Author Topic: Rosewill keycpas and puller - NewEgg  (Read 4868 times)
Offline uzoc
« on: Mon, 04 February 2013, 11:20:22 »
NewEgg is selling a Rosewill brand: 6 keycaps (red) and keycaps puller for $5 (free s/h).
In case anybody needs it, and for community info: http://www.ebay.com/itm/290849281489?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Offline Hyde
  • White Tofu Extraordinaire
Re: Rosewill keycpas and puller - NewEgg
« Reply #1 on: Mon, 04 February 2013, 11:52:20 »
lol pretty cool but why can't they arrange it in proper order on the display picture.  It throws me off looking at that arrangement lol.
Offline reaper
« Reply #2 on: Mon, 04 February 2013, 12:11:20 »
While that's a good price, I wouldn't recommend buying that keycap puller since it's been reported here several times before that it will scratch your keycaps if you're not careful.  I'd get  the wire ones instead.  Any of these should be fine.
Din Eli
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #3 on: Mon, 04 February 2013, 12:15:39 »
Yep, the wire ones are the way to go.
Offline uzoc
« Reply #4 on: Mon, 04 February 2013, 12:19:16 »
True, specially for us, that mess with the keys so much. With the cheap keycap puller there's a chance of scratching it with insertion/for removal (not much you can do there) but when removing the extracted keycap from the key puller I slide it out (so it won't scratch the key from top/bottom).
Offline uzoc
« Reply #5 on: Mon, 04 February 2013, 12:21:46 »
What's the third keycap puller brand, there? Best place to get them?
Offline reaper
« Reply #6 on: Mon, 04 February 2013, 13:11:06 »
Funny you should ask.  I just did a small review here.   :)   That third one is by KBC.
Din Eli
Offline uzoc
« Reply #7 on: Mon, 04 February 2013, 13:24:38 »
Offline reaper
« Reply #8 on: Mon, 04 February 2013, 13:36:34 »
You're welcome.  :)
Din Eli
