Author Topic: list of plate-mounted switch keyboards?  (Read 2965 times)
Offline wolfv
« on: Wed, 20 February 2013, 13:20:34 »
Is there are list of plate-mounted switch keyboards that are in production or sold as kits?
Thank you.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: list of plate-mounted switch keyboards?
« Reply #1 on: Wed, 20 February 2013, 13:49:15 »
Really it's the majority that is plate mount. It's much simpler to list the PCB mount for you to avoid then.
So here is a list of PCB mount boards you are not looking for that have no plate stock (though aftermarket plate is available for some):
Cherry G80 line, Vortex/KBC/KBT Poker/Pure/Race, Plum 96, Neo Zelia.
Pretty much anything else you will find has a plate.
Offline TotalChaos
  • Indy Game Coder
« Reply #2 on: Wed, 20 February 2013, 14:38:54 »
I am interested in a list of PCB mounted keyboards that have all their keys.
I am guessing only the Cherry G80 has all its keys?  And the rest are mini keyboards?  (if anyone happens to know off-hand?)
I want to own a PCB mounted keyboard or 3 but I never did find one good enough for me so I just gave up on it and forgot about it, until I saw this msg.
« Reply #3 on: Wed, 20 February 2013, 14:41:18 »
Plum 96 have layout similar to CM TK. Neo Zelia is standard tenkeyless.
Offline wolfv
« Reply #4 on: Wed, 20 February 2013, 14:44:31 »
Thanks  IvanIvanovich.  That makes the selection process easier.
