Author Topic: M-60: A 60% Buckling Spring Keyboard (Like a tiny Model M)  (Read 74412 times)
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: M-60: A 60% Buckling Spring Keyboard (Like a tiny Model M)
« Reply #50 on: Mon, 11 March 2013, 14:48:05 »
Thanks.  Here it is in its life-support cradle...
 - Ron | samwisekoi
Offline duq
  • Connoisseur
« Reply #51 on: Mon, 11 March 2013, 14:54:48 »
This is quite awesome.
« Reply #52 on: Mon, 11 March 2013, 15:55:49 »
D'awww, it's so cute!
Offline Viz
« Reply #53 on: Mon, 11 March 2013, 19:00:59 »
My god, thanks sam.
I'm broke, but I won't let go of my SSK(yet). Now, this looks even better than my SSK, so maybe i'll get my dream board, and some extra cash? heheh.
Anyways, thanks!
Offline E TwentyNine
    • Some of My Keyboards
« Reply #54 on: Sun, 17 March 2013, 14:43:47 »
Current plan is a Unicomp PS/2 controller to a Soarer and USB out.
Unicomp controller is curently unhappy with the cut-down chassis, and I have been tied up with Retro DSA. The prototype M-60 is sitting on my desk glowering at me.
 - Ron I samwisekoi
Can I ask why you didn't start the project with a Unicomp USB keyboard?
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #55 on: Sun, 17 March 2013, 14:53:08 »
 - Ron I samwisekoi
Sure.
I am remapping some of the keys and adding a function layer. That means I need to capture the scancodes and convert them before I send them to the PC. The easiest way to do this is by using the Soarer PS/2-to-USB converter, which is specifically optimized for remapping IBM keyboards. There is no simple equivalent for USB-to-USB conversion.
 - Ron I samwisekoi
Offline wcass
« Reply #56 on: Sun, 17 March 2013, 15:30:40 »
i look at it differently. samwisekoi is stirring interest and attempting to resolve some of the many challenges using known working methods.
problem: some keys need to be reassigned. known to work solution: teensy with Soarer's
problem: smaller membrane. known to work solution: folded membrane.
problem: smaller case. known to work solution: cut and glue existing case.
both successes and failures help the community by identifying problems and the effectiveness of various solutions.
Offline r3dx
« Reply #57 on: Sun, 17 March 2013, 15:42:55 »
very inspiring samwisekoi. I can't wait to see the final product. I'm also very intrigued about the possibility of making my own in the future :D
Filco MJ2 Ninja | CM Storm QFR | CM Storm QFR | IBM Model M | IBM Model M SSK | ErgoDox |
LZ-GH
Offline OrangeJewce
  • ssk.ℜ
  • King of the Jewce
« Reply #58 on: Sun, 17 March 2013, 17:06:49 »
Case is one of, if not the, greatest challenge for any new BS board IMO. No case has the ability to handle the curved barrels/plate outside of originals and you can see how that problem has affected the SSKR project as well. That leaves destroying vintage cases for the cause, which I'm sure most would rather not do.
Cheers,
IBM Model M 1390120, Otaku Unicomp+RGB, CM QFR Green, Ducky YOTD Red, SSK MKII,
ErgoDox Blue, ErgoDox White
Offline wcass
« Reply #59 on: Sun, 17 March 2013, 17:35:40 »
agreed. i am a bit of a tinkerer too and am trying to address some of these problem issues. the controller issue is essentially resolved. it can be replaced by an Atmel IC just as has been done with many custom keyboards. Hasu has agreed to help me with this do this. the membranes - i'm working on that now in another thread. if the plan works as expected then NKRO.
and i have a few ideas for a case, but am trying to keep focused on the membrane issue until that is proven.
Offline OrangeJewce
  • ssk.ℜ
  • King of the Jewce
« Reply #60 on: Sun, 17 March 2013, 19:13:59 »
Manufacturing membranes is also a challenge. So is getting real 60% barrel plates made. Jury-rigging one from a unicomp 101 is a little silly imo.
Cheers,
Offline Plater
« Reply #61 on: Mon, 25 March 2013, 12:44:54 »
Please make this a GB. I would definitely going buying a bunch!
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #62 on: Mon, 25 March 2013, 13:02:19 »
Cheers,
Yes; this was just for a proof-of-concept.
 - Ron | samwisekoi
Offline JWK
« Reply #63 on: Tue, 26 March 2013, 08:58:31 »
To connect to a cut-down full size membrane, it would be relatively easy to fabricate a very thin piece of circuit board material and use the barrel plate and back plate to clamp it in place -- to make a pressure-fit connection to the membrane.  If there was a strip along the top side and right side of the membrane, then traces on the circuit board could connect any membrane traces interupted by the cutting, and bring necessary traces out to a ribbon cable connector.
Have you asked whether perhaps Unicomp would let you use their CAD files as a starting point for a new CAD file?  You might have to agree to license the new CAD file back to them.  And perhaps they would connect you with their vendors to fabricate a run of membranes -- maybe split the tooling cost in exchange for a hundred pieces.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #64 on: Tue, 26 March 2013, 09:27:40 »
To connect to a cut-down full size membrane, it would be relatively easy to fabricate a very thin piece of circuit board material and use the barrel plate and back plate to clamp it in place -- to make a pressure-fit connection to the membrane.  If there was a strip along the top side and right side of the membrane, then traces on the circuit board could connect any membrane traces interrupted by the cutting, and bring necessary traces out to a ribbon cable connector.
If only...
The back and barrel plate don't cover the mylar, there is a sort of "snap-in" pressure connection.  So I have done what you suggest using steel bar stock and 4-40 bolts.  Unfortunately, this only works for the column circuits, not the rows.  The rows are located such that an additional pressure connection is needed, but there is room for a bolt-hole only on one side.  So my latest fix for that is a pair of 1cm x 2cm flat magnets holding the membrane sections together in that location.
Anyhow, I also assumed it would be relatively simple, and in fact have the correct portion of the barrel plate cut out for my first experiment.  It did not provide enough constant pressure to make reliable contact, so I moved on to the complicated method described above.
This project is currently very low on the list for me, so I have not worked on it much recently.  There is also a thread elsewhere on GH describing others' work on a custom membrane.
 - Ron | samwisekoi
Offline phetto
  • HHKB JP
« Reply #65 on: Wed, 10 April 2013, 09:58:25 »
You should complete this, make a list of what's needed to do this yourself and you will become a legend! :D
Offline tipo33
  • "Ski"
« Reply #66 on: Fri, 19 April 2013, 21:33:20 »
This is amazing.  I also would be all over an aluminium case for an M...
KM4COL    R.I.P.  SmallFry
Offline zoolzoo
« Reply #67 on: Sat, 20 April 2013, 10:37:00 »
Post a full work log and / or make a GB!  :eek:
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline NYCesquire
« Reply #68 on: Mon, 22 April 2013, 21:44:12 »
I am also interested in how this progresses.  I just ordered a unicomp 104 key, but I intend to keep it 104 key, make a custom enclosure, and mod in a bluetooth adapter.  I am following this very closely, Samwise. Don't let us down!
WCass: Did you do any additional work on designing an enclosure?  Those sketchup files are a great start!
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #69 on: Sat, 27 April 2013, 10:30:27 »
This project is right where it has been.  On my desk glaring at me every day and waiting for me to finish the GH75 custom build and the Retro DSA shipments.
It shall be done, but it needs some cycles to free up.
 - Ron | samwisekoi
Offline Michael
  • Formerly Bro Caps
« Reply #70 on: Sat, 27 April 2013, 10:31:59 »
I wish I could find the old thread with photos of the one ClickClack did. It was amazing. Had a LED on the capslock, too
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #71 on: Sat, 27 April 2013, 10:35:18 »
Goddammit.  Feature creep!
Now I have to find a Model M windowed capslock!
Offline NYCesquire
« Reply #72 on: Tue, 30 April 2013, 16:00:00 »
Is it possible to backlight keys on a buckling spring?
Offline wcass
« Reply #73 on: Tue, 30 April 2013, 18:50:58 »
my daily driver has an "under key" caps lock LED. i like this better than the "on key" LED.
http://geekhack.org/index.php?topic=21436.0
the picture got stripped out, but i think i have copies around here somewhere.
a flash washes the LED out, so here is a shot without a flash
20501-0
« Last Edit: Tue, 30 April 2013, 19:04:33 by wcass »
Offline NYCesquire
« Reply #74 on: Tue, 30 April 2013, 19:15:24 »
I'd love to see those pics if you do find them!
« Reply #75 on: Tue, 30 April 2013, 19:20:54 »
wcass, you have more pics of that board?  Was thinking of doing something just like that...
Offline wcass
« Reply #76 on: Tue, 30 April 2013, 21:02:00 »
it really is a great board - my current favorite which is why it is my home daily driver.
i'll pull together what i have on it and re-post in "making stuff together"
« Reply #77 on: Thu, 02 May 2013, 09:12:54 »
Apart from all the obvious things, one thing I'm interested in is what you used to paint the case.  I did my hacked SSK and the paint is not holding up well (even with plastic primer), going to redo it.
Offline RougeR
« Reply #78 on: Thu, 02 May 2013, 09:17:14 »
wtf is this...
Buckling spring warrior!
Offline esoomenona
  • Gnillort?
« Reply #79 on: Thu, 02 May 2013, 09:19:04 »
Why, that looks to be an M-75.
« Reply #80 on: Thu, 02 May 2013, 09:26:17 »
wtf is this...
Might be useful to post a little info on where you found that picture.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #81 on: Thu, 02 May 2013, 09:38:11 »
Offline uzoc
« Reply #82 on: Thu, 02 May 2013, 10:06:10 »
wtf is this...
He got it from his computer and then photoshopped it...
Offline iiiGerardoiii
« Reply #83 on: Thu, 02 May 2013, 18:43:00 »
wtf is this...
Where did you got that pic??
That's my old modded model m, i'm not using it right now, i need the numeric keypad so i use the huge one.
Offline esoomenona
  • Gnillort?
« Reply #84 on: Thu, 02 May 2013, 18:50:10 »
Show us more angles, bottom, etc. And how did you mod it?
Offline inteli722
« Reply #85 on: Thu, 02 May 2013, 20:48:46 »
wtf is this...
That thing is awesome.
Waiting for: Phantom Plate
Offline BlueBär
« Reply #86 on: Fri, 03 May 2013, 00:48:46 »
Wait, this thing is real? Want.
I think somebody found it on /g/ and posted it here in a different thread. Amazing mod you did there.
Offline Moosecraft
  • HHKB Pro
« Reply #87 on: Fri, 03 May 2013, 06:29:36 »
Sexiest board ever!
Offline RougeR
« Reply #88 on: Fri, 03 May 2013, 17:50:57 »
wtf is this...
i saw it posted on /g/
inb4 4chan
post up how you did it, seems this thread is very similar in line...how the **** are the joints so near
Offline zoolzoo
« Reply #89 on: Sat, 04 May 2013, 05:12:08 »
wtf is this...
you have a strange thumb
Offline vivalarevolución
« Reply #90 on: Fri, 10 May 2013, 11:16:19 »
Just stumbled in on this project.  A dream board, if there ever was one.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #91 on: Fri, 10 May 2013, 11:17:26 »
I can't wait for this summer. I have a fullsized model M waiting for a weight reductions and maybe even a wood enclosure :D
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #92 on: Fri, 10 May 2013, 11:56:12 »
A model M weight reduction?! :eek:
Why would you do such a thing? How are you going to use it as a weapon when the zombie apocalypse comes?
But in all seriousness, how would you cut out any of the weight? Wood will weigh more than plastic...
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline tipo33
  • "Ski"
« Reply #93 on: Fri, 10 May 2013, 14:21:08 »
Ohhh.  A wooden case M.....   why must you taunt me so??
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #94 on: Mon, 24 June 2013, 08:58:15 »
I can't believe I missed this thread... there're so many interesting things going on on this forum
Offline Moosecraft
  • HHKB Pro
« Reply #95 on: Mon, 24 June 2013, 17:01:23 »
DIY seems to a FOTM among forum members, I quite like it because there are so many unique projects available at all times.
Offline dgreekstallion
  • B.S. Fiend
« Reply #96 on: Fri, 13 September 2013, 18:05:52 »
I'm thinking of getting a wood case for my Model F. :)
Recent keyboard fanatic.
Model F-122 convert.
