Author Topic: Help me decide on keycaps for my painted QFR  (Read 4797 times)
Offline lukelev07
« on: Sat, 16 February 2013, 21:35:07 »
So I recently painted my Cooler Master Quickfire Rapid with blues, and I need an opinion on which keys I should buy. I want to keep the cost below $60, and I want white keycaps (unless I find something else to match the color I painted it  ;D
Here is what I have found so far...
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=140
and
http://www.ebay.com/itm/KBC-White-Printed-PBT-Cherry-MX-Key-Caps-104-keys-included-/330757195528?pt=PCA_Mice_Trackballs&hash=item4d02aa4708
Of these two, which should I go for? ALso, any other suggestionos I am open to  :)
I painted with a krylon fusion blue, but I sanded with 100, then 400 grit paper beforehand... I have not touched the board for a week tolet the paint "cure"....pics are below...
Offline calavera
Re: Help me decide on keycaps for my painted QFR
« Reply #1 on: Sat, 16 February 2013, 22:04:18 »
Of the two I'd go with the latter. I never was a big fan of ducky products or printed key caps.
How about you mix & match these alphas and keep the stock QFR black modifiers:
http://www.ebay.com/itm/KBC-Blue-PBT-Top-Printed-37-Keyset-for-Cherry-MX-Keyboards-/230839614759?pt=PCA_Mice_Trackballs&hash=item35bf1cfd27
Of course, if you were to up your budget to a $100 you have some awesome choices:
Vorex thick dye subs:
http://www.ebay.com/itm/KBC-Blue-Dyesub-Thick-PBT-Cherry-MX-Key-Caps-105-keys-included-/330758846871?pt=PCA_Mice_Trackballs&hash=item4d02c37997
Cherry beige /w Blue double shots:
http://geekhack.org/index.php?topic=40253.0
« Last Edit: Sat, 16 February 2013, 22:07:14 by calavera »
Offline lukelev07
« Reply #2 on: Sat, 16 February 2013, 22:23:12 »
Noooo stop showing me these amazing keycaps that cost the same as a new keyboard ;)
I might just go with your recommendation, but are PBT's the way to go? and just forget about a custom set from WASD?
Offline lukelev07
« Reply #3 on: Sun, 17 February 2013, 00:48:05 »
halppp please... I am about to go with fengs ebay ones, unless I can get some better ones with possible blue font
Offline calavera
« Reply #4 on: Sun, 17 February 2013, 03:21:19 »
ducky's coming out with dye subs soon, no ETA but I would wait it out.
Offline Reomero
  • Manual breather
« Reply #5 on: Sun, 17 February 2013, 04:27:58 »
Maybe some of the sets this guy is selling could interest you. http://geekhack.org/index.php?topic=38927.0
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Sun, 17 February 2013, 10:34:28 »
Maybe some Cherry style blue on white dyesub PBT. You may ask imsto if they have some sets of them left...
Offline lukelev07
« Reply #7 on: Sun, 17 February 2013, 13:38:55 »
^Those would be perfect :PPP
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« Reply #8 on: Tue, 19 February 2013, 13:16:18 »
I second these.
Offline kboardvintage
« Reply #9 on: Tue, 19 February 2013, 13:23:08 »
I second these.
+2
Offline tauburn
« Reply #10 on: Tue, 19 February 2013, 13:31:00 »
hmm this makes me want to do this to my qfr. i hate the "not quite black"-black the rubber coating gives it. i'm interested to see how well your paint job holds up.
Offline lukelev07
« Reply #11 on: Tue, 19 February 2013, 18:44:11 »
So far so good, it has been a week since the painting so I am using it again and it looks amazing with the black keys...I can only imagine what it will look like with white ones...
Here it is in all its glory!
Apologies for they poorly-painted windows key, I was experimenting with clear coat.
