Author Topic: ISO PBT  (Read 2579 times)
Offline gropingmantis
ISO PBT
« on: Tue, 12 February 2013, 16:35:31 »
Specifically blank black ISO PBT keycaps, preferably thick but not 100% necessary.
Does such a thing even exist?
Where would one go about sourcing them either way?
Answers on a postcard or in the thread below please.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: ISO PBT
« Reply #1 on: Tue, 12 February 2013, 16:42:23 »
Thick Cherry profile ISO blanks is not available at this time, but you can get the thinner 'oem' profile by Ducky. You should add your country to your profile as it makes reccomending which etailer a lot easier in some instances.
Re: ISO PBT
« Reply #2 on: Tue, 12 February 2013, 17:05:04 »
Are blank black PBT caps avalilable in ISO?
I'm in the UK, just added to my profile.
Re: ISO PBT
« Reply #3 on: Tue, 12 February 2013, 17:16:36 »
Yes, but verkkokauppa is the only place I can see that have stock that I can find right now. I am not sure if they will ship to you or not though.
Re: ISO PBT
« Reply #4 on: Tue, 12 February 2013, 17:54:15 »
Awesome! Thanks for the tip. Might it be worth sending Ducky Nordic a message to see if they can send them to me?
