I think replacing the springs should help. You could swap the spring from a less used key like the F-keys to the one that feels soft.
there is an easy method to swap single springs: http://geekhack.org/index.php?topic=5265.msg77401#msg77401
Another problem could be that your board has a lot of broken rivets. If this is the case, some keys have a different feel than others or completly stop working. Then you have to do a bolt-mod... http://wiki.geekhack.org/index.php?title=Modifications:IBM_Model_M:Nut_and_Bolt_Mod
« Reply #4 on: Fri, 01 February 2013, 04:08:53 »
^ told you :p
Offline QuidNYC
« Reply #5 on: Fri, 01 February 2013, 07:15:32 »
Many thanks, snoopy!
Offline wolfofsin
« Reply #6 on: Fri, 01 February 2013, 09:27:28 »
Welcome QuidNYC. Manhattan born and raised here
Offline QuidNYC
« Reply #7 on: Fri, 01 February 2013, 13:38:19 »
A picture of Model M #2 in the office...
Offline snoopy
  • The Flying Ace
« Reply #8 on: Fri, 01 February 2013, 13:48:19 »
wow, an exact replica :)
If you fell in sleep in front of your keyboard.... after you wake up again, you don't know where you are... :D Work? Home? Where am I?
Offline QuidNYC
« Reply #9 on: Fri, 01 February 2013, 13:55:40 »
 :)  I suppose I could have taken advantage of the detachable cable to carry it back and forth to the office... but it's a tad heavy for a twice daily commute, and I think I'd get some weird looks on the subway.
Of course, the upside is that it would make a highly effective and street-legal self defense weapon!
Offline snoopy
  • The Flying Ace
« Reply #10 on: Fri, 01 February 2013, 14:04:30 »
a red esc-key and switching the led color to red would be cool
Offline QuidNYC
« Reply #11 on: Fri, 01 February 2013, 14:19:46 »
Hmm... I think you may be on to something there (at least for my "home" version).  I'm going to have to research replacing the LEDs though, as I'm not really sure how to go about it.
Offline QuidNYC
« Reply #12 on: Thu, 07 February 2013, 08:54:29 »
Pic of new escape key... not sure yet how much I like it.  Will have to see if it grows on me...
