Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6278056 times)
Offline swimmingbird
  • keyset hoarder
« Reply #14450 on: Thu, 21 January 2016, 21:20:25 »
Why don't you see half plates that much in customs anymore?
I only remember seeing it for one OTD (360?), The Cheat, and an attempt at it for TGR which was recent
Ahh ok - maybe im assuming they were more popular than they actually were
I guess having a plate that allows for switch opening (without desoldering) kind of negates the need for a half plate?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #14451 on: Thu, 21 January 2016, 21:25:37 »
Well, the one real effect you get from a half plate is a plate mount feel on the mods and a pcb mount feel on the alphas. Not super useful anyway
  • keyset hoarder
« Reply #14452 on: Thu, 21 January 2016, 21:26:29 »
Ahhh totally forgot about that - thanks :)
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #14453 on: Thu, 21 January 2016, 21:27:43 »
That's my assumption. Should also give it a good bit of added rigidity over a half plate.
Offline klennkellon
  • I like bottoming out
« Reply #14454 on: Fri, 22 January 2016, 04:09:47 »
Can anyone directly compare Matias Click switches with the original Complicated White ALPS for me? I have used my ALPS board enough to think that I like the switches a lot for typing but would like to try something more modern in design.
I find that Complicated Whites are heavier and not as smooth as the Matias Click switches. I prefer Matias Click to Complicated Whites.
Thank's for answering. I've been using my FK-2001 with white ALPS for a few days and I like them alright but they feel a little clunky sometimes.
Offline tofgerl
« Reply #14455 on: Fri, 22 January 2016, 04:14:31 »
I've been using my first SA keyboard for a few weeks, and the wiggle is starting to annoy me. I know it's completely normal, but is there anything I can do to (literally) fix it? The keyboard already has an alu plate. The case is temporarily plastic, but that shouldn't matter, right?
Offline E3E
« Reply #14456 on: Fri, 22 January 2016, 05:32:04 »
I believe I have had six vintage blue Alps boards so far, and still, I haven't been able to try a complicated white Alps board yet, hahaha. Eh.  :rolleyes:
« Reply #14457 on: Fri, 22 January 2016, 06:37:03 »
We're 50 key IBMs made with F internals using the M style case, or did all the F versions have the 4704 style cast case?
It was a cast metal plate IIRC
Thanks CBA, I am assuming this one is M by the date on the label, but was F internals ever used in the same case?
http://m.ebay.com/itm/IBM-KEYBOARD-4707-50-KEY-POS-1392560-/172050888228?nav=SEARCH
I'm far from an IBM expert so I'm not sure. All I know is that the 4074 50key that dorkvader showed me had F internals and a cast metal case.
You can shim the caps with a bit of plastic. Like tape or a sandwich baggie. That might help.
Not that popular and I don't think the effect works as well as advertised. I've never tried it myself though.
  • keyset hoarder
« Reply #14458 on: Fri, 22 January 2016, 06:37:57 »
Thanks man
Offline mobbo
  • u fk
« Reply #14459 on: Fri, 22 January 2016, 11:05:58 »
I just got 1976 and after putting it on a Pok3r I noticed the spacebar sticks quite a bit...sometimes it even just stays down when I press the key slowly.
Just wondering what the issue could be here. I tried it with a GMK spacebar and it seems to work fine.
Quote from: Binge
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #14460 on: Fri, 22 January 2016, 11:09:34 »
Check and see if in inside of the spacebar is rubbing against the stabilizer. You might need to shave it down a touch.
« Reply #14461 on: Fri, 22 January 2016, 11:10:03 »
lube fixes this normally.
Offline mobbo
  • u fk
« Reply #14462 on: Fri, 22 January 2016, 11:12:30 »
Thanks guys I'll try both of these things when I get home.
Which part would typically be rubbing against the Cherry stabs? The stem itself, or one of the edges of the spacebar?
Quote from: Binge
Offline inanis
    • SEALWoodworking
« Reply #14463 on: Fri, 22 January 2016, 11:14:10 »
The interior edge of the spacebar. I've taken a nail file to a few keys before. It doesn't take much and there is no visible impact. And a little lube, as Sifo mentioned, may also do the trick.
Offline mobbo
  • u fk
« Reply #14464 on: Fri, 22 January 2016, 11:16:24 »
Thanks <3
Hopefully it's as simple a fix as you guys are suggesting!
Quote from: Binge
Offline xondat
  • i'm not a star
« Reply #14465 on: Fri, 22 January 2016, 18:41:45 »
Desoldering all switches on a WASD V2, swapping springs, stickering, and lubing; is it actually viable or not?
The key press is too light, but I don't want to damage to contacts whilst desoldering.
(Just in case) Is the PCB swappable?
« Reply #14466 on: Fri, 22 January 2016, 18:52:57 »
Viable if you know what you're doing. It will require higher temperature to desolder since factories use lead free, so slightly higher risk of damage.
PCB is not swappable, is the short answer.
Offline pr0ximity
« Reply #14467 on: Fri, 22 January 2016, 19:42:18 »
Ah, I tried that. Did not work. No idea why... That was the first thing I tried, even before I put in the two other switches...
I'm a bit late, but did you insulate the terminals when you put them into the "botched" position so they didn't make contact with whatever is left of the botched holes?
Offline Jixr
« Reply #14468 on: Fri, 22 January 2016, 22:03:16 »
is the DS5 programable in its RGB features? or its it just set with default profiles?
Offline Oxid
  • resin rash and glitter
« Reply #14470 on: Fri, 22 January 2016, 22:49:02 »
My HHKB's spacebar sounds weird (clacky instead of thock-y) when I hit it in the middle. Is there a solution?
Also, if I press it down, and slightly wiggle it forward/backwards, i hear the spring squeaking hardcore.
Lastly, I have Tri-flow lube, that I bought for my X-55 HOTAS, would it be safe to use for an HHKB? Or will it chew through my board/desk/floor/neighbor-beneath-me?
« Reply #14471 on: Sat, 23 January 2016, 12:36:56 »
Have you tried just leaving out the spring? Some people say it feels better
Offline azhdar
  • Praise the AZERTY god
Azerty Propagandiste
« Reply #14473 on: Sat, 23 January 2016, 15:48:34 »
Anyone know what sets in the past have used SP's BBJ color? Or if anyone has a cap in that color/has the color swatch.
« Reply #14474 on: Sat, 23 January 2016, 16:39:22 »
http://elitekeyboards.com/products.php?sub=access,cherrymxkeys&pid=cds_yel_arrow
are those N6 or CV color?
CV.  N6 is a god-awful goldenrod color.
AFAIK, none have.  I was wanting to do a set with that color in the past since it's such a fantastic color.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #14476 on: Sat, 23 January 2016, 16:47:56 »
Yeah well that's why I'm doing it now. But I have a surprise I want to get going for people who get in on the GB so I want to see the color :\
Offline Oxid
« Reply #14477 on: Sat, 23 January 2016, 17:40:11 »
I'll give that a shot, thanks. Didn't occur to me to try without it.
Offline xondat
  • i'm not a star
« Reply #14478 on: Sat, 23 January 2016, 17:45:49 »
How do get GIFs work for avatars?
« Reply #14479 on: Sat, 23 January 2016, 17:49:08 »
Needs to be exact size 150x150 (or smaller) and uploaded via computer
Offline xondat
  • i'm not a star
« Reply #14480 on: Sat, 23 January 2016, 17:52:30 »
<3 :-*
« Reply #14481 on: Sun, 24 January 2016, 01:06:12 »
You could also try putting a small (~1cm2) bit of plastic over the stabilisers before you put the space bar on.
« Reply #14482 on: Sun, 24 January 2016, 01:07:04 »
Anyone know if there are meetups in Belgium/The Netherlands? Have yet to find fellow countrymen here and only know a few that share the hobby.
No idea, but you are welcome to create a thread in off topic to see if there is any interest.
If there is sufficient interest, the mods might even make the thread sticky for you.
Offline bocahgundul
  • a seal
« Reply #14483 on: Sun, 24 January 2016, 07:38:46 »
Can someone who have tried vintage black and zeal linear compare the 2 of them?  :thumb
Are the zeal better or the vintage black better?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14484 on: Sun, 24 January 2016, 07:49:28 »
If price isn't a factor I'd get Zeal, otherwise vintage blacks.
Offline bocahgundul
  • a seal
« Reply #14485 on: Sun, 24 January 2016, 07:50:42 »
nah I don't care about the price
« Reply #14486 on: Sun, 24 January 2016, 08:14:29 »
The Zeal linears felt the same to me as the Gateron linears. Unless you really want the custom weighting, I think most people would be happy with Gateron Blacks and Reds. I prefer the Gaterons to Vintage Blacks just because they're easier to source.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14487 on: Sun, 24 January 2016, 08:18:20 »
Gateron makes Zeal switches, so feeling the same doesn't really come as a surprise to me.  :p
Offline bocahgundul
  • a seal
« Reply #14488 on: Sun, 24 January 2016, 08:20:07 »
Nah bro I mean like the actual feeling of the switches bro does the vintage black feels better?  :thumb:
So its like gateron black with gold springs and transparent housing?
« Reply #14489 on: Sun, 24 January 2016, 08:22:54 »
Yeah I guess I shouldve clarified my statement.
I'm not following your question now. I think Gaterons feel just as good or better. The Zealio linear are just Gateron black stems with custom springs and a different housing yes.
Offline bocahgundul
  • a seal
« Reply #14490 on: Sun, 24 January 2016, 08:25:02 »
Thank you bro that answer my question  :thumb:
Offline mason
  • have fun with her, ryan
« Reply #14491 on: Sun, 24 January 2016, 12:07:39 »
I stripped 3 screws on my Realforce.. I tried the rubber band method, but no luck. Any tips?
« Reply #14492 on: Sun, 24 January 2016, 12:59:35 »
For stripped screw sockets I usually do something like glue a toothpick or matchstick into the hole and then drill it out just smaller than the shaft of the screw.
- D Trump 2026-10-24
Offline tofgerl
« Reply #14493 on: Sun, 24 January 2016, 13:02:47 »
Whatever you do, when you get them out, replace them with proper ones made of good metal.
Offline Pemdas
« Reply #14494 on: Sun, 24 January 2016, 16:07:14 »
Anybody have any experience with both linear green alps and matias linears? How do the matias linears compare to the greens?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14495 on: Sun, 24 January 2016, 16:15:50 »
I haven't yet tried SKCL Green Alps but I will tomorrow when I fly home. If someone else hasn't answered before then, I'll let you know my experience.
« Reply #14496 on: Sun, 24 January 2016, 16:56:40 »
IMO, good condition linear greens are better feeling.  They're the smoothest linear switches I've felt.
« Reply #14497 on: Sun, 24 January 2016, 17:11:37 »
This, or a guitar string, should work.
« Reply #14498 on: Sun, 24 January 2016, 17:18:15 »
The Matias Linears feel *much* lighter than SKCL Greens to me. The Matias linears also have a bit of a click on the downstroke which really threw me off. I much prefer SKCL Greens. The weight is a bit heavier and they're luciously smooth. Some of my favorite Alps switches period. Some more of my thoughts on the Matias Linears can be found here.
Offline Pemdas
« Reply #14499 on: Sun, 24 January 2016, 17:22:50 »
I'd love to hear you opinion, the more the better :thumb:
Sweet thanks for the input! I've been loving linear switches lately and have heard great things about these greens. Going to keep my eyes peeled for a green alps board.
I've only got one alps pcb and I really hate desoldering so ill probably end up getting both to test side by side in the end :/
