Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6277600 times)
Offline bocahgundul
  • a seal
« Reply #14850 on: Sat, 05 March 2016, 17:12:19 »
How much force does the spring under the hhkb spacebar add again? 5 or 10g? I forget OnO
5g bro  :thumb:
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
Offline LechnerDE
« Reply #14852 on: Sun, 06 March 2016, 01:55:04 »
Where can I get those stabilizer inserts for cheap in Europe?
http://www.wasdkeyboards.com/index.php/cherry-mx-keycap-stabilizer-insert-2pcs.html
WASD wants like 30$ for shipping which is ridiculous for such an item...
http://www.keyboardco.com/product/4-filco-white-stabilizers.asp
Or I'm more than happy to proxy some for you from wasdkeyboards.
Thank you for the link and your offer to proxy!
The pack from Keyboards CO is still expensive considering it's only 4 tiny pieces of plastic :(
I had hoped you can buy a 100 pack from Taobao for cheap. Does anybody know a vendor who has these in stock?
Offline tassadarforaiur
« Reply #14853 on: Sun, 06 March 2016, 15:51:32 »
Is there a gh60 plate layout floating around? Bought pcb off tech Keys, but only have costar stabs.
« Reply #14854 on: Mon, 07 March 2016, 07:49:37 »
Hm...the original GB had plates which could accommodate all the stabilizer types. Dunno if the plate files were ever released. I'd PM jdcarpe and ask.
Are there any ortholinear fullsize keyboards?
EDIT: Not counting SPOS-style keyboards, looking for something with a more traditional height/aspect ratio instead of the massive grid.
Besides the SPOS ones you're referring to, I don't think so.
Has anyone else experienced a difference in tactility between Milky Housing (PCB 5Pin Mount) and Clear Housing (Plate 3 Pin Mount) Gateron Switches?
I built a keyboard yesterday using Milky Gateron Blues and noticed they felt a lot 'mushier' than my KC60, which has the Clear Gateron Blues.
(This is a difference in housing/body, not the actual stem type/color).
Is there a reason for this? The keycaps I'm using are the same between boards and both are using Costar stabilizers.
Also, if this issue is caused by the housing or stem, could I just swap out the tops and stems with a 'Clear' one?
I REALLY don't want to desolder everything and replace the entire switch  :-X...
You can swap the tops and stems out yes. The difference between the two could be differences in tolerances or materials. Never played with the exact switch combinations myself though.
Offline klennkellon
  • I like bottoming out
« Reply #14855 on: Mon, 07 March 2016, 16:58:31 »
Is a 1986 model m worth $20 more over one from 97'?
« Reply #14856 on: Mon, 07 March 2016, 18:25:41 »
Quite probably.
- D Trump 2026-10-24
Offline Bromono
  • Wanabe Cicerone
« Reply #14857 on: Tue, 08 March 2016, 08:37:07 »
Where can I find this wrist rest or one like it?
130527-0
130529-1
Offline alienman82
« Reply #14858 on: Tue, 08 March 2016, 09:18:02 »
removed.
« Last Edit: Thu, 01 March 2018, 15:54:50 by alienman82 »
« Reply #14859 on: Tue, 08 March 2016, 09:21:27 »
I believe that's the clear acrylic Bird Electron wrist rest from PFU. I am unsure whether or not it's still for sale.
Offline jonathanyu
« Reply #14860 on: Tue, 08 March 2016, 16:25:56 »
Offline klennkellon
« Reply #14861 on: Tue, 08 March 2016, 19:57:01 »
Why are the industrial Model M's so highly valued? Is it just because they are rare or do they have advantages over regular Model Ms?
« Reply #14862 on: Tue, 08 March 2016, 20:02:01 »
Mainly due to rarity.  They're not common and they're much sexier looking that the standard Model M.
Offline klennkellon
« Reply #14863 on: Tue, 08 March 2016, 20:15:23 »
I see. I'd rather buy a regular model-m and paint it for 1/3 the cost.
Maybe I should start making bootleg industrial model m's.
« Reply #14864 on: Tue, 08 March 2016, 20:16:56 »
Only if you like getting hit with socks full of nickles.
Offline Bromono
  • Wanabe Cicerone
« Reply #14865 on: Tue, 08 March 2016, 20:18:11 »
Offline swimmingbird
  • keyset hoarder
« Reply #14866 on: Wed, 09 March 2016, 23:42:56 »
Can anyone identify this keyboard?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #14867 on: Wed, 09 March 2016, 23:44:14 »
Well it appears to be your standard vintage clicky mechanical computer keyboard at xt super cheap sale keyboard.
  • keyset hoarder
« Reply #14868 on: Wed, 09 March 2016, 23:44:57 »
*cough* white alps *cough*
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #14869 on: Wed, 09 March 2016, 23:47:12 »
I got nothing search for Profound SK-688LB (or 6881B, 888LB, 8881B).
  • keyset hoarder
« Reply #14870 on: Wed, 09 March 2016, 23:49:21 »
Yeah I did quite a bit of searching on that model number without any results
I'm wondering if its a rebrand of some other board
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14871 on: Thu, 10 March 2016, 09:13:30 »
Silitek OEM, probably the Silitek SK-8801 which is Rubber dome.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #14872 on: Fri, 11 March 2016, 11:18:42 »
What's the current recommendation for switch SIP sockets for LED installation? I found an old thread that suggested that there were multiple sizes, and that the larger ones prevented switches from closing well. Can someone link me to the specific ones I'd want to buy?
Cheers.
Offline klennkellon
« Reply #14873 on: Fri, 11 March 2016, 17:53:53 »
I'm having issues with my Blue Cube PS/2 to USB converter.
The converter is detected by my PC, and the keyboard works fine when directly plugged into the PS/2 port (which is not aligned properly so i try not to use it). The keyboard will work for a few moments and then stop working a few moments later.
does anybody know why? thanks
EDIT: forgot to mention It's an AT keyboard being converted to PS/2
« Last Edit: Fri, 11 March 2016, 17:56:33 by klennkellon »
« Reply #14874 on: Fri, 11 March 2016, 18:13:29 »
So you have an AT to PS/2 adapter then a PS/2 to USB adapter? Could you be a little more clear? Your edit is confusing.
Offline klennkellon
« Reply #14875 on: Fri, 11 March 2016, 18:21:50 »
Apologies.
Apologies.
The keyboard is a Focus FK-2001. It uses a 5 pin AT cable, which I have a converter that converts it into PS/2. I then am plugging that PS/2 cable into the PS/2 to USB adapter.
« Reply #14876 on: Fri, 11 March 2016, 18:33:33 »
Apologies.
Apologies.
So with just the AT to PS/2 converter it works fine. And with the PS/2 to USB adapter it doesn't work that well? I'd try another keyboard with that PS/2 to USB adapter but it just seems like your adapter is bad.
Offline klennkellon
« Reply #14877 on: Fri, 11 March 2016, 18:41:17 »
Apologies.
Apologies.
I tried it with another keyboard, it works better, but it's like there is some huge lag between keystrokes and they don't even register.
At normal typing speed "Tq quik bown f x jumpd oer the la dog"
so probably the converter like you said.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #14878 on: Fri, 11 March 2016, 20:20:51 »
Cheers.
+1  I'd like to know this also.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline klennkellon
« Reply #14879 on: Fri, 11 March 2016, 21:44:47 »
I just tried it again with my moms PC and her PS/2 keyboard, did not work.
I think it's something to do with the AT to PS/2 converter, maybe it doesn't play nice.
« Reply #14880 on: Fri, 11 March 2016, 22:01:57 »
Cheers.
I'm not 100% sure what's the most up to date SIP socket information but I found this year old GB which placed an order for these SIP sockets on Mouser. I ran a Google search for mention or info in the last 3 months and it didn't yield any info.
  • Cherry Peasant
  • keycult.com
« Reply #14881 on: Fri, 11 March 2016, 23:47:11 »
Thanks capn. I placed an order and will post here once they've arrived and I've tried installing a few.
Offline rpeterclark
  • RPTR ❌
« Reply #14882 on: Sat, 12 March 2016, 06:44:23 »
Cheers.
I installed those exact SIPs in some Zealios a couple nights ago. I removed them from the black housing and they fit just fine. Using those same SIPs, I've had to fiddle getting them into Cherry and older Gateron switches, they can catch on the top housing if not aligned right.
  • Cherry Peasant
  • keycult.com
« Reply #14883 on: Sat, 12 March 2016, 09:57:37 »
Thanks for the info rpeterclark. I'm putting them in some Gaterons, and I'm not sure how to tell whether they're "old" or "new" Gaterons, but I'll report back regardless. Will probably be next weekend or so that I mod these switches.
Offline poisened_blueberry
« Reply #14884 on: Sun, 13 March 2016, 19:18:08 »
Offline 108
  • Yeet. Yeet.
« Reply #14885 on: Sun, 13 March 2016, 20:06:19 »
Anyone know the difference between these two? Which one would you get?
http://gaming.coolermaster.com/en/products/keyboards/rapid-i/ vs http://gaming.coolermaster.com/en/products/keyboards/quickfirerapidred/
From what I've read the QFR-I is just a more updated and durable version of the QRF-R. However, the QFR-R comes with only red switches, and a red backplate.
Offline zombiegristle
« Reply #14886 on: Sun, 13 March 2016, 20:56:33 »
Are there any "preferred" keyboards or other input methods for interacting with a computer while wearing gloves? Specifically, something for typing crap while working on a car without having to constantly don and doff that work gloves would be pretty handy...
Offline klennkellon
« Reply #14887 on: Sun, 13 March 2016, 21:18:59 »
Maybe a KB with heavy switches so its harder to press other keys accidently with your gloves.
« Reply #14888 on: Sun, 13 March 2016, 21:27:24 »
Hmmm, ok.  The fact that the QFR-R is red switch only isn't a problem, as that is the switch I prefer.  If the QFR-I is more durable though, then i'm probably going to get that one, esp since it's cheaper aswell.
Offline ideus
  • Björkö.
« Reply #14889 on: Sun, 13 March 2016, 21:27:42 »
You may try to wear gloves with no tips, if they are safe for your trade.
« Reply #14890 on: Sun, 13 March 2016, 21:31:57 »
Many buckling springs boards have been found in autoshops.
Offline klennkellon
« Reply #14891 on: Sun, 13 March 2016, 21:38:14 »
Yeah, in fact the industrial versions were in partmade because the grime is harder to see on grey.
« Reply #14892 on: Sun, 13 March 2016, 21:40:35 »
Sweet, I'll start checking out buckling-spring boards. My current daily-use board has Cherry greens, and it seems the main issue is the edges of the gloves pressing down adjacent keys unless I type very slowly, hunt-and-peck style. Fingertip-less gloves are a no-go, I'm not looking to compromise safety for convenience. Thanks for the advice!
  • keyset hoarder
« Reply #14893 on: Sun, 13 March 2016, 22:09:35 »
All of a sudden I'm getting this really weird phenomenon with my duck viper...
Pressing certain keys like I will result in two I's being placed (unless you tap it very quickly) and pressing K gives me something like the following:
"   Qetuquo[   wetip   wetpqi   qweryweyi   q]iwerty   ]iqweryi   toryuiiyuo[   eier   wtyiqe   wrtyui   qetyri   qweyri   qweoryui   qwertyui   qop]iet"
What the hell is going on?
edit: ive tried resetting the firmware and im still getting this problem - also getting it on other keys such as ]}
The "=+" key is giving me not only double entries but is giving me crazy random stuff like "124`7\1608" now as well
« Last Edit: Sun, 13 March 2016, 22:16:14 by swimmingbird »
« Reply #14894 on: Sun, 13 March 2016, 22:22:58 »
That's a fascinating set of symptoms, has the board ever had water damage?
« Reply #14895 on: Sun, 13 March 2016, 22:52:27 »
And the essence of many autoshops has been found inside buckling spring keyboards found in autoshops.
  • keyset hoarder
« Reply #14896 on: Sun, 13 March 2016, 22:53:01 »
"Qetuquo[wetipwetpqiqweryweyiq]iwerty]iqweryitoryuiiyuo[eierwtyiqewrtyuiqetyriqweyriqweoryuiqwertyuiqop]iet"
Nope
« Reply #14897 on: Sun, 13 March 2016, 22:55:29 »
Do you have anything between the PCB and the metal case?
  • keyset hoarder
« Reply #14898 on: Sun, 13 March 2016, 22:57:36 »
The board came prebuilt so I'm not sure exactly
Haven't had a problem with it to date though
  • keyset hoarder
« Reply #14899 on: Mon, 14 March 2016, 01:20:43 »
I took the board apart - turns out there was nothing separating the pcb from the aluminium case....
I put some sticky tape down on each of the standoffs and put it back together - working perfectly now
Thanks man
