Author Topic: ducky keyboard out of stock in mechanical keyboards website  (Read 3455 times)
Offline volatilecoffee
  • Formerly ybnrmalatall
  • I don't feel any certain way.
« on: Thu, 14 February 2013, 14:10:06 »
-redacted
« Last Edit: Tue, 11 January 2022, 23:40:51 by ybnrmalatall »
Linear gang needs to rise up against the tactile hipsters.
Offline regack
Re: ducky keyboard out of stock in mechanical keyboards website
« Reply #1 on: Thu, 14 February 2013, 14:16:46 »
does anyone know when they will restock?
Ducky DK9087 Shine II TKL Purple LED Backlit Mechanical Keyboard (Brown Cherry MX)
is what I am getting.
I want one of those too, but with MX Blues... they've been out of stock for a little while, but recently got a new shipment of the DK9008s, so maybe the TKLs will be next?
Offline jabar
« Reply #2 on: Thu, 14 February 2013, 14:24:36 »
MechanicalKeyboards supposedly clears out Ducky's stock every time they order.
The last batch was mostly full-size DK9008 Shine II boards. Hopefully the next order will have TKL Shines. If you can hold tight more should be arriving sooner than later.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
« Reply #3 on: Thu, 14 February 2013, 14:28:24 »
-redacted
« Last Edit: Tue, 11 January 2022, 23:40:41 by ybnrmalatall »
« Reply #4 on: Thu, 14 February 2013, 14:38:59 »
-redacted
« Last Edit: Tue, 11 January 2022, 23:40:23 by ybnrmalatall »
Offline Yzeets
« Reply #5 on: Thu, 14 February 2013, 15:59:26 »
The only other place is tiger imports and they are out of stock as well, I have a ducky shine II TKL with purple but it has red switches, also the color is more pink than purple
« Reply #6 on: Thu, 14 February 2013, 16:32:37 »
Like a magenta, very smexy. Actual purple LED's are notoriously hard to find.
« Reply #7 on: Fri, 15 February 2013, 00:21:29 »
Magenta sounds nooice
