Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6277793 times)
0 Members and 7 Guests are viewing this topic.
Offline ajx
« Reply #14650 on: Sat, 06 February 2016, 13:38:07 »
https://vid.me/JFeu
HHKB spacebar makes me sick while on NT its dead silent
Both silenced by way with ironed landing pads, both lubed and greased on stabs
Where the ****ing noise comes from?
I believe its the spacebar steel wire that hits on plastic stab?
Maybe should i lube more into stab?
Any advice would be grateful
Thanks
Offline bocahgundul
  • a seal
« Reply #14651 on: Tue, 09 February 2016, 04:24:17 »
Can someone tell me what is the angle of this board :
-Koala
-360c
-LZ FE
Thank you!
« Reply #14652 on: Tue, 09 February 2016, 06:35:46 »
-Koala
-360c
-LZ FE
Thank you!
I can't find much. All I found in a quick search is this quote about the Koala.
https://vid.me/JFeu
Thanks
The most common fix I've heard about spacebar noise is lubing the stabilizers. Other than that, I have no idea since I don't Topre. :(
So what sort of LEDs do you use in the Redscarfs for RGB?
I'd assume SMD RGB LEDs but I couldn't find any information on it at all. Might have to track down an owner to take a picture?
« Last Edit: Tue, 09 February 2016, 06:37:30 by CPTBadAss »
Offline bcredbottle
« Reply #14653 on: Tue, 09 February 2016, 08:55:27 »
I have a Chicony board with a male 5 pin DIN plug. Can't find any converters with female 5 pin DIN on one end. Do I need to mount a new controller (I really hope not!) or is there a simpler solution?
Oops
« Last Edit: Tue, 09 February 2016, 09:01:43 by bcredbottle »
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #14654 on: Tue, 09 February 2016, 14:04:19 »
Trying to get some LEDs from Mouser.
What size would I be looking for?
« Reply #14655 on: Tue, 09 February 2016, 16:00:26 »
What kind of LEDs you looking for? SMD? In-switch/the ones with legs? And what switches are you putting the LEDs into?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14656 on: Tue, 09 February 2016, 16:23:36 »
Anyone know what the cheapest source of G80s (any kind) are in the US? On eBay the cheapest is currently $35. I need a Cherry board for a project of mine, but I decided against using the Cooler Master I'd bought.
    • WTB/WTTF Thread
« Reply #14657 on: Tue, 09 February 2016, 16:46:44 »
Switch LEDs to go with a couple Zealio builds.
Offline Red October
« Reply #14658 on: Tue, 09 February 2016, 17:30:12 »
Does anyone know the sizes of the re-legendable keycaps on the IBM 6112884?  I would like to be able to make neat-looking legends for mine with my laser printer.
« Reply #14659 on: Tue, 09 February 2016, 17:33:25 »
I usually go for 2x3x4 mm LEDs but the Zealio switches will actually fit inswitch RGB LEDs switches. I'm not sure of the sizes.
    • WTB/WTTF Thread
« Reply #14660 on: Tue, 09 February 2016, 18:23:24 »
Well the board I want to use them on doesn't support in switch RGB LEDs as far as a I know and I heard that 2x3x4mm with Zealios causes a scratching issue with GMK caps but I am not sure.
Offline Skribbles
« Reply #14661 on: Tue, 09 February 2016, 18:53:16 »
What case is this?
Mod Note: Woohoo!  My KMAC 2! :cool:
« Last Edit: Sun, 14 February 2016, 09:51:13 by infiniti »
Offline bocahgundul
  • a seal
« Reply #14662 on: Tue, 09 February 2016, 19:02:46 »
What case is this?
Kmac 2 cause af that bezel?
Offline cryptokey
  • [°°▄°] luser-friendly
« Reply #14663 on: Tue, 09 February 2016, 19:08:39 »
How would I go about contributing to the GH wiki?  I have some things to contribute to pre-existing lists, yet when I tried to log in with my GH username, it said that it did not exist so I figure you need some special account or permission.
Also, if anybody has any links to a guide for installing Hypersphere silencing rings, that would be awesome.
[WTB] HHKB Black
« Reply #14664 on: Tue, 09 February 2016, 19:10:43 »
1) How would I go about contributing to the GH wiki?  I have some things to contribute to pre-existing lists, yet when I tried to log in with my GH username, it said that it did not exist so I figure you need some special account or permission.
2) Also, if anybody has any links to a guide for installing Hypersphere silencing rings, that would be awesome.
1) I believe you need to get the moderators to setup an account. I don't really remember how I got access to be honest though. There was a long awaited upgrade and I was part of trying to set up a team with the geekhack staff to spearhead a Wiki overhaul. That never came to fruition and kinda died. I believe the best thing to do is to add to the DT Wiki and keep populating Making Stuff Together with the maker/DIY stuff that GH is into.
2) https://geekhack.org/index.php?topic=73940.5
https://deskthority.net/help-f53/silencing-rings-for-topre-rf-or-hhkb-t10051-60.html#p246406
What case is this?
I would also guess KMAC 2.
« Last Edit: Tue, 09 February 2016, 19:12:28 by CPTBadAss »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #14665 on: Tue, 09 February 2016, 19:22:13 »
What case is this?
The winkeys, red plate, and sides make me think it's a KMAC II
Offline bocahgundul
  • a seal
« Reply #14666 on: Tue, 09 February 2016, 19:26:01 »
What case is this?
Kmac 2 is so classy!
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #14667 on: Tue, 09 February 2016, 19:26:38 »
What case is this?
Definitely, one of my favorite boards.
Offline bocahgundul
  • a seal
« Reply #14668 on: Tue, 09 February 2016, 19:31:47 »
What case is this?
How much did you say for this board? 500$? Ah so classy! It haves its own charms! Not like the other customs!
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #14669 on: Tue, 09 February 2016, 19:32:52 »
What case is this?
Yea, somewhere around there.
Offline bocahgundul
  • a seal
« Reply #14670 on: Tue, 09 February 2016, 19:37:23 »
What case is this?
Yes thank you brother!
Offline Skribbles
« Reply #14671 on: Tue, 09 February 2016, 19:40:02 »
Thanks for the responses guys! Another KB that I'm about, ohh, 3 years too late to get in on... Still figuring out what my first mech kb should be! Wish me luck as I navigate the 100s of tabs I have open right now.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #14672 on: Tue, 09 February 2016, 19:43:33 »
Honestly, the KMACs are pretty affordable as far as kustoms go. You could find a KMAC I for sub $400, II for sub $600
Offline bocahgundul
  • a seal
« Reply #14673 on: Tue, 09 February 2016, 19:43:45 »
Your best bet is classified tho!
Offline xondat
  • i'm not a star
« Reply #14674 on: Wed, 10 February 2016, 01:55:50 »
What keycaps are those on the KMAC?
Offline bocahgundul
  • a seal
« Reply #14675 on: Wed, 10 February 2016, 02:23:49 »
Gateron pbt? I see that bro use this on his dge too IIRC
Or imsto
Offline JonnyPolygon
  • Mechanical keyboard masterrace
« Reply #14676 on: Wed, 10 February 2016, 03:38:14 »
Damn, glad I decided to check out this thread. It's awesome! Thanks
Ducky Shine | i7 GTX 980ti | Top 9 best mechanical keyboards
Offline xondat
  • i'm not a star
« Reply #14677 on: Wed, 10 February 2016, 03:45:40 »
Or imsto
The gats come in 4 shades right? I want the shade that's lighter than this but I might be wrong.
Offline bocahgundul
  • a seal
« Reply #14678 on: Wed, 10 February 2016, 04:44:42 »
Or imsto
I think this one is from geekeys! Check the geekeys website they have the same ones
Offline Stabilized
« Reply #14679 on: Wed, 10 February 2016, 10:22:29 »
Just got a Leeku 1800 PCB and wondering if there is any difference between this style of diode:
And this one that I see most people using on their's:
I can get 150 of the first one for £2 and the other one is £6 for the same amount (shipped from farnell.com). Would prefer to go with the former if there is no differences/disadvantages.
« Last Edit: Wed, 10 February 2016, 10:24:37 by Stabilized »
« Reply #14680 on: Wed, 10 February 2016, 10:35:28 »
I prefer the flat package, because I find them easier to mount. But a diode is a diode. Just use whichever you want. :)
Offline Stabilized
« Reply #14681 on: Wed, 10 February 2016, 10:42:26 »
Ok I thought as much. Thanks very much! ;)
Offline Steezus
  • Keeper of Facts
« Reply #14682 on: Wed, 10 February 2016, 11:47:11 »
Yeah I definitely prefer the flat diodes as well, last time I used the LL4148 diodes I had to tape one side down and solder the other side or else they'd roll right off.
Like Jd said, diodes are diodes. They are just meant to direct the path of the current, allows it to come in one way but not the other. :thumb:
Offline tofgerl
« Reply #14683 on: Wed, 10 February 2016, 12:29:21 »
Can anyone think of a reason for a diode to be cylindrical...?
Offline xondat
  • i'm not a star
« Reply #14684 on: Wed, 10 February 2016, 12:33:18 »
Think it's just the older way to do them
Offline jd29
« Reply #14685 on: Wed, 10 February 2016, 13:27:19 »
Through-hole vs surface mount. If you're doing through-hole you probably don't care if your diode is round or flat, and for a very long time through-hole was dominant. Manufacturing rectangular through-hole diodes might be a little more involved, and cost more, for no good reason.
Offline Otesanek
« Reply #14686 on: Wed, 10 February 2016, 15:29:07 »
I have a quick question that I have not been able to find the answer to on my own:
What qualifies as a post on Geekhack? I've been around here for just a few months and have a post count of 6, but I feel like ived posted more than that, so I guess there is other qualifications for what makes a post. I ask because I might want to make use of the classifieds in the future.
Offline thatllbeme
« Reply #14687 on: Wed, 10 February 2016, 15:44:12 »
So I put one of my customs together again today (had to take it apart because I'm a klutz and wired the Teensy in backwards). One of the keys doesn't register when pressed down normally, but when I put the keyboard on the table upside down it spams the key. Swapping out the spring + stem hasn't helped and the solder connections seem fine. Shorting the switch by putting a wire across both legs doesn't help either, so I'm thinking I'll have to swap out the whole leaf or switch. Am I missing something obvious?
Offline tofgerl
« Reply #14688 on: Wed, 10 February 2016, 15:49:17 »
Yay, 7!!! /artificiallyinflatingpostcount
Offline Steezus
  • Keeper of Facts
« Reply #14689 on: Wed, 10 February 2016, 15:51:17 »
A post that counts is one that generally contributes something to the forum Threads such as new members, off topic, classifieds, etc. aren't really contributions so they do not count as posts.
Offline Otesanek
« Reply #14690 on: Wed, 10 February 2016, 15:52:47 »
Sorry for asking a question on the question thread. I'm not trying to artificially inflate my post coubt, I just want to know why only 6 of my posts are counted. Is that really a problem? If you look at my posts, I'm clearly not a spammer. I don't appreciate your attitude, I'm new man, give me a break.
Offline Otesanek
« Reply #14691 on: Wed, 10 February 2016, 15:58:13 »
Okay, that makes a lot of sense. Thank you Steezus.
Offline Steezus
  • Keeper of Facts
« Reply #14692 on: Wed, 10 February 2016, 16:01:26 »
No problem, if you ever want to see your total post count go to Profile -> Show Posts -> and then skip to the last page and at the very first post there will be a number next to it.
Offline tofgerl
« Reply #14693 on: Wed, 10 February 2016, 16:27:57 »
It was a joke. Who has an attitude here...?
You should know that the pattern /doingsomething means that that is what the poster is doing, not a jab at someone else.
Offline Otesanek
« Reply #14694 on: Wed, 10 February 2016, 16:54:19 »
Oh man, my bad then. Sorry about that. I obviously didn't take it as a joke.
/walksawayembarrased
Offline tofgerl
« Reply #14695 on: Wed, 10 February 2016, 18:23:52 »
No worries. Humour is hard to infer in writing as we all know 😊
Offline ctm
  • Hello, world!
« Reply #14696 on: Wed, 10 February 2016, 20:50:51 »
I got 3 Topre switch testers and the keycaps confused me. The keycap from Type Heaven is supposedly ABS and the other two from Realforce are PBT. The Type Heaven keycap has a nice texture and feels dry(not slippery). It feels very similar to my Vortex PBT caps. On the other hand, the Realforce caps are quite slippery, even more slippery than my ABS caps. Why is this?
Coming:
Ellipse Model F F62.
Offline bocahgundul
  • a seal
« Reply #14697 on: Wed, 10 February 2016, 21:16:36 »
Different plastic?
No I mean different factory? Cause they must have a different finishing?
Offline ctm
  • Hello, world!
« Reply #14698 on: Wed, 10 February 2016, 22:01:27 »
Different plastic?
I don't have other Topre caps, but the two I have are different (one white one black). I thought PBT in general has a dry texture that is somewhat resilient to sweat, but these two does not feel that way. Is my impression on PBT wrong?
Coming:
Offline bocahgundul
  • a seal
« Reply #14699 on: Wed, 10 February 2016, 22:07:32 »
Different plastic?
Different method leads to different feeling. BSP have smooth texture and ducky caps have a dry texture. Topre caps all have a smooth texture but the black caps have a rougher texture
