Author Topic: IBM Model M '95 Question  (Read 2753 times)
Offline newbrict
« on: Thu, 14 February 2013, 15:33:29 »
Hey so I recently became the new owner of an IBM Model M from 1995.
The issue is that the keyboard has a "8P5C (RJ-45)" out and I cannot use this.
Can anyone point me in the right direction to convert this to a ps/2 or USB out
whichever would be easier.
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
Re: IBM Model M '95 Question
« Reply #1 on: Thu, 14 February 2013, 15:57:08 »
I believe Soarer's converter might be able to help, if you're willing to get your hands a little dirty. http://geekhack.org/index.php?topic=17458.0
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Offline newbrict
« Reply #2 on: Thu, 14 February 2013, 17:01:56 »
Hey thanks for the reply, I actually saw this earlier and was considering it. I guess that's the best way to go unless I could just rewire the connections to a ps/2 without having to modify the actual keyboard, only the cable
Offline x2o
    • x2o.me
« Reply #3 on: Thu, 14 February 2013, 20:58:17 »
I think the problem is most Terminal Model M's with the RJ45 connector send their output in Mode 3, which is why Soarer's converter is usually needed.
What's the P/N ?
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #4 on: Fri, 15 February 2013, 02:33:36 »
You can come close to it. But you need a donor board to provide the PS/2 Set2 controller. A circa '95 3151 uses the same matrix as an M, so you can do a straight controller swap. But, like I said, needs a donor board. (Or a Unicomp controller, that'll also work.)
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline newbrict
« Reply #5 on: Fri, 15 February 2013, 10:02:20 »
I'll get the part number when I get back to my house
Is it possible to use the existing rj45 connect with my computer?
Offline rootwyrm
    • My Website!
« Reply #6 on: Fri, 15 February 2013, 15:23:47 »
or
Nope. Either that or controller swap. It is not a PS/2 keyboard.
Offline newbrict
« Reply #7 on: Sat, 16 February 2013, 02:55:56 »
What's the P/N ?
The part number is 1392595
Offline mich
« Reply #8 on: Sat, 16 February 2013, 06:34:06 »
or
Most likely it is a PS/2 keyboard and will work on PS/2 after cable swap.
There is a wiki article showing how to wire a PS/2 cable to these keyboards and linking to modified Windows driver which supports them.
Using them in Linux currently requires kernel recompilation with simple patch I've posted somewhere on this forum.
