Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6009881 times)
Offline esoomenona
  • Gnillort?
« Reply #1300 on: Mon, 06 May 2013, 10:10:59 »
what do you guys think?  Put the HD activity LED or the PC power LED behind the ESC key on my Das?
What's the purpose of either? Also, why not both?
« Reply #1301 on: Mon, 06 May 2013, 10:11:19 »
I think the HD activity would be amazing on the ESC key. Looking forward to your build log and pictures Melvang!
Offline SmallFry
« Reply #1302 on: Mon, 06 May 2013, 10:11:59 »
That sounds interesting...Let us know how you actually do it.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #1303 on: Mon, 06 May 2013, 10:17:07 »
Because the Ti 3d skull keycap I have on the ESC key has clear eyes for an LED
Have a build log started in the Making Stuff Together section.
http://geekhack.org/index.php?topic=43241.0
Melvang
PS typing on domes after having MX Browns for a couple years FREAKING SUX
Offline The_Beast
  • I like wood ಠ_๏
« Reply #1304 on: Mon, 06 May 2013, 10:18:31 »
Where can i find a Switch Top Remover Tool :)
The_Beast made a run of them and the thread can be found here. I heard a rumor that he'd be doing a R2 but he's super busy between his GH60 case, lube station, and other stuff. If you see this Beast, I'm sorry I spoke for you in advance ^__^
I've also heard that tweezers can work in a pinch.
Y U LINK?
Offline esoomenona
  • Gnillort?
« Reply #1305 on: Mon, 06 May 2013, 10:20:09 »
« Last Edit: Tue, 27 October 2015, 08:40:15 by esoomenona »
« Reply #1306 on: Mon, 06 May 2013, 10:24:24 »
Y U LINK?
Sorry sorry! I can remove it if you're not joking ^__^
Offline Melvang
« Reply #1307 on: Mon, 06 May 2013, 10:24:46 »
Y U LINK?
Also, Melvang, I love that key. Maybe you can fit one LED per eye? Also, I didn't mean to come off as rude. It just seems weird to use either of those two things as an LED indicator. HDD activity is going to happen like ALL the time. Also, if your PC is on, I'm sure you'll know it...
It's all good, just wasn't sure if you had seen the thread.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #1308 on: Mon, 06 May 2013, 10:25:14 »
Y U LINK?
I don't really care. BTW if you're still answering the IC, I'm not looking, I deleted the link to see responses
« Reply #1309 on: Mon, 06 May 2013, 10:31:23 »
Just in case people were wondering: moose won the giveaway with his 1300th reply to this post. Congrats to him and I've updated the giveaway post and the OP!
« Reply #1310 on: Mon, 06 May 2013, 10:33:34 »
Sir, your kindness is only exceeded by your generosity. :D
Offline esoomenona
  • Gnillort?
« Reply #1311 on: Mon, 06 May 2013, 10:33:41 »
« Last Edit: Tue, 27 October 2015, 08:39:51 by esoomenona »
« Reply #1312 on: Mon, 06 May 2013, 10:34:21 »
Thank you to CPTBadAss! I really appreciate it. He may only be an actual Captain, but he was promoted to Major in my book.
You mean he is now MAJBadAss to you?
« Reply #1313 on: Mon, 06 May 2013, 10:35:31 »
Haha, thanks everyone for the kind words :D
JD, as might might know from IRC, I've been given quite a few different nicknames. MAJBadAss might not be so bad compared to CPTSpamAss :P
Offline esoomenona
  • Gnillort?
« Reply #1314 on: Mon, 06 May 2013, 10:36:58 »
« Last Edit: Tue, 27 October 2015, 08:39:39 by esoomenona »
« Reply #1315 on: Mon, 06 May 2013, 10:40:10 »
Offline esoomenona
  • Gnillort?
« Reply #1316 on: Mon, 06 May 2013, 10:43:55 »
« Last Edit: Tue, 27 October 2015, 08:39:21 by esoomenona »
« Reply #1317 on: Mon, 06 May 2013, 10:46:51 »
No worries moose! I'm hoping to do more of these later guys so don't worry. You'll probably get another shot at some goodies :D
Offline Melvang
« Reply #1318 on: Mon, 06 May 2013, 11:30:20 »
Gratz to Moose and to think my question was #1299.
« Reply #1319 on: Mon, 06 May 2013, 11:56:16 »
Next time Melvang!  ;)
Offline linziyi
  • The one with many questions
« Reply #1320 on: Mon, 06 May 2013, 14:20:38 »
What is the cheapest way to try all the switches? Mainly interested in Green, White, Grey, Clear and topre
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline keymaster
  • Topre Revolution Theorist
« Reply #1321 on: Mon, 06 May 2013, 14:21:28 »
Go to a GH meet :)
Offline linziyi
« Reply #1322 on: Mon, 06 May 2013, 14:32:33 »
I live in New York, where is the nearest one I can attend to?
Ducky DK9008G2 Pro
Offline esoomenona
  • Gnillort?
« Reply #1323 on: Mon, 06 May 2013, 14:35:30 »
I've seen bost and MAJBadAss discussing the possibility of one.
« Reply #1324 on: Mon, 06 May 2013, 15:27:49 »
Boost is planning an NYC meet sometime soon. I might be able to attend if its the one weekend I'm in town but we'll see. And I believe you even commented in that thread already. :P
Offline Kayliss
« Reply #1325 on: Mon, 06 May 2013, 16:33:58 »
Could anyone tell me the gauge of wire used for Cherry stabilizers (spacebar)?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1326 on: Mon, 06 May 2013, 16:39:59 »
Approx. 1mm or probably like 18AWG.
« Last Edit: Mon, 06 May 2013, 16:42:22 by IvanIvanovich »
Offline Kayliss
« Reply #1327 on: Mon, 06 May 2013, 16:44:03 »
Offline esoomenona
  • Gnillort?
« Reply #1328 on: Mon, 06 May 2013, 16:54:02 »
Should this work: If a KMAC Number Pad is properly set up with codes for numpad keys, shouldn't I theoretically be able to hold Alt on a Phantom and press the numpad keys to get unicode characters? And if that should work, then that would mean that the numpad was set up with regular number codes, a la the number row?
« Reply #1329 on: Mon, 06 May 2013, 17:02:38 »
Numpad and numbers row have different scan codes. Even when the numpad has correct numpad scan codes, some separate numpad and keyboard combos are still super finicky about letting you enter in unicode. Like when I had my Leopold FC200 and goldtouch numpad I don't remember them playing particularly well together. Though with 2 things that are user programmable, I would guess if both had firmware from the same base, it would probably make them work nicer together.
« Last Edit: Mon, 06 May 2013, 17:06:01 by IvanIvanovich »
Offline esoomenona
  • Gnillort?
« Reply #1330 on: Mon, 06 May 2013, 17:05:24 »
Right. Crap, that really sucks. I suppose one thing I could do to work around is to add an Alt key to the K pad. Time to investigate. Thanks, lysol!
Offline alfa147x
« Reply #1331 on: Mon, 06 May 2013, 17:36:48 »
Where can I find more information on the hid liberator ?
Offline Melvang
« Reply #1332 on: Mon, 06 May 2013, 19:36:33 »
Need suggestions for a keyboard that is going to be a gift.  Going to be getting 2 for my aunt and uncle.  I am not exactly sure what she does but I know that about 2/3 of her keys are now blank just due to the heavy use.  He runs some web server stuff from the house.
I was thinking of getting 2 Days Keyboards one with blues and the other with browns and let them decide who wants which switch.
Any comments/suggestions?
« Reply #1333 on: Mon, 06 May 2013, 19:45:20 »
Check this link for some info. And you can win a Filco w/ an HID Liberator already installed from Glissant. Go check out the giveaway!
If you've got some boards, bring those over to let em try different switches out and see what they like. And then I'd get Ducky because I really think the glossy finish on the Das boards are terrible. Filco might be nice too if you can afford one of those. But Das boards are nice quality, I just have a personal gripe with the finish.
« Reply #1334 on: Mon, 06 May 2013, 19:54:49 »
Consider the KBT Pro at Techkeys.us.  Also be prepared for them to reject mechanical keyboards.  Some people just like their quiet, mushy rubber domes.  :rolleyes:
Offline Rule16
  • R.I.P. SmallFry
« Reply #1335 on: Mon, 06 May 2013, 21:26:01 »
Im looking into full metal filcos... But the only case I found was $300... Are there any for cheaper?
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
« Reply #1336 on: Mon, 06 May 2013, 21:31:04 »
You'll have to spend around $800-1000 for a Full Metal Filco; Full Metal Filco is the name of the board that Tipo33 has. There aren't many metal TKL cases that I know of that are out there. Photekq and Boost will be offering some soon. The last set of metal caps I saw were for sale from longweight and were going for $600. Then you'll probably have to get an HID Liberator and mod the switches to have heavier springs to combat the weight of the caps.
TLDR: If you're worried about just the case being expensive, the rest of the Full Metal board won't be much cheaper.
Offline alfa147x
« Reply #1337 on: Mon, 06 May 2013, 23:25:29 »
Thanks for the link! I PM'ed him. I don't think that controller would work with a MiniLa. I guess my best bet would be to go with a Teensy?
Yeah I saw the giveaway! Too bad I just joined the forum and don't have enough posts :(.
Thanks again!
Alfa
Offline remedyhalopc
« Reply #1338 on: Mon, 06 May 2013, 23:45:54 »
I'm having trouble finding the tabao pictures of the poker 2's backplate. can anyone help me?  :(
Offline WhiteFireDragon
    • youtube
« Reply #1339 on: Mon, 06 May 2013, 23:59:11 »
It's hard to find naked keyboards without caps. I saw a pic of the poker2 with 1 or 2 caps off somewhere, but I can't really tell if it has a plate that allows removable top switch covers. I doubt it though.
Offline esoomenona
  • Gnillort?
« Reply #1340 on: Tue, 07 May 2013, 04:31:18 »
This is what I was thinking of the Poker 2 plate: where did those cheap black Vortex plates come from not too long ago? As far as I knew, Poker X never had a plate. I'm thinking maybe those were Poker 2 plates. In which case, no easy open openings.
    • youtube
« Reply #1341 on: Tue, 07 May 2013, 05:14:13 »
Actually, now that I think about it again, poker2 supports LEDs, and even the ones that don't come with LEDs has traces and holes for the LEDs, which means it doesn't make sense to make the plate for removable switches.
« Reply #1342 on: Tue, 07 May 2013, 08:01:07 »
So with the current poker (not the poker 2) is it possible to swap stems and springs without desoldering?
« Reply #1343 on: Tue, 07 May 2013, 08:09:37 »
The current poker is PCB mounted. You'll have to desolder. You can only do solderless swaps with custom plates.
Offline inteli722
« Reply #1344 on: Tue, 07 May 2013, 08:13:38 »
I don't believe this is true. With PCB mounted switches, you can disassemble them without desoldering. The custom plate just allows you to reach the part of the switch to take it apart, which is normally blocked by the plate, whereas it's perfectly open on a PCB Mount. If I'm wrong, please correct me, though.
Waiting for: Phantom Plate
« Reply #1345 on: Tue, 07 May 2013, 08:15:09 »
Is there enough room in between the switches for you to get a tool in there and open the switch housing? I don't actually know. It seems like there isn't.
Offline inteli722
« Reply #1346 on: Tue, 07 May 2013, 08:16:46 »
I've seen a video done, and I presume that if there'e enough space between the switches on a plate-mount board, there's enough space on a PCB-mounted board...
on a completely unrelated note, I hate trackpads.
« Reply #1347 on: Tue, 07 May 2013, 08:18:36 »
Can anyone verify this? I've only ever seen videos and heard people talk about it so I might've jumped the gun on my answer.
« Reply #1348 on: Tue, 07 May 2013, 08:22:16 »
With the KBC Poker X, since there is no plate, you can open the switches without desoldering. I have done it many times.
Also true for most Cherry keyboards, since they are usually PCB mounted, also.
« Reply #1349 on: Tue, 07 May 2013, 08:25:35 »
Thanks JD!! :D
Edit: Added the info to the OP under "Commonly Asked Questions"
« Last Edit: Tue, 07 May 2013, 08:28:34 by CPTBadAss »
