Author Topic: small(er) keyboard with MX clears?  (Read 2300 times)
Offline lost eden
« on: Tue, 19 February 2013, 08:19:16 »
I was lucky enough to come across a Cherry G80-3000 with MX clears a few months ago, which I have been using at home ever since. I'd used a G80-3000 with MX blues at home for 3-4 years previously & a Compaq MX-11800 with MX browns at work for about a year.
I would like to replace my Compaq at work with another MX clear board & am considering going for a tenkeyless or smaller board. What are my options? The KBT Race looks neat, but doesn't seem to be available with clears :( I'm an ISO user, but am open to the idea of switching to ANSI as there seems to be so much more choice of boards that way...
Offline CeeSA
Re: small(er) keyboard with MX clears?
« Reply #1 on: Tue, 19 February 2013, 08:25:37 »
Small boards with ISO Layout are hard to find. Maybe you could be happy with a G80-1800? It's smaller than a 3000 but it's not tenkeyless. But very cheap and easy to mod.
Offline SmallFry
« Reply #2 on: Tue, 19 February 2013, 09:53:45 »
You could also look into the DIY avenues of the Phantom and GH60.
Offline lost eden
« Reply #3 on: Tue, 19 February 2013, 12:39:07 »
This might be an obvious question, but can one actually buy a bunch of new MX clear switches to solder onto a DIY PCB like the Phantom, or do you have to find a 'donor' board to unsolder them from?
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #4 on: Tue, 19 February 2013, 12:40:42 »
Anything smaller than fullsize is currently either custom, modded or a special limited edition. I have a TKL with clears from Keycool's Taobao store. If you want ISO, maybe check out the deskthority marketplace for modded boards?
|||My other keyboards :
x
Offline lost eden
« Reply #5 on: Thu, 21 February 2013, 08:41:44 »
Something like this with clears looks promising, but my Chinese isn't good enough to see whether that's actually an option on offer :(
http://item.taobao.com/item.htm?id=13489217832
Offline cyberwave
« Reply #6 on: Thu, 21 February 2013, 09:22:48 »
http://item.taobao.com/item.htm?spm=a230r.1.10.37.tCOggw&id=13514954417
白轴 means 'white shaft' but it's cherry clears no cherry whites :)
Offline jabar
« Reply #7 on: Thu, 21 February 2013, 09:44:17 »
There are a few TG3 BL82 which feature MX Clears. They are a bit of a rarity—most are MX Blacks. The BL82 features the same form factor as the Deck 82 Ice but without the weird font and only 2KRO (which isn't a huge problem).
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline lost eden
« Reply #8 on: Thu, 21 February 2013, 10:10:09 »
If this is true, then I might try to order one of those... Clears in a small keyboard but which still has arrow keys is an absolute winner for me, even if it does mean learning ANSI.
Offline lost eden
« Reply #9 on: Fri, 22 February 2013, 09:04:33 »
So can anybody confirm whether the Keycool 84 is actually available with clears & whether it's a decent board?
