Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6277204 times)
Offline MJ45
  • HHKB Pro
« Reply #15050 on: Fri, 15 April 2016, 04:34:52 »
I really like the thocking sound of the HHKB but really don't like the placement of the ctrl key since I game more than I type, any solutions?
Use another keyboard for gaming not a HHKB. I think a TKL with MX linear switches are better suited for the task.
Offline davkol
  •  Post Editing Timeout
« Reply #15051 on: Sat, 16 April 2016, 13:37:01 »
Or use a remapped JIS HHKB.
Offline Bradley727
« Reply #15052 on: Sun, 17 April 2016, 05:56:23 »
Hi guys I purchased a Realforce Variable weighted keyboard from a business in Australia. I had a look at the back of the keyboard and it is listed as a 'Realforce UW8755' and the model number is 'SE08T0'. The shop I purchased this from was a small business with limited stock. Did they just send me the uniform weighted 55g version? I'm not discerning enough to be able to tell if the keys are variably weighted.
Offline MJ45
  • HHKB Pro
« Reply #15053 on: Sun, 17 April 2016, 06:14:23 »
Yes that seems to be a 55g version, if you like the feel keep it. Most seem to favor the RF 55g uniform myself included.
http://elitekeyboards.com/products.php?sub=topre_keyboards,rftenkeyless
Offline Bradley727
« Reply #15054 on: Sun, 17 April 2016, 06:28:46 »
Ahh okay that's good. To be honest I was feeling buyer's remorse over getting a variable weighted keyboard. I have another question, I wanted to purchase blank keycaps and I can't seem to find anything out there. Is there a source for blank white realforce 87U keycaps?
Offline alienman82
« Reply #15055 on: Sun, 17 April 2016, 11:28:43 »
removed.
« Last Edit: Thu, 01 March 2018, 15:30:01 by alienman82 »
Offline yjt33
« Reply #15056 on: Tue, 19 April 2016, 19:34:31 »
Can someone with poker 3 with LED check something for me.
if the dip switch #3 is on (the one that makes Capslock into FN), will the capslock light be permanently on.
Offline nephiel
« Reply #15057 on: Wed, 20 April 2016, 15:54:11 »
Is the "charcoal" Gateron blank keyset from UKkeycaps (http://www.ukkeycaps.co.uk/product/gateron-thick-pbt-blank-keycaps-iso-ansi) the same color as the "dark" from Shadovved's blanks GB (https://geekhack.org/index.php?topic=72609.0)?
Stop wasting space! Chop your spacebar into bits!
NPH60: a custom 60% w/TrackPoint & split spacebar
« Reply #15058 on: Wed, 20 April 2016, 15:55:45 »
Wish there was a bigger picture but it looks like they're different.
Offline user 18
« Reply #15059 on: Wed, 20 April 2016, 17:16:27 »
My guess from those images is that the charcoal is closer in colour to the caps from this GB:
https://geekhack.org/index.php?topic=50935.0
https://geekhack.org/index.php?topic=50935.msg1755037#msg1755037
Avatar by ashdenej
Offline nephiel
« Reply #15060 on: Thu, 21 April 2016, 16:35:02 »
That's what I thought at first, but wasn't 100% sure.
Thanks.
Offline joey
« Reply #15061 on: Thu, 21 April 2016, 18:33:12 »
Can someone just sanity check the 1800 layout here: http://www.keyboard-layout-editor.com/#/gists/2e885a5c0661e60169a637bd218ddd54 (not the legends, but physical key placement)
« Reply #15062 on: Thu, 21 April 2016, 19:09:20 »
Probably intentional but you've got a 2u + key and your bottom row is not authentic 1800, it should be 1.5, 1.5, 7, 1.5, 1.5 or 1, 1, 1, 6, 1, 1, 1, 1.
Your layout will fit in a standard 1800 case and has better keycap options though, if that's what you were going for :thumb:
Offline joey
« Reply #15063 on: Fri, 22 April 2016, 01:59:47 »
I just meant the spacing of the arrow keys and function row etc! But thanks, I guess you answered yes to that.
« Reply #15064 on: Sat, 23 April 2016, 11:18:48 »
Can anyone who is familiar with the leeku 3000 pcb let me know if you have to cut out the piece(s) pictured below to fit into the g81-3000 case?? I'm fairly certain that is what is supposed to be done but I haven't found any information that says for certain.
135226-0
135228-1
135230-2
Offline alienman82
« Reply #15065 on: Sat, 23 April 2016, 13:36:03 »
removed.
« Last Edit: Thu, 01 March 2018, 15:27:02 by alienman82 »
« Reply #15066 on: Sat, 23 April 2016, 14:00:53 »
I'm not sure, but are you planning to replace that 1.5u control key on the right?  Are those gateron blacks?  Looks nice Spamray!  :cool: :cool:
Yeah it was super late last night when I was putting the bottom row on haha. :facepalm:
And it's a mix of gateron switches, I just wanted to get it built so I used what I had lying around.
Offline fi0x
« Reply #15067 on: Sat, 23 April 2016, 14:14:32 »
Are Cherry and Costar Stabilizers interchangeable? Or is it dependent on the PCB and plate? If so, how would I know?
~I̶ ̶a̶m̶ ̶n̶o̶t̶ ̶a̶ ̶k̶e̶y̶b̶o̶a̶r̶d̶ ̶g̶e̶e̶k̶ ̶(̶I̶ ̶w̶o̶u̶l̶d̶ ̶l̶i̶k̶e̶ ̶t̶o̶ ̶t̶h̶i̶n̶k̶ ̶I̶'̶m̶ ̶o̶n̶e̶)̶ I am a keyboard geek~
« Reply #15068 on: Sat, 23 April 2016, 14:34:08 »
No they are not interchangeable and costar are plate mount only. There have been a few aftermarket plates with cutouts that could use both but typically you only have the choice of one or the other.
« Reply #15069 on: Sat, 23 April 2016, 19:21:23 »
I definitely didn't need to, but that was for an older winkeyless case. I've never used a leeku with a newer one like yours. It looks like you will either need to mod the case or cut away those parts on the PCB.
Offline leeku
« Reply #15070 on: Sat, 23 April 2016, 22:12:54 »
ok this is a latest type of cherry case.
( ) shape is exactly for this.
REMOVE THE PART OF ( ) TO FIT THIS KIND OF CASE
« Reply #15071 on: Sat, 23 April 2016, 22:16:20 »
Awesome! Thank you so much leeku and thanks for the wonderful PCB's :D
Offline jonathanyu
« Reply #15072 on: Sun, 24 April 2016, 23:07:40 »
what is the weight of a tkl realforce?
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #15073 on: Mon, 25 April 2016, 00:11:01 »
Has anyone had any problems with the Lock LEDs (CapsLock/ScrollLock) not working on your just assembled KMAC2?
I used new LEDs that I got from Sprits GB a while ago.  They are probably a little over a year old.
I haven't tried to re-flash the firmware yet as I don't need to change the layout.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
« Reply #15074 on: Mon, 25 April 2016, 00:21:26 »
http://www.amazon.com/Realforce-87U-Tenkeyless-55g-Black/dp/B00MV84Y2Y
Amazon suggests 2.6 pounds (with shipping weight 3.3 pounds).
Offline jonathanyu
« Reply #15075 on: Mon, 25 April 2016, 00:50:29 »
thinking about getting a realforce to carry around.. but it seems to heavy, i guess i will stick with my dell rubber dome than  :rolleyes:
« Reply #15076 on: Mon, 25 April 2016, 00:55:04 »
HHKB?
Offline jonathanyu
« Reply #15077 on: Mon, 25 April 2016, 14:18:41 »
HHKB?
nah, I can't use 60% at all
Offline tintoret
« Reply #15078 on: Thu, 28 April 2016, 07:55:50 »
Are the stock keycap profiles the same on the Apple Standard Keyboard and Apple Extended Keyboards?
« Reply #15079 on: Thu, 28 April 2016, 08:57:20 »
I believe they are.
Offline mason
  • have fun with her, ryan
« Reply #15080 on: Fri, 29 April 2016, 10:47:36 »
My spacebar stabilizer wire popped out under the plate. Is desoldering the switches the only option to fix it?
« Reply #15081 on: Fri, 29 April 2016, 10:54:17 »
I've been able to fix my Cherry stabilizer wire without desoldering in the past. It's a lot of fishing and messing with it but I didn't have to desolder anything. It would certainly make things easier though.
Offline mason
« Reply #15082 on: Fri, 29 April 2016, 11:00:29 »
Thanks, I guess I'll keep trying
Offline alienman82
« Reply #15083 on: Fri, 29 April 2016, 11:02:08 »
removed.
« Last Edit: Thu, 01 March 2018, 15:22:44 by alienman82 »
Offline mason
« Reply #15084 on: Fri, 29 April 2016, 11:17:52 »
hopefully the zeal stab project is completed soon. Screw in stabs never catch on the spacebar like what probably happened to you.  I hate it when that happens.  Ideally, I'd have a cap set for every board, but I only have 2 OG dye sub sets, so I can't do that T_T
I guess I'm gonna order a soldering iron. This is gonna be my first time desoldering, should I get the YiHUA-936B?
« Reply #15085 on: Fri, 29 April 2016, 11:29:40 »
Sure. It should be all right if you don't plan on doing much soldering. And remember a solder sucker or solder braid.
Offline alienman82
« Reply #15086 on: Fri, 29 April 2016, 11:33:49 »
removed.
« Last Edit: Thu, 01 March 2018, 15:22:36 by alienman82 »
Offline Crossfire
« Reply #15087 on: Fri, 29 April 2016, 11:57:07 »
The board itself is 2.4lbs.
Offline mason
« Reply #15088 on: Fri, 29 April 2016, 12:31:01 »
chip quik is amazing stuff too for really stubborn joints :thumb:
Thanks guys  :thumb:
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #15089 on: Fri, 29 April 2016, 15:48:06 »
What's the best place to order sip sockets from in the US?
Does someone have a link?
WTB/WTS/WTT ---->
« Reply #15090 on: Fri, 29 April 2016, 16:44:12 »
Do you just need regular ones? They are dirt cheap on eBay.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #15091 on: Fri, 29 April 2016, 17:19:45 »
I need some for switch LEDS.
I'm not familiar with the different kinds.
WTB/WTS/WTT ---->
« Reply #15092 on: Fri, 29 April 2016, 17:30:50 »
There are short and long ones in relation to how far do they protrude out the bottom of the PCB.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #15093 on: Fri, 29 April 2016, 17:34:55 »
Ah,  then I guess the longer ones would be best.  Sounds like they are easier to work with.
WTB/WTS/WTT ---->
« Reply #15094 on: Fri, 29 April 2016, 17:35:06 »
From the SIP socket thread:
eBay SIP Sockets
These might work for you but you can check that thread for the other options
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #15095 on: Fri, 29 April 2016, 18:37:07 »
eBay SIP Sockets
Thanks. Do you know if these are the longer stemmed ones they talk about in that thread?
WTB/WTS/WTT ---->
« Reply #15096 on: Fri, 29 April 2016, 19:05:04 »
eBay SIP Sockets
The ones on ebay are short.
Zeal sells some long tail ones on his website https://zealpc.net/collections/accessories/products/sipsockets
Just make sure you calculate the amount correctly as you'll need 2 per switch. :D
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #15097 on: Fri, 29 April 2016, 21:42:00 »
eBay SIP Sockets
Okay, cool.   Thanks Ray
WTB/WTS/WTT ---->
Offline Eszett
« Reply #15098 on: Sun, 01 May 2016, 16:58:30 »
Hi! I have a stupid question:
« Reply #15099 on: Sun, 01 May 2016, 17:02:47 »
6U Spacebars
7U Spacebars
I think that's just what Cherry did. So wherever you got that screenshot from has the same setup.
