Author Topic: IBM model m's need help  (Read 1201 times)
Offline koala
« on: Sun, 10 February 2013, 20:26:56 »
I was looking at ibm model m's and i was wondering what is the difference between them if they have a different labels, other than the year manufactured. also  wondering what is the difference between model f's and m's
Re: IBM model m's need help
« Reply #1 on: Sun, 10 February 2013, 20:35:12 »
There is a great deal of disagreement about various Model Ms. Many people believe that the older ones (pre-1989) are best, but there are those who prefer a new Unicomp. The 1391401 is considered the "classic" and just look for a clean tested one at a good price.
I would be inclined to recommend a new Unicomp, since you can get a smaller footprint, black (if you like that) and a native USB cable, in addition to fresh springs and a warranty.
The Model F is a completely different and more ancient beast. They are much rarer and do not come in a standard modern layout. Internally they are far more complex but you have some options when you take one apart.
There are those of us who feel that the F is the pinnacle of buckling spring excellence, but you make many sacrifices, not limited to search time and money, to acquire one.
Start with the Model M, and think long and hard about a Model F before you get involved.
- Oliver Willis 2026-08-01
« Reply #2 on: Sun, 10 February 2013, 20:39:22 »
Offline sleepy916
« Reply #3 on: Mon, 11 February 2013, 00:05:58 »
I've only been using a Model M for a few months, but I love it. The feel is so much more satisfying for me than the Cherry Browns I came from. I just bought a Model F AT so I'm hoping I will like that even more.
