Author Topic: help with steelseries 6gv2  (Read 3223 times)
Offline jd4311
« on: Fri, 08 February 2013, 11:52:48 »
I need help finding keys that will replace the oversized enter, is there anywhere that sells just that one blank key cap? or is there a method of replacing it with two keys I can use on wasd keyboards.com?
Offline L4yercake
Re: help with steelseries 6gv2
« Reply #1 on: Fri, 08 February 2013, 12:55:41 »
I believe feng has a couple sets and I've seen some on taobao, although they've always been parts of a 104/107 set.
WASD doesn't have anything that fits the funky Enter key or replaces both as the upper stabilizer is proprietary to SS.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Fri, 08 February 2013, 13:20:10 »
You can use regular ANSI 2.25 enter and make a dummy 1.5 key above to fill the space. It's probably the easiest way to solve the problem unless you want one of those full matching sets like these. Or if you want a doubleshots set there are some older keyboards like Laser that are compatible if you are up for some hunting.
Offline jd4311
« Reply #3 on: Sun, 10 February 2013, 15:40:02 »
so a regular ansi enter key and then i can just add a dumby blank 1.5 key?
so this for enter? - http://www.wasdkeyboards.com/index.php/row-1-size-1x2-25-cherry-mx-keycap.html
I actually just pulled the keys out and it loooks like it would work, but theres a long post that goes into the space above the enter key, if i was to put another key cap in it wouldn't be the right height >< i have no idea why steelseries would make a enter key like this
« Reply #4 on: Sun, 10 February 2013, 17:04:32 »
Right, basically it would involve cutting out the normal stem on the 1.5 key and making a similar post type solution to affix it in place. I remember someone did it before, but we lost a lot of pictures and content some months back and I can't seem to find it now.
Offline jd4311
« Reply #5 on: Sun, 10 February 2013, 23:18:15 »
I could probably get it to work but meh, i don't understand why they couldn't just go with the standard design. I like this keyboard but its like a hastle to find the key cap now, and i dislike where the \ key is.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #6 on: Mon, 11 February 2013, 14:43:09 »
If you contact SteelSeries support, they should be able to get you a new one direct.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline jd4311
« Reply #7 on: Mon, 11 February 2013, 20:10:48 »
i want a blank key ideally :(
