Author Topic: Need some metal cut  (Read 2472 times)
Offline Gupgup
Need some metal cut
« on: Sat, 02 February 2013, 15:32:45 »
I remember seeing a post where someone said they had access to the machinery that could cut some metal?
If someone could point me towards that, I'd greatly appreciate it!
I need to take the F row off of a ANSI150 plate, not complex at all!
This is needed because I'm trying to get a plate that will work with my Korean A.87 PCB, an ANSI150 is just a little bit off between
 the number row and F row.. So I just want to cut off the F row and have a usable plate! If someone has another route I could take, that would be welcome also!
« Last Edit: Sun, 03 February 2013, 00:57:52 by Gupgup »
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: Need some metal cut
« Reply #1 on: Sun, 03 February 2013, 12:33:51 »
depending on the material and thickness, careful use of a nibbler, fine-toothed hacksaw, or dremel followed by a fine-cut file is probably the way to go.
dremel also now sells a small rotary saw that looks fairly precise but is about the same size as a traditional dremel.
Offline Gupgup
Need some metal cut
« Reply #2 on: Mon, 04 February 2013, 11:27:09 »
Do you have any links to the materials you have found to be most effective?
