Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6277223 times)
Offline Saiph
« Reply #15150 on: Mon, 16 May 2016, 12:06:47 »
I just finished swapping my keyboard back to gateron yellows from zealios through switch top removal. For some reason my keys seem to catch onto something if I hit them from the bottom of the keycap. This happens at the beginning of pressing down. Anyone know what might cause this?
« Reply #15151 on: Mon, 16 May 2016, 12:14:24 »
Did you switch caps? That might have something to do with it.
The stems are different I believe as well which could be an issue as well.
Offline Saiph
« Reply #15152 on: Mon, 16 May 2016, 13:15:40 »
I haven't switched keycaps this time around, though I did use different keycaps when I had this keyboard originally(when it was gateron yellows). The caps are GMK Sky Dolch.
It does seem like I can't get the switch to catch when I press it without the keycaps. I guess it could be the stem of the cap catching?
« Reply #15153 on: Mon, 16 May 2016, 13:22:30 »
There's been some issues reported with GMK caps and some MX stems. I think people have shaved down the caps to fix it if I recall correctly.
Offline Saiph
« Reply #15154 on: Mon, 16 May 2016, 13:29:42 »
Ah yeah, I just found that thread. I guess its a tedious step that I have to go through haha. Do you think sandpaper would work well for that?
« Reply #15155 on: Mon, 16 May 2016, 13:31:06 »
I guess so? I've never done it. I have both files and sandpaper in my tool box at home. I'd try the sandpaper first and if I'm not getting good results, switch to the files. Both can be had for very cheap.
Offline Saiph
« Reply #15156 on: Mon, 16 May 2016, 13:38:44 »
Yeah, sounds like a plan. Thanks for the help. :thumb:
Offline pr0ximity
« Reply #15157 on: Tue, 17 May 2016, 05:38:17 »
My Gateron caps from one of Ivan's buys do the same on my Gateron Blacks. I haven't been able to fix it because I can't figure out a good way of telling where the cap is rubbing on the housing.
Offline ghostjuggernaut
« Reply #15158 on: Tue, 17 May 2016, 06:02:36 »
Back when gateron switches first came from hwood, there were a lot of people talking about the switch stems catching at odd angles. The GMK set may be perpetuating this.
Offline pr0ximity
« Reply #15159 on: Fri, 20 May 2016, 07:39:40 »
Sorry I misspoke, my Gateron keycaps were catching on vintage MX Blacks.
Offline klennkellon
  • I like bottoming out
« Reply #15160 on: Fri, 20 May 2016, 14:51:48 »
Why does the Model M's case never yellow despite being made of ABS?
« Reply #15161 on: Fri, 20 May 2016, 14:57:38 »
I thought that Model M used PVC.
- D Trump 2026-10-24
Offline NewbieOneKenobi
« Reply #15162 on: Fri, 20 May 2016, 15:28:49 »
Are Majestouch 1 keycaps PBT?
« Reply #15163 on: Fri, 20 May 2016, 16:41:07 »
nope ABS
« Reply #15164 on: Fri, 20 May 2016, 18:31:38 »
It's not the material itself that yellows, I believe it's fire retardant chemicals that get added that causes yellowing. Apparently whatever material the Model M is made from, it doesn't have those chemicals to become yellow.
Offline kohi
« Reply #15165 on: Sat, 21 May 2016, 18:14:30 »
do gateron clear switch covers fit well on cherry switches housings? or does it somehow change the feel of the switch
« Reply #15166 on: Sun, 22 May 2016, 08:45:13 »
They fit and I think it changes the feeling.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #15167 on: Mon, 23 May 2016, 01:38:10 »
To my knowledge PVC was used in the outer insulation of the cable.  During long term storage the cable can react with the case and essentially melt the case at the point of contact.  This is why some people recommend stuffing the cable into something like a toilet paper tube to minimize the contact.
From what I have read, bromine is the flame retardant that is suspected to cause the yellowing when exposed to long term UV light.
Couple questions of my own regarding my newest keyboard acquisition.
137750-0
1. What is the correct location for those clips.  When I received this keyboard those along with some other parts were in a plastic bag.
2.  Is that plug physically compatible with a VGA socket?
3.  Are the plastic tabs from a PC-AT compatible with the slots on this keyboard?  My keyboard didn't arrive with any and would like to use the plastic ones from my AT as I use insert stabilized keys and have already knocked out the plastic clips.  Would just be a matter of gluing them back in with a bit of epoxy.
« Reply #15168 on: Mon, 23 May 2016, 07:20:12 »
1) https://geekhack.org/index.php?topic=50475.msg1131368#msg1131368
2) Don't know
3) Not sure what plastic tabs you're referring to. Or what their purpose is.
Offline Melvang
« Reply #15169 on: Mon, 23 May 2016, 07:36:56 »
2) Don't know
The tabs for the wire stabilizers.
« Reply #15170 on: Mon, 23 May 2016, 07:54:03 »
2) Don't know
I believe they're the same yes.
Offline Melvang
« Reply #15171 on: Mon, 23 May 2016, 07:55:42 »
2) Don't know
Thanks CBA, looking forward to typing in this soon. I would assume the card in the top left of the linked post is a buzzer and not a solenoid.
Offline Eszett
« Reply #15172 on: Mon, 23 May 2016, 09:00:25 »
simple question: may I use Costar stabs with Alps?
« Reply #15173 on: Mon, 23 May 2016, 09:05:03 »
I don't think so. Stabilizers on Alps are tricky. I'd stick with the Matias stabilizers.
Offline Eszett
« Reply #15174 on: Mon, 23 May 2016, 09:15:55 »
Alrighty, thx Captain!
Offline klennkellon
« Reply #15175 on: Wed, 25 May 2016, 03:12:16 »
I'm looking for a good tactile switch, but apparently the tactility on MX Browns is pretty weak and Topre is too pricey for me at the moment, are there any alternatives?
« Reply #15176 on: Wed, 25 May 2016, 06:04:37 »
MX clears are good, if a little heavy.
« Reply #15177 on: Wed, 25 May 2016, 07:09:31 »
nope ABS
Thanks. Found my old G8-11800 with PBT caps while cleaning today. Tempted to play dentist now.
« Reply #15178 on: Wed, 25 May 2016, 12:32:43 »
nope ABS
try throwing them in with some warm water and denture tabs
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #15179 on: Wed, 25 May 2016, 12:41:29 »
Anyone got a guide for cleaning coffee spill on Realforce 87? D:
It also happened months ago.. am I screwed? Should I just get an HHKB?
« Reply #15180 on: Wed, 25 May 2016, 12:45:52 »
Take it apart and clean everything with isopropyl alcohol. I like using 91%. Let it dry. Put it back together. Since it's been a while, it might have some issues. You would ideally have cleaned it ASAP.
I had a friend spill soda on a Razer Blackwidow. He didn't do anything about it and it ended up corroding the PCB. I only found out about it like 3 months later. If you see corrosion, you won't be able to recover the board.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #15181 on: Wed, 25 May 2016, 12:53:53 »
Okay thank you CPTBA, I will try this when I have time !
Offline HPE1000
  • Keycap Paparazzo
« Reply #15182 on: Wed, 25 May 2016, 16:13:10 »
How would I go about figuring out the size of a screw I have? I have one of the original vortex aluminum tkl cases and I need new screws for it, since the original ones were too short to actually hold it together.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #15183 on: Thu, 26 May 2016, 16:24:39 »
k another dumb question:
is the bro set https://ctrlalt.io/buys/the-bro-set
cherry profile or sp dcs? i looked around but didn't see what it was. its been so long since i bought it i can't remember, and i don't remember which sellers sold what profiles anymore :/
please help :)
thanks
« Reply #15184 on: Thu, 26 May 2016, 16:27:35 »
please help :)
thanks
DCS
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #15185 on: Thu, 26 May 2016, 16:38:06 »
Thanks partna
Sent from my OnePlus One
Offline stoic-lemon
« Reply #15186 on: Thu, 26 May 2016, 17:38:44 »
Which of the two lubes, thick or thin, offered by Zeal are suitable for use on stabilisers?
« Reply #15187 on: Thu, 26 May 2016, 17:39:08 »
both, thick probably better for stabs.
Offline stoic-lemon
« Reply #15188 on: Thu, 26 May 2016, 17:40:46 »
Thanks Sifo.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #15189 on: Thu, 26 May 2016, 23:42:00 »
is there such a thing as blank white realforce set? pretty much im looking for some colorway as the white realforce (with the grey mods) but blank. is this available?
« Reply #15190 on: Fri, 27 May 2016, 05:39:56 »
Not with grey mods, but an all white blank set was available in the mists of ancient time.  Good luck finding one now though :(
Offline Waateva
« Reply #15191 on: Fri, 27 May 2016, 09:27:40 »
I think that there was a guy dyeing sets over on /r/MechMarket but I don't know how well a black white set would turn out via dyeing.
Offline Suruga Devil
« Reply #15192 on: Fri, 27 May 2016, 12:57:18 »
Are there any 104-key boards with a milled aluminum enclosure that are currently on the market? Besides that Ducky one, the brass doesn't count.
Bonus points if it's plate mounted!
Offline alienman82
« Reply #15193 on: Fri, 27 May 2016, 13:21:44 »
removed.
« Last Edit: Thu, 01 March 2018, 15:07:53 by alienman82 »
« Reply #15194 on: Fri, 27 May 2016, 17:19:53 »
^ It's not really on the market though.
Offline asgeirtj
« Reply #15195 on: Sat, 28 May 2016, 06:05:30 »
I'm building a board right now and I'm testing caps on differently lubed stabs.  However sometimes when I take the caps off the switch the stab comes off the pcb because I have to pull so hard.  Does anyone know how to prevent this?  I'm using zealios and og cherry dyesubs.
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline HeeCh2ei
  • qdrw
« Reply #15196 on: Sat, 28 May 2016, 06:42:50 »
Spread some lube over the keycap mount on stabs ( "+" shaped thing).
Cherry is the Maker, Topre is the God
FC660C             FC750R (reds)     FC750R (blues)
Offline asgeirtj
« Reply #15197 on: Sat, 28 May 2016, 08:11:39 »
I'm assembling my lz rv, i've soldered all the switches, however the 1,2,3,4 don't work as well as numlock, add, multiply, subtract. insert is delete, delete is home, end is page up and vice vera, windows keys don't work, keys number 2 and 3 above the numpad give 2 and 3. anyone know what could be going on?
« Reply #15198 on: Sat, 28 May 2016, 12:31:25 »
I'd like to have a custom PCB made for me, where can I post on Geekhack to request such a service?
Can one-off keysets be ordered from GMK, and if so, how much would it cost? Doubleshot of course, but no custom legends.
Offline ideus
  • Björkö.
« Reply #15199 on: Sat, 28 May 2016, 13:01:35 »
I have never heard off GMK keeping off the shelve stock; but, you may ask them, they may have left overs that you can buy. If what you want is your own colors selection; then, based on recent GBs it seems that the lowest MoQ is 150, so you may buy 150 sets, keep the amount you want, one?, and sell the rest. Why you just not joint one of the multiple current GMK group buys, instead? There are at least 3 of them active, or soon to come.
