Author Topic: This 'board has white Cherry sliders, and it's cheap  (Read 9448 times)
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #1 on: Mon, 03 December 2007, 17:48:26 »
Well spotted. Are the white ones clicky?
Offline xsphat
  • Enlightened
« Reply #2 on: Mon, 03 December 2007, 17:49:23 »
No, they are tactile though.
« Reply #3 on: Mon, 03 December 2007, 17:59:22 »
So are they the same as the brown ones then?
Offline Nonmouse
« Reply #4 on: Mon, 03 December 2007, 18:18:16 »
Quote from: Whiskey in the Jar-o
Nope.  They're the "semi-mechanical" ones- a membrane with a spring over it.  Keyboards with the MX switches will start with G80, and ML-switched boards will start with G84.
There is a G80-1800 keyboard that looks the same, but has the MX switches.
Offline Bluemercury
« Reply #5 on: Mon, 03 December 2007, 18:54:05 »
How are the ML- Switches? are they clicky? i just found a store here in Portugal that seems to have some Cherry keyboards, they have the G84-4100, they say it has MX switches but at the european cherry site they say ML switches.....
Collection:
Das Keyboard II
Model M5-2
Model M5-1(considering selling this one)
Cherry G80-3000LCMPO with black switches
Cherry G80-5000HAMPO (Brown switches)
McAlly96
HHKP2 BNx2
« Reply #6 on: Mon, 03 December 2007, 19:07:51 »
Quote from: Nonmouse
Well done!  I can't believe I didn't spot the G81 in the model number. Wishful thinking, I guess. This one should have linear feel.
« Reply #7 on: Mon, 03 December 2007, 19:10:16 »
Quote from: Bluemercury
They don't click.
Offline xsphat
  • Enlightened
« Reply #8 on: Tue, 04 December 2007, 15:06:56 »
So what switches so the G80 American keyboards have? and are the "MX gold crosspoint" switches the blue sliders?
Offline mr_sf_applet
« Reply #9 on: Tue, 04 December 2007, 15:14:00 »
Quote from: xsphat
Not necessarily. The Deck keyboards brag about their Cherry MX gold crosspoint switches, and we all know they're black linear.
Offline elmomax
« Reply #10 on: Tue, 04 December 2007, 19:48:38 »
How does this keyboard compare with black alps.... not sure I understand what is meant by a semi-mechanical board.
Can anyone help on this? Thanks
« Reply #11 on: Tue, 04 December 2007, 20:12:10 »
It should be similar to the Cherry MX linear mechanical switches. Long linear travel, no click. You are supposed to type on faith i.e. not expect a "break-through" feeling in your fingers, but just press and go.
Offline Nonmouse
« Reply #12 on: Tue, 04 December 2007, 21:01:27 »
This site has pictures of a G81-1800 keyboard that's been disassembled.  The babelfish translation from Japanese lets you get some idea of what he's talking about.  The actual switch is a membrane-contact sheet, but each has a mechanical key-return sitting on top of it, so it's got  more tactile feel than a cheap membrane keyboard, but not as much as a keyboard with individual switches.
Offline xsphat
  • Enlightened
« Reply #13 on: Tue, 04 December 2007, 21:18:30 »
You know, I give up on Cherry. It seems like they handed out a secret decoder ring to get through all the marketing ploys and I didn't get mine.
Offline Nonmouse
« Reply #14 on: Tue, 04 December 2007, 21:39:43 »
Quote from: xsphat
Just stick with G80- or G84- boards- the G80 have MX switches, and the G84 have ML switches.  I haven't been able to figure out how to tell if they're white, blue, black or brown sliders, though, short of popping a keycap off.  I think it varies by market (i.e., gringos don't like clicky keyboards, do the blues aren't sold here anymore)
Offline Bluemercury
« Reply #15 on: Tue, 04 December 2007, 21:44:23 »
Quote from: xsphat
Yeah its stupid that they dont specify which switches are in the keyboards.....
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
« Reply #16 on: Tue, 04 December 2007, 22:23:01 »
A few weeks ago I downloaded a PDF product data sheet for the Cherry G80-3000 series keyboards, and it had the following info:
Order description
Order number             Colour        Connection             Key action
G80-3000LPMxx-0     light grey         PS/2                     linear
G80-3000LQMxx-0     light grey         PS/2                     soft
G80-3000LSMxx-0     light grey         PS/2                     click
G80-3000LUNxx-0     light grey         USB                      linear
So I looked all over the web to see if there was any place where I could order a G80-3000LSMUS-0. Couldn't find any. Still amazes me that it is so difficult in the US to find a keyboard, whether full size or compact, with blue Cherry MX switches (except for the two we already know about).
« Reply #17 on: Wed, 05 December 2007, 00:25:06 »
Offline xsphat
  • Enlightened
« Reply #18 on: Wed, 05 December 2007, 00:29:01 »
What is the difference between US and European layouts? Do they work with American stuff?
Offline xyzzy
« Reply #19 on: Wed, 05 December 2007, 04:44:28 »
Quote from: xsphat
Typically, EU keyboards have 1 more key than US ones. So they're 102 keys (vs 101 US) for the standard AT layout and 105 keys (vs 104) for the enhanced layout with Windows keys.
The result is that you normally have a smaller left-shift to make space for the additional key. See this page on Wikipedia for the details of the most common European layouts.
If you don't mind to having a smaller left-shift key (and to the different marking on the keys in case you don't get one with blank key tops), you can use an European keyboard and set it to US layout from the O.S., with no additional complications.
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
