Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6278050 times)
Offline xondat
  • i'm not a star
« Reply #14400 on: Tue, 19 January 2016, 14:41:00 »
Okay, how do I take apart my WASD V2? There aren't screws under the legs.
Huh, I just checked on mine, there's none under my legs either.
Is there a sticker on the back? Perhaps you need to break the sticker in order to open the back so they can tell because it would probably void the warranty.
Waaaaaa
« Reply #14401 on: Tue, 19 January 2016, 14:42:08 »
Waaaaaa
Should be under the OK sticker. At least that's where the screw is on Filcos.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #14402 on: Tue, 19 January 2016, 14:42:32 »
Waaaaaa
Try that sticker that says "Do Not Remove"  they are usually under there.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline xondat
  • i'm not a star
« Reply #14403 on: Tue, 19 January 2016, 14:54:25 »
Waaaaaa
There is 1. Um.
Offline xondat
  • i'm not a star
« Reply #14404 on: Tue, 19 January 2016, 15:32:00 »
http://imgur.com/a/D2HQI
Found this but I only have two hands wtf
Offline derb2k2
  • Something of a Topre ****..
« Reply #14405 on: Tue, 19 January 2016, 18:57:52 »
When will Brian from EK re-stock on 45g RF??
HHKB | RF 45UB | Novatouch | Poker II Blue | QFR Browns | Rosewill RK-9000RE
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #14406 on: Tue, 19 January 2016, 21:22:23 »
Could you not find any videos on Youtube?
Don't think that question can be answered here.  I would email Brian and ask.
WTB/WTS/WTT ---->
Offline klennkellon
  • I like bottoming out
« Reply #14407 on: Wed, 20 January 2016, 03:41:19 »
Hey, I need a little help with my ALPS board.
They are complicated white alps in a Focus FK-2001.
I tried lubing a few switches because they felt scratchy, I started with Numlock 7 as a test, it went fine, but when I did 4 the switch has now lost all tactility and feels completely linear.
I thought it was because I used too much lube, so i wiped it all off and gave it a quick rinse until it didn't feel greasy, and then I put it back, it still feels the same. I have no idea why its doing this. All of the parts are in exactly how they should be. The keys still work fine BTW. I can upload pictures later if needed.
Thanks.
Offline bocahgundul
  • a seal
« Reply #14408 on: Wed, 20 January 2016, 04:43:16 »
Thanks.
Nope don't ever lube clicky switches ever. Well there is a guide for it but its really complicated so just don't lube your alps just clean it like in this videos
Thank you chryos for the videos all courtesy from chyros
Offline klennkellon
« Reply #14409 on: Wed, 20 January 2016, 04:54:16 »
Thanks.
That's the video I used to take it apart, all I did was lube the slider, and I cleaned it off so it should still work at least a little!
After more cleaning and tweaking the tactile leaf, the key has regained a majority of its tactility but with no click. This is so weird.
Offline xondat
  • i'm not a star
« Reply #14410 on: Wed, 20 January 2016, 05:26:46 »
Offline wockytocky
« Reply #14411 on: Wed, 20 January 2016, 14:11:31 »
Is there an easy way to make an FC660c programmable? Maybe something like Hasu's alternate HHKB controller but for the fc660c?
« Reply #14412 on: Wed, 20 January 2016, 14:19:55 »
Thanks.
I think there should be two leaves. One makes the clickyness and one provides the contact to the PCB. Do you have both leaves in the switch?
Maybe this?
Nope
So you unscrew the only screw then the case halves are just snap fit together. So you run a credit card or something relatively thin and flexible between the two case halves and kinda lever the snap fits apart. That's how my Filco is and that's how that CODE looks.
Offline dgneo
  • Supervillain
« Reply #14413 on: Wed, 20 January 2016, 14:22:35 »
« Reply #14414 on: Wed, 20 January 2016, 15:36:26 »
Maybe this?
+1   Indeed, I believe this is the only option at this time.
Offline xondat
  • i'm not a star
« Reply #14415 on: Wed, 20 January 2016, 15:39:30 »
There's probably a millimeter that I have to lever in, I genuinely can't figure this out
Offline wockytocky
« Reply #14416 on: Wed, 20 January 2016, 16:16:17 »
Maybe this?
Looks interesting, thanks!
« Reply #14417 on: Wed, 20 January 2016, 16:23:08 »
Yes, you'll have to use a little bit of force to get your tool into there. The case halves should have a little give. If they don't give, you haven't removed all the screws yet.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #14418 on: Wed, 20 January 2016, 16:54:11 »
CBA, what was the most difficult case for you to crack into?
« Reply #14419 on: Wed, 20 January 2016, 16:56:41 »
Photoelectric was kind enough to paint a camo Filco top for my Filco Zero. However, the camo Filco top was slightly smaller than the Zero so I spent ages sanding it down so that it would fit. It's still not perfect and it scares me every time I remove it that it will snap. And it's really hard to get on as well.
Offline xondat
  • i'm not a star
« Reply #14420 on: Wed, 20 January 2016, 17:20:42 »
Did it.
Took some force and a blunt knife but did it. Thanks Cpt :thumb:
Offline joey
« Reply #14421 on: Wed, 20 January 2016, 18:05:40 »
Best way to get purple RF sliders?
Offline nmur
  • ಠ_ಠ
« Reply #14422 on: Wed, 20 January 2016, 18:08:52 »
gonna dremel out some bit from my TEX acrylic case.
anyone have a suggestion of what dremel bit I should use?
Offline Connly33
« Reply #14423 on: Wed, 20 January 2016, 18:18:42 »
Just from my experience with PC case modding, if your going to be cutting, either a straight router bit, or a mini saw attachment, depending on what you're doing exactly,  that has a medium teeth per inch count, to fine and it will just melt the acrylic, and not fine enough and it will just tear it up. For grinding corners or ridges down a medium fine planer bit is usually the best.
Custom 60% with Cherry MX Clear
Offline nmur
  • ಠ_ಠ
« Reply #14424 on: Wed, 20 January 2016, 18:26:41 »
ah okay thank you
I'm gonna be removing sections of the support ridges inside the case to allow room for RGB components on the underside of a PCB. so I might be using a combination of cutting and routing.
Offline swimmingbird
  • keyset hoarder
« Reply #14425 on: Wed, 20 January 2016, 21:30:50 »
Why are Korean customs so cheap to manufacture compared to in the USA/UK/etc?
Offline Melvang
« Reply #14426 on: Wed, 20 January 2016, 21:31:36 »
cheap labor isn't skilled, and skilled labor isn't cheap.
  • keyset hoarder
« Reply #14427 on: Wed, 20 January 2016, 21:34:07 »
Seems like they are skilled enough to make the most desired boards in the community (OTD, LZ)
Offline Melvang
« Reply #14428 on: Wed, 20 January 2016, 21:38:05 »
Really though, the reason is because labor is dirt cheap over there and corporate greed runs rampant over here.  The cost is in the tolerances.  For example with Sherlines benchtop mills and lathes, for them to increase the accuracy of their machines by ~5%, it would increase the cost of the machine by a factor of 10.
  • keyset hoarder
« Reply #14429 on: Wed, 20 January 2016, 21:43:49 »
That's really interesting
So are the high prices in Western markets such as the US mostly labor or is it that the accuracy of the machining is significantly better than what's typical in Korea?
Offline Melvang
« Reply #14430 on: Wed, 20 January 2016, 21:49:16 »
From what I have seen, both.  Cherry and Alps switches are very forgiving on the tolerances.  A lot of the shops that actually machine (not including water jet and laser) work to tolerances much lower than what these require.  For instance, with surface grinding, it is not uncommon at all to have to work to tolerances of +/-.0002".  Cherry switch tolerances are about 10 times that.  Even tighter tolerances are possibly fairly easily if you are willing to spend the time and money to get there.
Hell, I personally did a shaft alignment a month or so ago in the field, with shaft offset and angular missalignment errors of less than .001".  All depends on the tools you have.
  • keyset hoarder
« Reply #14431 on: Wed, 20 January 2016, 22:04:32 »
Man that's a ridiculous level of tolerance - is it typical for most US machining shops to work on these incredibly low tolerances?
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #14432 on: Wed, 20 January 2016, 22:19:23 »
All depends what's being machined. A friend of mine works in a tool and die shop (for some reason they also make parts for boat racing) and some of their tolerances are incredibly tight!
Offline klennkellon
« Reply #14433 on: Wed, 20 January 2016, 23:43:19 »
Can anyone directly compare Matias Click switches with the original Complicated White ALPS for me? I have used my ALPS board enough to think that I like the switches a lot for typing but would like to try something more modern in design.
« Reply #14434 on: Wed, 20 January 2016, 23:45:21 »
Is labor cheap in South Korea?
Offline tofgerl
« Reply #14435 on: Thu, 21 January 2016, 01:41:21 »
Are there any mass produced flat 60% cases? I have a feeling I would massively prefer a 0 incline keyboard, but it seems like it would be hard to do without going custom, and my piggy bank is not at that point yet.
I know the Planck is flat, so I'll get to try it in a few weeks :)
Offline Melvang
« Reply #14436 on: Thu, 21 January 2016, 01:49:47 »
  • keyset hoarder
« Reply #14437 on: Thu, 21 January 2016, 01:51:54 »
I think both the Tex Acrylic and the Tex Aluminum cases would be totally flat as long as you didn't put the feet on the end
Same thing for the Nerd 60 housing
Offline tofgerl
« Reply #14438 on: Thu, 21 January 2016, 01:54:16 »
Damn, wish I knew that before splurging on this (slightly cheaper than TEX) case:
https://www.massdrop.com/buy/60-keyboard-case
« Reply #14439 on: Thu, 21 January 2016, 12:49:16 »
I find that Complicated Whites are heavier and not as smooth as the Matias Click switches. I prefer Matias Click to Complicated Whites.
Offline xondat
  • i'm not a star
« Reply #14440 on: Thu, 21 January 2016, 13:12:01 »
Slightly on the topic of Korean customs, can anyone help me get quotes there? LeandreN & LSB said they're help but both have been busy :-[
Offline jd29
« Reply #14441 on: Thu, 21 January 2016, 14:42:34 »
Is anyone else getting "Gatekeeper returned an error code: bad_code" when trying to log into keyboard layout editor?
Offline tassadarforaiur
« Reply #14442 on: Thu, 21 January 2016, 15:44:01 »
Is the gt80 titan keyboard NKRO? All that MSI's website says is "steelseries anti-ghosting"
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14443 on: Thu, 21 January 2016, 17:36:04 »
Check the manual, it might have it there.
Offline Melvang
« Reply #14444 on: Thu, 21 January 2016, 19:36:05 »
We're 50 key IBMs made with F internals using the M style case, or did all the F versions have the 4704 style cast case?
« Reply #14445 on: Thu, 21 January 2016, 19:41:31 »
It was a cast metal plate IIRC
Offline Melvang
« Reply #14446 on: Thu, 21 January 2016, 19:43:51 »
Thanks CBA, I am assuming this one is M by the date on the label, but was F internals ever used in the same case?
http://m.ebay.com/itm/IBM-KEYBOARD-4707-50-KEY-POS-1392560-/172050888228?nav=SEARCH
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #14447 on: Thu, 21 January 2016, 21:02:44 »
For something cheaper than Tex you could grab this on AliExpress
  • keyset hoarder
« Reply #14448 on: Thu, 21 January 2016, 21:09:02 »
Why don't you see half plates that much in customs anymore?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #14449 on: Thu, 21 January 2016, 21:17:39 »
I only remember seeing it for one OTD (360?), The Cheat, and an attempt at it for TGR which was recent
