Author Topic: WTS poker with steel plate and steel case  (Read 3013 times)
Offline laden3
  • Trade Count: (0)
« on: Tue, 19 February 2013, 12:21:31 »
I believe it is a prototype made by imsto ( http://www.likeyboard.com/forum.php?mod=viewthread&tid=5840&extra=page%3D6 )  before the aluminum ones are made as 2 screw holes on the far left and far right are not aligned with the PCB, regardless it doesn't affect the flexibility and the keyboard is solid.
2 rubber bumpers are missing but replacement shouldn't be too hard to find.
There are no LEDs installed for ease of modifications and the springs in the switches are taken from red switches.
The entire keyboard with keycaps should weigh around 5 lbs.
This should be the only steel case that was made for a poker.
Location is CONUS. Looking for $190 for the case and $100 for the poker. I will let both go for $270. Price is without shipping. Reserved
http://imgur.com/a/KzZ9C
http://imgur.com/a/BvLZs
« Last Edit: Tue, 19 February 2013, 16:13:16 by laden3 »
I rrrove brrracks.
Offline Gupgup
  • Trade Count: (0)
Re: WTS poker with steel plate and steel case
« Reply #1 on: Tue, 19 February 2013, 12:25:55 »
If you'd like I change your mind, I'd like to buy that case by itself!
  • Trade Count: (1)
« Reply #2 on: Tue, 19 February 2013, 12:44:24 »
I can't find a price in your OP. :(
Offline Jocelyn
  • Trade Count: (0)
  • 조셀린
Re: Re: WTS poker with steel plate and steel case
« Reply #3 on: Tue, 19 February 2013, 12:56:04 »
I thought that was something sellers didn't have to list on this forum???
Offline laden3
  • Trade Count: (0)
« Reply #4 on: Tue, 19 February 2013, 13:03:03 »
Sorry, forgot to update that.
I rrrove brrracks.
Offline limmy
  • Trade Count: (0)
« Reply #5 on: Tue, 19 February 2013, 13:06:26 »
PCB is attached to the case by 3 screws?
Offline laden3
  • Trade Count: (0)
« Reply #6 on: Tue, 19 February 2013, 13:13:12 »
Yes.
I rrrove brrracks.
Offline laden3
  • Trade Count: (0)
« Reply #7 on: Tue, 19 February 2013, 15:49:50 »
Added more pictures and if you PM me, depends on how much I like you, I will add some extras to sweeten the deal.
I rrrove brrracks.
Offline Tym
  • Trade Count: (0)
« Reply #8 on: Tue, 19 February 2013, 15:52:45 »
Just wondreing if you can help me? What parts are needed to build a poker? I would buy but i think shipping to the UK would kill it.
