Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6276845 times)
« Reply #15500 on: Wed, 24 August 2016, 09:56:12 »
Can I get some of those old style stabilizers anywhere? I assume I can't use them with a plate?
It's been a while since I took the old boards apart but I think they've got a plate. You can use that one lol. And same with the stabilizers, you can get em from old Cherry boards. Not 100% sure on which models. But there's no new source for them.
Offline tofgerl
« Reply #15501 on: Wed, 24 August 2016, 10:13:08 »
OH, old Cherry MY stabs! I'm up to speed now...
More: https://deskthority.net/wiki/Cherry_MY#Keycap_compatibility_with_Cherry_MX
(The link lies, they're not compatible.)
I think I'll get a set of purple mods from originative and put these on my my keyboard with the purple plate :)
« Last Edit: Wed, 24 August 2016, 10:25:18 by tofgerl »
Offline davkol
  •  Post Editing Timeout
« Reply #15502 on: Thu, 25 August 2016, 06:13:56 »
Those are *new* Cherry MY stabs, not old ones. The old MY stabs are similar to Costar.
Offline tofgerl
« Reply #15503 on: Thu, 25 August 2016, 06:48:47 »
I am down to speed.
How can I use the mods on a 60% with or without a plate?
Offline Eszett
« Reply #15504 on: Thu, 25 August 2016, 20:26:21 »
In which orientation have the Cherry stab inserts* be put into the stabs? (one side has two holes for the stab wire end, the other side has only one hole)
* With "insert" I'm referring to the black plastic inside the black plastic :-)
« Last Edit: Thu, 25 August 2016, 20:28:11 by Eszett »
Offline piemancoder
« Reply #15505 on: Thu, 25 August 2016, 21:51:30 »
The one with two holes is the one you put the wire in. You'll see on the thing you put the insert in there's a spot where the wire snaps in, that's where the one with two holes faces
Yoda grammar best has
Offline Eszett
« Reply #15506 on: Thu, 25 August 2016, 22:10:10 »
@piemancoder perfect, that's it. Thank you!
Offline Dr Hwatson
« Reply #15507 on: Fri, 26 August 2016, 00:42:36 »
Why do all of the TKL cases I see specify that they are not for Ducky boards?
I have a Ducky Shine 3 TKL and I am going to have to resort to painting the case since all of these nice cases hate my board. Just kinda wanted to know the reason behind this specification.
Also, did I make the wrong choice in board? I rarely see Ducky boards posted on reddit (I am brand new to GH). I know they are known for their build quality and that was my driving factor at the time.
« Reply #15508 on: Fri, 26 August 2016, 16:57:44 »
Think they've got a nonstandard dimension compared to many other boards.
And I think ducky boards are great. Always a solid pickup.
Offline NewToKeyboards
« Reply #15509 on: Mon, 29 August 2016, 10:50:34 »
Quick and Simple Question for you all...
Is the Corsair K70 LUX with Cherry MX Blue switches still using a non-standard bottom row?
Already found the answer: for those of you who are wondering it seems that they still are and the bottom row is 1.5 1 1.25 6 1.25 1 1 1.5
« Last Edit: Mon, 29 August 2016, 19:30:50 by NewToKeyboards »
« Reply #15510 on: Mon, 29 August 2016, 13:55:06 »
Is there a way to get translucent on black double shots for a back lit keyboard?
Yes
Offline blazzo
« Reply #15511 on: Mon, 29 August 2016, 19:33:20 »
Possibly a weird question...
What counts as a 'media key' on a keyboard?
Obviously track forward/back, volume up down etc.
But do 'mail', 'home' etc function keys count as 'media keys', or would they be referred to as something else?
Filco MJ2 + Novatouch
Offline tofgerl
« Reply #15512 on: Tue, 30 August 2016, 03:16:14 »
I think of them as media keys, or simply "things I don't want on my keyboard", but I don't know if they're part of any standard. I assume they simply send unused scan codes and the OS knows what to do with them.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #15513 on: Tue, 30 August 2016, 06:21:16 »
Special keys? People may have called them media keys in the past, but I think when someone says 'media keys' they're referring to keys that can be used for prerecorded media. I use a few of those special keycodes myself. They seem to be pretty standard for Windows/Linux OS.
Offline blazzo
« Reply #15514 on: Wed, 31 August 2016, 18:43:38 »
I'm in the same boat and refer to them as "things I don't want on my keyboard" :D
That's what I was leaning towards myself. 'Media' does seem to be pretty specific I guess.
Thanks for the feedback on this question guys, appreciate it.
Offline klennkellon
  • I like bottoming out
« Reply #15515 on: Thu, 01 September 2016, 18:10:58 »
What are the thinnest possible Cherry O-rings I could buy? I would like them 1mm or less.
Offline tobsn
« Reply #15516 on: Fri, 02 September 2016, 08:12:45 »
Trying to build my own keyboard layout atm because I don't like any I found available...
https://geekhack.org/index.php?topic=84301.msg2250651
http://www.keyboard-layout-editor.com/#/gists/ff3374e064770867929c23c6e186fdb2
Maybe someone can give me advice on the sandwich setup with the Case & Plate builder?
I have it currently set up like this for lasergist:
I'm going with M2 screws but I'm not sure if the padding (8mm) and edge spacing (7mm) is good...
Offline MandrewDavis
  • Chasin' That Neon Rainbow
« Reply #15517 on: Sat, 03 September 2016, 00:37:06 »
Has anyone had any experience or have a quick opinion on the idea of dropping Gateron black stems into vintage Cherry housings?
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline PollandAkuma
« Reply #15518 on: Sat, 03 September 2016, 03:36:39 »
So... With the influx  ;D  of London mech addicts, when is a meet-up going to happen?
Offline xondat
  • i'm not a star
« Reply #15519 on: Sat, 03 September 2016, 06:51:34 »
Summer was going to happen for the UK but then **** hit the fan for bunny so never happened.
Offline duynguyenle
  • Personal text? What personal text???
« Reply #15520 on: Sat, 03 September 2016, 06:59:46 »
Influx of London mech addicts? Where?
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline xondat
  • i'm not a star
« Reply #15521 on: Sat, 03 September 2016, 07:07:00 »
Just a few new people in the new members forums :)) Whether they are here to stay, we'll see.
« Reply #15522 on: Sat, 03 September 2016, 14:53:09 »
Might be a good thing if they don't, so no competition iwhen fleabaying  ;)
Offline asgeirtj
« Reply #15523 on: Sat, 03 September 2016, 15:37:36 »
Anyone know if winkeyless.kr or gon boards bend at all when typing?  I'm asking since they don't have a steel plate.  I tried an alu plate with my lz rv and I thought it was horrible so I switched to a steel plate. Will winkeyless.kr boards and gon's be the same?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #15524 on: Sat, 03 September 2016, 15:45:28 »
From my basic understanding both of those suppliers have aluminum plate options. So it will be an aluminum plate on kind of thick acrylic. But, if you're spending that kind of cash on a keyboard what is stopping you from getting a custom steel plate made?
Offline xondat
  • i'm not a star
« Reply #15525 on: Sat, 03 September 2016, 15:58:17 »
Neither have steel plates. WKL only has acrylic, and GON has aluminum but he is a scammer so...
Offline tofgerl
« Reply #15526 on: Mon, 05 September 2016, 06:55:42 »
Is the Phantom the only TKL with TMK support? Cause I don't want to build a Phantom :(
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #15527 on: Mon, 05 September 2016, 07:04:06 »
You could slap a controller on to one of these TKL keyboards. No need to build a keyboard if you don't want to. Quickfire XT is not a TKL but I think that's the only one on this list that is not a TKL
Off the shelf controller list atm http://1upkeyboards.com/index.php?cPath=38 All with TMK support
(I am no way affiliated with 1upkeyboards.com -- they're just awesome)
Offline tofgerl
« Reply #15528 on: Mon, 05 September 2016, 07:05:07 »
Yeah, I know, but in that case I'll order a Hasu USB converter. More flexible. And Novatouch support!
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #15529 on: Mon, 05 September 2016, 08:05:19 »
You already knew the answer before you even asked the question! Look at you ;)
Offline tofgerl
« Reply #15530 on: Mon, 05 September 2016, 08:06:18 »
No, I just wanted to make sure I wasn't missing a cheap TKL somewhere with TMK support. That would be far easier :)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #15531 on: Mon, 05 September 2016, 08:09:24 »
You knew the answer already--admit it ;)
Offline tofgerl
« Reply #15532 on: Mon, 05 September 2016, 08:10:28 »
Nope, but I will admit that googling "Tmk tkl keyboard" didn't give any hits other than the coolermaster alt controllers.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #15533 on: Mon, 05 September 2016, 08:11:30 »
Ah, I see
Offline alienman82
« Reply #15534 on: Mon, 05 September 2016, 12:05:20 »
removed.
« Last Edit: Thu, 01 March 2018, 14:13:05 by alienman82 »
Offline tofgerl
« Reply #15535 on: Mon, 05 September 2016, 13:08:00 »
Can't go back? That's weird... Well, GON are really overpriced IMO...
I put up a wtb on mechmarket earlier today for an ANSI Novatouch. No takers so far.
« Reply #15536 on: Tue, 06 September 2016, 07:13:20 »
When you organize one and find an actual venue. As previously mentioned, there was talk about a meetup but no concrete plans. Meetups aren't really official things run by geekhack. They're community organized by members of the forum. If you want it done, DIY.
Buried in my review are my impressions of this swap
Never had this issue when tying on a GON board. It gave more than a steel plate but I wouldn't say bend.
If EK still sells landing pads, that might work well for you.
Offline Subbax
« Reply #15537 on: Tue, 06 September 2016, 15:00:18 »
I have zero experience here so apologies for the [most likely] stupid question!
I'm looking to make a keyboard from two aluminium plates and 2 acrylic middle pieces to provide the space, seems standard enough.  I've sourced a template, which has screw holes through each piece but I'm unsure how these keyboards are screwed together.  Discounting the fancier feet, most screens I've seen have screws visible from the top so I'd imagine that there's a nut on the bottom and a rubber cover over it?  I've seen Gon's feet but these seem like they'll only screw through the bottom plate, so what's keeping the rest of the 3 layers together?
Offline xondat
  • i'm not a star
« Reply #15538 on: Tue, 06 September 2016, 15:03:19 »
GON uses a straight screw, whereas Winkeyless use rivet nuts.
https://geekhack.org/index.php?topic=44147
http://blog.winkeyless.kr/207
Offline Subbax
« Reply #15539 on: Tue, 06 September 2016, 15:15:27 »
Ahh, rivet nut makes so much sense now.  Ta!
Offline xondat
  • i'm not a star
« Reply #15540 on: Tue, 06 September 2016, 15:52:44 »
This is what I'm planning on using - https://www.accu.co.uk/en/knurled-flat-rivet-nuts/177622-HRKN-M3-10-A2-BL
decent place in the UK from my experience :))
« Reply #15541 on: Wed, 07 September 2016, 02:27:34 »
do SA keycaps fit on a board with sipsocketed 2x3x4 leds?
Offline Bakgrund
« Reply #15542 on: Fri, 09 September 2016, 15:08:06 »
Any decent English reviews of the MOTOSPEED Inflictor CK104 keyboard? Just bought one for 25 bucks  :)
Just found non-english reviews when I searched.
Edit: Nevermind, found a decent review here: https://www.reddit.com/r/MechanicalKeyboards/comments/46jcex/review_motospeed_k84inflictor_ck104_translated/
« Last Edit: Fri, 09 September 2016, 16:08:40 by Bakgrund »
Quickfire Rapid    Quickfire Rapid
Mx Browns          Mx Reds
Ducky thick PBT   Stock caps
Offline asgeirtj
« Reply #15543 on: Sat, 10 September 2016, 12:24:50 »
Is there any difference in feel between pcb mounted switches mounted into a plate and pcb, and non pcb mounted switches mounted into a plate and pcb?
Offline xondat
  • i'm not a star
« Reply #15544 on: Sat, 10 September 2016, 13:13:54 »
All the stability is provided by the plate as the PCB mount don't clip into the PCB, so no. Unless it's placebo.
Offline CyberPlatypus
« Reply #15545 on: Tue, 13 September 2016, 15:06:43 »
I just got my my first mech, a Ducky Shine 5 with Cherry MX Blue switches, a couple of days ago. The keyboard is mostly great, except the keys are pretty wobbly. Is that normal? Thanks for any help!
Offline xondat
  • i'm not a star
« Reply #15546 on: Tue, 13 September 2016, 15:23:51 »
You mean wobble as in you can move the keycap around a bit on the stem? Pretty normal but it shouldn't be too drastic.
Offline tofgerl
« Reply #15547 on: Tue, 13 September 2016, 16:36:25 »
Whenever people talk about making a new SA-like keycap profile, I kind of hope they'll make a spherical fully profiled keycap system with some sort of internal stabilizer so that it would be solid as a rock when put on a MX switch. But I know that's just impossible...
Offline Subbax
« Reply #15548 on: Wed, 14 September 2016, 07:55:45 »
I've used keyboard-layout-editor and swillkb to sort a pretty standard 65% layout, sandwich style build but I'm not entirely sure if I need to add a few mm of space around the outside of the file I get from swillkb.  I'm assuming if the screws are flush they'll just sneak in underneath the cap but if they're not flush I should add some space?
« Reply #15549 on: Wed, 14 September 2016, 08:26:38 »
Wobble with a switch isn't necessarily a bad thing. If helps with off-centered strikes and having them register when you type. It would feel much more awkward without the wobble. If you've tried Cherry ML, it'd be similar to that. Unfortunately not everyone has proper typing technique (including myself) so having wobble is helpful.
Just add a countersink for the screw holes.
