Author Topic: What's the proper way to store away a keyboard  (Read 4519 times)
Offline fkeidjn
« on: Tue, 04 December 2007, 00:11:12 »
Like the subject says, is there a good way to store away a keyboard so I can use it when one fails out on me?  What factors should I consider?  I know moisture is an issue for keyboards with metal plates (rust), which can be resolved with desiccant (I think).  Anything else?
Kinesis Keypad - Filco FKBN104M/EB - Unitek space-saver - Acer 6511-TW - Apple Extended II (M3501) - Scorpius M10 - Cherry G80-1800, AT - SGI Granite - vintage Fujitsu - IBM Model M, 101 and mini - Model F, 84-key AT - Dell AT101W - Northgate 101
« Reply #1 on: Tue, 04 December 2007, 01:18:26 »
The box it came in?
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #2 on: Tue, 04 December 2007, 01:21:35 »
Good question. I worry most about the switches. I keep mine in a cardboard box with cardboard separators, but this is most likely not the best way and it is not optimal for longterm storage.
What do you people do?
Offline iMav
  • geekhack creator/founder
« Reply #3 on: Tue, 04 December 2007, 06:53:25 »
I do nothing special.  Just leave them in the box they came in (if I have it), and then store them away in a trunk.
