Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6276843 times)
Offline tofgerl
« Reply #15550 on: Wed, 14 September 2016, 08:35:25 »
Whenever people talk about making a new SA-like keycap profile, I kind of hope they'll make a spherical fully profiled keycap system with some sort of internal stabilizer so that it would be solid as a rock when put on a MX switch. But I know that's just impossible...
Wobble with a switch isn't necessarily a bad thing. If helps with off-centered strikes and having them register when you type. It would feel much more awkward without the wobble. If you've tried Cherry ML, it'd be similar to that. Unfortunately not everyone has proper typing technique (including myself) so having wobble is helpful.
True enough, but I think you would get used to it, and in fact it might help your technique.
Offline heedpantsnow
  • Old enough to know better
« Reply #15551 on: Wed, 14 September 2016, 10:16:30 »
Who can I get to repair my GON bluetooth in the US?  The two folks I was looking at are no longer in it.
More details of my issue in this thread: https://geekhack.org/index.php?topic=84685.msg2262027#msg2262027
I'm back.
« Reply #15552 on: Wed, 14 September 2016, 11:00:50 »
If you did the soldering and you suspect it's the solder joint, I'd first try resoldering yourself like was suggested in your post. I'm unaware of any USA based repairpeople or builders right now.
« Reply #15553 on: Wed, 14 September 2016, 12:39:12 »
OK thanks.
I'm back.
Offline Deep
« Reply #15554 on: Fri, 16 September 2016, 20:34:24 »
I like the look of the WhiteFox more, I absolutely love that keyboard and I really don't want to buy it used/prebuilt because I like building keyboards, but I don't know if the RedScarf will be worth it. I wont be getting keycaps since I already have nice thick PBT keycaps. The one thing that bothers me is how you can see the pcb plate gap under the keycaps on the RedScarf. Wanted to know if it will be noticeable.
** So at the end I want to see if it will be worth it to wait and maybe get the WhiteFox if it re-releases (or until something nicer comes on) or hop onto this right now since it released.
-Deep.
Offline Deep
« Reply #15555 on: Sat, 17 September 2016, 08:25:25 »
[/quote]
Um....that's not necessarily true. I'm not 100% on that LED type but I wouldn't automatically assume it's fine with keyboards. The issue isn't with the switch body if you're using MX, but really more with the caps. Some LEDs are a bit too thick and rub against the thicker caps like GMK or nice PBT caps. I will say if you are into those LEDs, buy a couple first to trial fit before buying 100+.
-Deep.
I'm not sure what gap you're referring to. And what is your criteria for a keyboard being "worth it"?
[/quote]
By being worth it I was trying to figure out if the WhiteFox will release anytime soon and if not would the RedScarf be a good option... or to just forget every thing there and wait for a jchan 65% release?
Offline ArchDill
« Reply #15556 on: Sun, 18 September 2016, 13:08:47 »
Hello, pretty new here.
I am looking at trading a CM Storm Quickfire TK with Cherry Browns and O-Rings for WoB Dark Lord and/or Evil Silence.
I'm really not sure if I can post in the classifieds yet. Any advice? Should I just wait until I can?
Thanks for any help.
Sincerely, Geekhack Newb.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #15557 on: Sun, 18 September 2016, 13:10:32 »
Hello Friend, you'll need at least 25 posts before you can post in the classifieds :thumb:
Offline ArchDill
« Reply #15558 on: Sun, 18 September 2016, 13:14:02 »
Awesome, thanks so much!
Offline dndlmx
« Reply #15559 on: Sun, 18 September 2016, 18:51:19 »
 :cool:
« Last Edit: Sun, 18 September 2016, 19:06:22 by dndliomx »
« Reply #15560 on: Sun, 18 September 2016, 18:59:03 »
Retro DSA  TKL Set what would you value these at? Lightly used.
You are looking for this thread https://geekhack.org/index.php?topic=31779.0
Offline dndlmx
« Reply #15561 on: Sun, 18 September 2016, 19:05:52 »
So I am...  :cool:
Offline tobsn
« Reply #15562 on: Tue, 20 September 2016, 10:39:56 »
can I put a RGB LED under each key in a 40% layout and control it via a teensy? thanks!
« Reply #15563 on: Tue, 20 September 2016, 15:05:04 »
I believe it's been done before but I'm not 100% sure how it was controlled. This thread seems to think it's not possible but I can't say either way.
« Reply #15564 on: Tue, 20 September 2016, 20:05:01 »
where the **** do you find 2x3x4mm purple leds
not magenta I mean like UV/deeper purple
I know it exists man
Offline ideus
  • Björkö.
« Reply #15565 on: Wed, 21 September 2016, 11:20:09 »
Does someone knows if a G84-4100PPAUS keys are MX compatible and if they are double shots?
« Reply #15566 on: Wed, 21 September 2016, 11:26:36 »
Those user cherry ML switches and are not MX compatible. I believe the key printing is pad printing but they may also have a lasered version as well.
More reading http://bfy.tw/7oWy
« Last Edit: Wed, 21 September 2016, 11:29:09 by SpAmRaY »
Offline ideus
  • Björkö.
« Reply #15567 on: Wed, 21 September 2016, 11:34:54 »
Wow! It was a nice script, haha.
Offline alienman82
« Reply #15568 on: Wed, 21 September 2016, 11:41:05 »
removed.
« Last Edit: Thu, 01 March 2018, 14:10:33 by alienman82 »
Offline ideus
  • Björkö.
« Reply #15569 on: Wed, 21 September 2016, 11:42:30 »
i used cherry ml for a bit.  good for typing bad for gaming
I was hoping to be able to harvest the keys for my custom, but not luck, they cannot, well, still looking for some OG Cherry Alphas.
Offline OompaLoompa
« Reply #15570 on: Wed, 21 September 2016, 17:58:20 »
I was wondering if it was possible to replace costar stabilizers with cherry on a filco majestouch 2? If so, plate or pcb? It doesn't look like pcb would work but this is the fist time I've attempted any sort of modifications so I can't really tell just by looking. Thanks in advance
« Reply #15571 on: Wed, 21 September 2016, 18:01:01 »
You can put plate mounted cherry stabilizers in a Filco if you buy a universal plate.
Don't know where you'd get one, I think mechanicalkeyboards.com used to sell them.
You'd have to desolder every switch and then reassemble using the new plate.
Offline OompaLoompa
« Reply #15572 on: Wed, 21 September 2016, 18:17:10 »
that's exactly what I was wondering, thanks. I was already planning on changing the switches to jailhouse blues and wanted to change up the stabilizers while I was at it but don't know if I can afford a new plate atm. It sucks they wont fit in the stock plate but whatevs.
Offline Dwarlorf
« Reply #15573 on: Fri, 23 September 2016, 06:23:57 »
What's the height of (Signature Plastics) G20 keycaps?
E5XKBP10140                 GH60 Iso/Ansi hybrid, cherry mx red
Offline antftw1
« Reply #15574 on: Tue, 27 September 2016, 09:34:16 »
Is the Magicforce my only option for a 66 or 68 key with black switches and white backlight for under $80?
Offline skuko
« Reply #15575 on: Wed, 28 September 2016, 06:44:34 »
i have 2 sets, will measure them for you tonight
Offline skuko
« Reply #15576 on: Wed, 28 September 2016, 06:45:23 »
i have a question - is there an aluminium case that would fit the leopold FC750RT? i want to pimp mine out a bit :)
Offline PollandAkuma
« Reply #15577 on: Wed, 28 September 2016, 15:30:52 »
Question: What are some common Alps board that can be found easily in UK and what switches do they usually have?
Offline pabile
    • pabile online
« Reply #15578 on: Thu, 29 September 2016, 05:15:29 »
what's the spacebar size needed for hasu's AEK PCB/FR-4 plate?
update: 6.5u based on image posted here  https://geekhack.org/index.php?topic=69666.0
« Last Edit: Thu, 29 September 2016, 09:35:26 by pabile »
Offline yasuo
  • spanengan puyeng newbie
« Reply #15579 on: Thu, 29 September 2016, 19:05:01 »
i was just curious what computer used in the Data avatar?
Logitech MK220 Colemak DH
Offline fublamchu
  • ㅋㅋㅋ
« Reply #15580 on: Sat, 01 October 2016, 17:13:07 »
No afaik
LZ-CE VBlacks
910-CE
Offline alienman82
« Reply #15581 on: Sun, 02 October 2016, 10:39:11 »
removed.
« Last Edit: Thu, 01 March 2018, 14:06:50 by alienman82 »
Offline Epixyl
« Reply #15582 on: Mon, 03 October 2016, 04:51:29 »
Does anyone know if the Red Scarf II+ Ver C. has resistors already soldered on to the PCB? I'm buying LED's and want to make sure everything will work out in the end.
« Reply #15583 on: Mon, 03 October 2016, 14:10:40 »
does anyone bring around their realforces on travels? or do you all go hhkb haha
Offline alienman82
« Reply #15584 on: Mon, 03 October 2016, 14:12:45 »
removed.
« Last Edit: Thu, 01 March 2018, 14:03:04 by alienman82 »
« Reply #15585 on: Mon, 03 October 2016, 14:14:46 »
it's a little big for that.  you could I guess, but might as well use the laptop keyboard since I think RF isn't that much better..  HHKB feels better but I'd rather use linears
so for you linears>45g topre> clunky realforce topre?
Offline alienman82
« Reply #15586 on: Mon, 03 October 2016, 14:16:45 »
removed.
« Last Edit: Thu, 01 March 2018, 14:03:01 by alienman82 »
« Reply #15587 on: Mon, 03 October 2016, 15:52:24 »
Thanks. Been thinking about getting HHKB for a while now. A long, long, drooling while  :p
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #15588 on: Mon, 03 October 2016, 17:51:46 »
Has there been any keyboards that used discrete mechanical switches and a curved plate, excluding maltron and I believe the kenesis?   Wondering about standard layouts.
Offline alienman82
« Reply #15589 on: Mon, 03 October 2016, 17:54:10 »
removed.
« Last Edit: Thu, 01 March 2018, 14:02:13 by alienman82 »
Offline Melvang
« Reply #15590 on: Mon, 03 October 2016, 17:55:36 »
well Model F but not very standard haha.  If you mean curved in more than one direction, I believe those are the only two.  However, maltron has multiple models
But F doesn't use discrete switches.  Was thinking some sort of standard layout with something like MX, Alps, or even own branded switches, but had a curved plate and uniform profile caps.
Offline alienman82
« Reply #15591 on: Mon, 03 October 2016, 17:58:45 »
removed.
« Last Edit: Thu, 01 March 2018, 14:02:10 by alienman82 »
Offline Melvang
« Reply #15592 on: Mon, 03 October 2016, 18:02:07 »
oh I see.  misunderstanding.  you could probably model your own board and hand wire it.  Use a vacuum form with thick plastic and mold it against something else and cutout every switch.  Seems like a boat load of work.   I've seen multiple alps board at an angle that makes it appear curved, but it's just a flat plate.
Think that's something you'lll have to invent.
There was a sculpted microsoft to MX conversion on here somewhere
I was looking to do the multiple plate route, just wondering if it had been done with a single plate and curious how the PCB side was handled.  Mostly curious about mass produced versions.
Offline alienman82
« Reply #15593 on: Mon, 03 October 2016, 18:03:28 »
removed.
« Last Edit: Thu, 01 March 2018, 14:02:07 by alienman82 »
Offline Melvang
« Reply #15594 on: Mon, 03 October 2016, 18:07:51 »
They use flexible PCB's it looks like
Looks expensive to produce in small quantities.  I wonder what is out there for small solder in connectors that allow easy and secure wire connection while being low profile enough for all the columns for a switch matrix.
Offline alienman82
« Reply #15595 on: Mon, 03 October 2016, 18:13:50 »
removed.
« Last Edit: Thu, 01 March 2018, 14:02:04 by alienman82 »
Offline Melvang
« Reply #15596 on: Mon, 03 October 2016, 18:15:16 »
there are solderable versions of the thin ribbon cable.  You could make some spacers and use that instead.  sounds like an interesting project
I was thinking something that would use normal hookup wire to offer flexible layouts with swapping just a single row.
Offline alienman82
« Reply #15597 on: Mon, 03 October 2016, 18:16:22 »
removed.
« Last Edit: Thu, 01 March 2018, 14:02:01 by alienman82 »
Offline Melvang
Offline evilside123
« Reply #15599 on: Fri, 07 October 2016, 04:10:47 »
Good day to all of you. I have an old Samsung GJJ4AKEAT-IOIODS Keyboard.
It has an AT/XT switch. I dont know which is which, can somebody help me with it please?
Your reply will be much appreciated.
