Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6276856 times)
Offline Krustyboomer
« Reply #15250 on: Fri, 17 June 2016, 15:05:13 »
I've been reading where people are using solder WAY older with no problems.  Like my 20-yr old stuff.  Sometimes the rosin core might go bad and you just have to get rid of a foot or so.  If it flows well, go with it!
I've got some .032 44 and some .020 Kester electronic silver solder.  Going to give them a try on an upcoming build.
Offline 9fiftyfive
« Reply #15251 on: Fri, 17 June 2016, 17:40:12 »
Black or White HHKB? I have a white one currently, but I'm getting a second PC, so I need another KB
Offline Sempre
« Reply #15252 on: Fri, 17 June 2016, 20:14:01 »
Get a black one
« Reply #15253 on: Sat, 18 June 2016, 04:05:21 »
white is right
Offline 9fiftyfive
« Reply #15254 on: Sat, 18 June 2016, 04:21:12 »
Get a black one
Yeah, it would be nice to change it up
Offline 9fiftyfive
« Reply #15255 on: Sat, 18 June 2016, 06:16:10 »
Get a black one
« Reply #15256 on: Sat, 18 June 2016, 09:02:57 »
Get a black one
I think that it can look good to get matching black and white keyboards and swap the caps into the opposite cases.
- D Trump 2026-10-24
Offline 9fiftyfive
« Reply #15257 on: Sat, 18 June 2016, 09:04:36 »
Get a black one
I was thinking about making the Space Invaders guys, with inverted colors.
Sent from my iPad using Tapatalk
Offline Celcius
« Reply #15258 on: Sat, 18 June 2016, 10:16:38 »
I got in on the SkiData+ GMK keycaps group buy and now I need a keyboard to use them on. I want a full size keyboard with cherry mx brown switches... any suggestions?
Offline Waateva
« Reply #15259 on: Sat, 18 June 2016, 14:24:21 »
Budget?  LED preference?  Custom or no?
Offline streetwizzur
  • ok
« Reply #15260 on: Sat, 18 June 2016, 17:42:55 »
Does the GH60 rev. C have any led support?
Offline user 18
« Reply #15261 on: Sat, 18 June 2016, 17:46:14 »
It has pads and traces for full backlighting, but it needs an external board to act as a controller. A few LEDs/zones are available without an external board, such as WASD lights.
Avatar by ashdenej
  • ok
« Reply #15262 on: Sat, 18 June 2016, 17:51:44 »
Is that a thing I can buy? Or would something like a rgb strip work under it?
Offline user 18
« Reply #15263 on: Sat, 18 June 2016, 17:54:22 »
I'm not sure, sorry.
Avatar by ashdenej
« Reply #15264 on: Sat, 18 June 2016, 19:00:46 »
Search for QMK firmware. People are using that with RGB led strips to get underglow.
I know with the Satan GH60 and Phantom so it should be possible with regular GH60.
« Reply #15265 on: Sat, 18 June 2016, 19:03:37 »
Any coupon codes to Winkeyless?  % off, first order discount?
Offline Celcius
« Reply #15266 on: Sat, 18 June 2016, 19:11:33 »
I'd like to spend no more than $200. I always turn off LEDs on my boards but it's cool if they're included (as long as they can be turned off). At this time I'm looking for something that I can just buy and put the keycaps on instead of building it myself. At first I was just thinking about a Filco Majestouch 2 but wanted to see if there are any better options for the price range.
« Last Edit: Sun, 19 June 2016, 09:51:46 by Celcius »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #15267 on: Sat, 18 June 2016, 20:28:43 »
Not sure I've ever seen discounts on keyboard sites...
« Reply #15268 on: Sat, 18 June 2016, 20:54:11 »
They've got a prominent coupon code area both in the cart and in the checkout areas.
« Reply #15269 on: Sat, 18 June 2016, 21:03:53 »
So just message them and ask them.
Offline Fullcream
« Reply #15270 on: Mon, 20 June 2016, 18:30:20 »
does anyone have a link for a standard qwerty layout (or some sort of hhkb layout would be better) for gh60 rev. c with atmega 32u4.
I cannot for the life of me figure out how to make my own layouts or any of that stuff (which is why I only buy Gons now) so I have resorted to just trying to find anyone's premade hex file.
After a long time searching the only one I can find anywhere is a colemak ISO one which someone linked in a thread where someone was looking for help doing the same thing I'm trying to do.
Thankyou, if anyone can help!
« Reply #15271 on: Mon, 20 June 2016, 19:27:55 »
EasyAVR as the name implies it makes it easy.
Offline Fullcream
« Reply #15272 on: Mon, 20 June 2016, 20:56:17 »
Thank you for telling me about EasyAVR
It seems to work however not properly for me. I built my layout and then saved the hex and reprogrammed and all my layout works except the button I programmed as FN registers as a windows key and my right shift doesn't register but the button to the right of right shift registers as right shift however that was also meant to be FN but nothing else is accidentally registering as FN so nothing has swapped around by accident.
I really have no idea.
Offline 9fiftyfive
« Reply #15273 on: Mon, 20 June 2016, 23:57:28 »
How well does the KBP V60 work with OS X?
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #15274 on: Tue, 21 June 2016, 04:30:40 »
You can test this one out, https://github.com/jackhumbert/qmk_firmware/blob/master/keyboard/gh60/keymaps/default/compiled.hex. (Click on the "Raw" button)
This should help you debug if your issue is a software or hardware one as Easy AVR doesn't seem to be working for you (Although it should be)
Offline Fullcream
« Reply #15275 on: Tue, 21 June 2016, 04:40:00 »
Thanks! But was just reading another thread where people were mentioning there is often a problem with short right shifts/fn on the gh60 and apparently it's a hardware issue and it just fixes by swapping them around in EasyAVR.
Offline Bucake
« Reply #15276 on: Tue, 21 June 2016, 05:26:31 »
anyone from Germany who could do some proxying (to the netherlands)?
dunno where else i'd ask
Offline ideus
  • Björkö.
« Reply #15277 on: Tue, 21 June 2016, 07:28:17 »
Are the 7u wires for Cherry stabs exactly the same for plate mounted ones than those for PCB mount?
Does anyone have a spec for Cherry 7u wire PCB and plate mounted?
Thank you for your help.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #15278 on: Tue, 21 June 2016, 13:30:03 »
PCB and plate mount wires are interchangeable. As far as dimensions, that I can't help with sorry.
You have to put the FN key in the same location on both layers.  So from base layer, you need FN1 in the same location as FN1 on the FN1 layer.
Offline 9fiftyfive
« Reply #15279 on: Tue, 21 June 2016, 17:22:30 »
Where can I purchase a colorful set of DSA modifiers?
Offline 9fiftyfive
« Reply #15280 on: Tue, 21 June 2016, 17:23:06 »
Which set of these modifiers will fit my Pok3r (Base or Additional)?
http://pimpmykeyboard.com/dsa-think-different-keycap-set/
« Last Edit: Tue, 21 June 2016, 17:36:01 by 9fiftyfive »
Offline user 18
« Reply #15281 on: Tue, 21 June 2016, 18:10:17 »
You need the standard modifiers for a pok3r. Note that if you want to cover the whole board you will also need the base kit, which includes the alphas.
You'll have some extra keys left over, as the base kit + standard modifiers is enough to cover a TKL board.
Avatar by ashdenej
Offline ideus
  • Björkö.
« Reply #15282 on: Tue, 21 June 2016, 18:13:55 »
@Melvang: Thank you for confirming that 7u wires are the same for plate and PCB mounted plastics.
Offline 9fiftyfive
« Reply #15283 on: Wed, 22 June 2016, 01:38:34 »
Ok, I was actually going to use these as my base:
http://pimpmykeyboard.com/dsa-sublimated-keycap-sets/
Would that work?
Offline 9fiftyfive
« Reply #15284 on: Wed, 22 June 2016, 02:57:46 »
Where can I get a Tux DSA key?
Offline dermixxer
« Reply #15285 on: Wed, 22 June 2016, 03:05:50 »
Whats the cheapest fully programmable board out there? (60-80%)
Only found the option to upgrade CM Quickfire Rapid + Filco Majestouch with a custom controller.
« Reply #15286 on: Wed, 22 June 2016, 09:04:09 »
Are there any on the SP/PMK sites?
I think that would be pretty cheap. You could also pick up like a Rosewill or something for cheap then setup a Hasu USB-to-USB converter.
Shouldn't have any problems as far as I know.
Offline user 18
« Reply #15287 on: Wed, 22 June 2016, 09:24:06 »
Would that work?
Yes, that should be fine as well  :thumb:
Avatar by ashdenej
Offline Waateva
« Reply #15288 on: Wed, 22 June 2016, 09:36:11 »
There are some colorful keysets like the Rainbow one at PMK but I don't see just a modifiers option listed.
http://pimpmykeyboard.com/keysets/
Otherwise you could piece things together by ordering each piece separately and choosing the exact colors you would want but they would be blanks.
http://pimpmykeyboard.com/blank-key-packs/dsa/
Offline 9fiftyfive
« Reply #15289 on: Wed, 22 June 2016, 09:46:43 »
No Tux on PMK. Idk what SP is
Offline 9fiftyfive
« Reply #15290 on: Wed, 22 June 2016, 09:47:05 »
Would that work?
Offline 9fiftyfive
« Reply #15291 on: Wed, 22 June 2016, 09:47:59 »
Thanks. I was going to go with the rainbow kit but I couldn't get modifiers only. Perhaps the Think Different modifiers will do for now
« Reply #15292 on: Wed, 22 June 2016, 09:50:08 »
SP is the same people as PMK. Also known as Signature Plastics. PMK is their storefront that caters to the keyboarding enthusiast community. They used to have a separate marketplace site from PMK but it looks like they've migrated over to PMK completely. Not sure where else to look for that Tux cap. Maybe Techkeys.us still has some? I thought they stocked them at one point.
Offline 9fiftyfive
« Reply #15293 on: Wed, 22 June 2016, 12:43:05 »
What size are the bottom rows of keys on the Pok3r (I'm trying to get blank modifiers)
« Reply #15294 on: Wed, 22 June 2016, 12:47:23 »
1.25x modifiers with a 6.25x spacebar. Standard ANSI
Offline 9fiftyfive
« Reply #15295 on: Wed, 22 June 2016, 12:47:59 »
Offline 9fiftyfive
« Reply #15296 on: Wed, 22 June 2016, 16:49:57 »
What is the measurement of the "Enter" key on the Pok3r?
Offline ideus
  • Björkö.
« Reply #15297 on: Wed, 22 June 2016, 17:17:00 »
2.25 units width for the ANSI version, remarking just in case there is an ISO one.
Offline 9fiftyfive
« Reply #15298 on: Wed, 22 June 2016, 17:23:18 »
Offline 9fiftyfive
« Reply #15299 on: Wed, 22 June 2016, 17:30:56 »
So then 1.75 would be tab and 2 would be something else, correct?
