Author Topic: [IC] Keycap and Switch Try Tour  (Read 25726 times)
Offline Lastpilot
  • Power stance
Re: [IC] Keycap Test Tour
« Reply #50 on: Thu, 09 May 2013, 08:32:31 »
Confirmed. My White Blank Thick Imsto PBT + Stock Poker Thin ABS will be included in this tour. Enjoy!  :]
« Reply #51 on: Thu, 09 May 2013, 08:33:19 »
Looking for thin PBT, thick ABS (Cherry DS) and POM caps. Lastpilot is a champ, thanks man!  :-*
Offline Lastpilot
  • Power stance
« Reply #52 on: Thu, 09 May 2013, 15:03:20 »
By the way it looks like mashby's list incorporates imsto caps as OEM profile? These should be cherry profile IIRC.
Offline vivalarevolución
« Reply #53 on: Fri, 10 May 2013, 13:26:42 »
I've got an SP DSA thin PBT from those keys on my Kinesis Advantage I could include.  Also I have one of those Alps-mount top hat keys from my Apple IIGS (not sure on plastic type) and some Alps doubleshot if that helps.
Offline keymaster
  • Topre Revolution Theorist
« Reply #54 on: Fri, 10 May 2013, 13:34:53 »
If there's interest, I can volunteer my blue imsto PBT numpad keycaps for the cause. They've been sitting in a box since I got them.
« Reply #55 on: Fri, 10 May 2013, 13:52:25 »
Forgot what I have coming from Mashby and I'm at work. I'll update this in a bit.
Edit: I've got the following coming in.
White Blank Thick PBT: Escape Row
Poker Stock Thin ABS: Number Row
Thin PBT (white laser etched Vortex): QWER Row
Cherry Double Shots: ASDF Row
I have four of each and it's going to go on:
A Tipro 4x8 numberpad.  Plate Mounted Blacks.
The bottom row will also have relegendables, a zinc cap, and a Wario doubleshot PBT cap.
A proper thread will go up once I receive all the caps.
« Last Edit: Sat, 11 May 2013, 22:58:21 by CPTBadAss »
Offline Dubsgalore
Re: [IC] Keycap and Switch Try Tour
« Reply #56 on: Sun, 12 May 2013, 11:20:34 »
I'm excited for this CPT!
looking great so far
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #57 on: Mon, 13 May 2013, 08:29:59 »
Had a working weekend, so I didn't get the caps out to you yet. I should be able to get them out by Tuesday.
« Reply #58 on: Thu, 16 May 2013, 22:34:31 »
Got your caps in today. Thank you!
And please, if anyone has POM caps to donate, please PM me. This tour is so close to getting underway, help a brother out! :D
Offline ndlu2
« Reply #59 on: Sun, 19 May 2013, 12:19:35 »
I'd like to join on this. I wouldn't mind paying a deposit since I'm new.
« Reply #60 on: Sun, 19 May 2013, 13:12:49 »
Unfortunately, the tour rules are going to be setup like Akimbo's Model F tour. I'm going to require a set amount of posts and then make personal judgement calls.
« Reply #61 on: Sun, 19 May 2013, 16:16:40 »
captain would you be interested in arrow cluster in dsa for your tour?
« Reply #62 on: Sun, 19 May 2013, 16:27:46 »
Yes I would be, send me a PM?
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
« Reply #63 on: Tue, 21 May 2013, 22:03:27 »
I am interested. Sign me up CPT!
HHKB Pro 2   SmallFry Keyboard
« Reply #64 on: Sat, 08 June 2013, 11:28:51 »
This tour is now live, I'm locking this thread and referring everyone here.
