Author Topic: Elitekeyboards replacement keycaps for Realforce  (Read 1863 times)
Offline ValerieV
« on: Sun, 10 February 2013, 09:52:15 »
Could they work with the HHKB as well? I was thinking about the black HHKB and replacing them with the yellow lettering keycaps. Anyone try it? Thanks.
Offline jabar
Re: Elitekeyboards replacement keycaps for Realforce
« Reply #1 on: Sun, 10 February 2013, 10:11:15 »
I think EK is pretty clear on which Realforce sets are compatible with HHKB. If not, I'd be interested in hearing too.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline longweight
  • philanthropist
« Reply #2 on: Sun, 10 February 2013, 10:15:07 »
They do work but you have to use the spare capslock as the short right shift on the HHKB.
Offline ValerieV
« Reply #3 on: Sun, 10 February 2013, 11:57:37 »
Thanks for the reply. That helps out a lot. They make it sound that it can't work with the HHKB but i have used some of the keys from a Real Force on my HHKB and haven't had a problem.
Offline karljs
« Reply #4 on: Sun, 10 February 2013, 14:24:02 »
Is the spacebar the same size on the HHKB as on the 104/87?  For some reason I was assuming it wasn't.
