Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6278413 times)
0 Members and 7 Guests are viewing this topic.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #14150 on: Sun, 27 December 2015, 13:37:24 »
I have Topre artisans but no Topre board.
Is there a converter/slider that will allow Topre caps to fit on MX switches?
I know, of course, that the reverse is possible.
Sounds like you need some Topre keychains. ;)
Those are expensive from what I've seen.
« Reply #14151 on: Sun, 27 December 2015, 13:41:54 »
That all depends really. I need to quit being lazy and make some.
    • WTB/WTTF Thread
« Reply #14152 on: Sun, 27 December 2015, 13:44:32 »
Yeah I guess the ones I've seen are just expensive. I'd be up to buy a 45g one for a reasonable price.
Offline Solo
  • Unreal
« Reply #14153 on: Sun, 27 December 2015, 13:58:23 »
If these came with those assorted color Realforce caps, I probably would have purchased one.
« Reply #14154 on: Sun, 27 December 2015, 14:05:55 »
Had no idea those were available. Thanks for the link.
    • WTB/WTTF Thread
« Reply #14155 on: Sun, 27 December 2015, 14:13:03 »
I must have missed these when I last checked his page. Thanks for the link!
Offline piemancoder
« Reply #14156 on: Mon, 28 December 2015, 12:53:41 »
Can you put Topre keycaps on a Novatouch?
Yoda grammar best has
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #14157 on: Mon, 28 December 2015, 13:06:37 »
Nope. The insert is completely different.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Solo
  • Unreal
« Reply #14158 on: Mon, 28 December 2015, 13:08:04 »
To use Topre keycaps on a Novatouch, you would need to replace the Novatouch's MX-compatible sliders with original Topre sliders.
Offline piemancoder
« Reply #14159 on: Mon, 28 December 2015, 14:14:50 »
No fancy topre artisans then  :(
I'm guessing that you would have to get those from another Topre board?
Offline Solo
  • Unreal
« Reply #14160 on: Mon, 28 December 2015, 14:24:45 »
You would have to harvest them from another Topre board. :)
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14161 on: Mon, 28 December 2015, 15:05:15 »
And that would defeat the purpose of a Novatouch too.  :p
« Reply #14162 on: Mon, 28 December 2015, 16:31:06 »
lol yeah that's going the opposite direction.  :))
Offline ideus
  • Björkö.
« Reply #14163 on: Tue, 29 December 2015, 08:13:39 »
Counterproductive.
Offline pr1me
« Reply #14164 on: Tue, 29 December 2015, 11:33:52 »
I'm looking to put my novatouch stems into an FC660C.
I assume i have to do that with the stabilizers as well
Is there anything specific i need to know before doing that mod?
I already silenced my novaotuch with landing pads, so i know how it is inside.
I don't have the 660c in yet, so i don't know how the novatouch stabilizer will fit yet.
Also, will those 6x spacebar available on maxkeyboard fit?
Thanks
Offline bcredbottle
« Reply #14165 on: Tue, 29 December 2015, 11:52:10 »
The best bet is to trade for MX or try to get a hold of a Novatouch and some Topre sliders.
Thanks. Some artisans are hard to find in MX but I might try to get a μtron. If someone came out with a split Topre board for under $400 I'd snap that **** up.
Might actually buy this. If you make some I'll def buy.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14166 on: Tue, 29 December 2015, 12:25:54 »
There are some Epson split Topre on Yahoo Japan auctions going for about $100 right now.
Offline alienman82
« Reply #14167 on: Tue, 29 December 2015, 12:27:05 »
removed.
« Last Edit: Thu, 01 March 2018, 16:44:17 by alienman82 »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14168 on: Tue, 29 December 2015, 13:11:11 »
Price will go up
Might stay under the $400 limit though.
Offline alienman82
« Reply #14169 on: Tue, 29 December 2015, 13:12:03 »
removed.
« Last Edit: Thu, 01 March 2018, 16:44:13 by alienman82 »
Offline Solo
  • Unreal
« Reply #14170 on: Tue, 29 December 2015, 13:52:22 »
Thanks
You can transplant the Novatouch's components (sliders/stabilizer housings) directly into the FC660C. You don't have to drill/file anything like you would if you were trying to do the same thing on an HHKB.
As far as the spacebar goes, and as far as I'm aware, 6u Cherry spacebars with centered stems don't exist. The FC660C uses a spacebar with a centered stem, so you'll be stuck either using the stock spacebar, or one from another Topre board.
Offline bcredbottle
« Reply #14171 on: Tue, 29 December 2015, 14:11:37 »
You mean this?
http://page6.auctions.yahoo.co.jp/jp/auction/f167947011
Looks cool but I need a board that's split down the middle (i.e. the alphas are divided in two).
Offline alienman82
« Reply #14172 on: Tue, 29 December 2015, 14:18:39 »
removed.
« Last Edit: Thu, 01 March 2018, 16:44:10 by alienman82 »
Offline mason
  • have fun with her, ryan
« Reply #14173 on: Tue, 29 December 2015, 16:17:00 »
Is there a way to lock the fn key on an hhkb? i.e. press fn once then you can use arrow keys and press fn again once you're done
Offline xondat
  • i'm not a star
« Reply #14174 on: Tue, 29 December 2015, 16:39:27 »
Where can I get keyboard opinions in mass from? Need to ask questions such as tilt, piece count etc...
Offline pr0ximity
« Reply #14175 on: Tue, 29 December 2015, 16:47:05 »
A poll in your own thread in the appropriate forum here would work decently well. Or a survey that you could try to peddle over on reddit as well.
Offline xondat
  • i'm not a star
« Reply #14176 on: Tue, 29 December 2015, 16:48:12 »
Cheers, is Google forms is a good platform for this?
Offline pr0ximity
« Reply #14177 on: Tue, 29 December 2015, 17:12:28 »
It's the one I see most I think, though I've never used it personally.
Offline pr1me
« Reply #14178 on: Tue, 29 December 2015, 20:26:00 »
Thanks
Thanks  :thumb:
Offline Sus
« Reply #14179 on: Wed, 30 December 2015, 10:53:28 »
Hey,
What's the standard pok3r resistors rated at? I know that the PCB has presoldered resistors for bright LED's, so are the individual resistors 470 ohm?
I'll check that with a multimeter when my kb arrives if noone has first-hand experience ;D
Offline xondat
  • i'm not a star
« Reply #14180 on: Wed, 30 December 2015, 14:41:21 »
What options do I need on the winkeyless 60% board to have it work when I solder my own switches in?
« Last Edit: Wed, 30 December 2015, 17:10:49 by xondat »
Offline swimmingbird
  • keyset hoarder
« Reply #14181 on: Wed, 30 December 2015, 19:04:26 »
Depends on whether you want to have lighting or not but if it's just switches you need to have diodes and controller parts soldered
Offline xondat
  • i'm not a star
« Reply #14182 on: Wed, 30 December 2015, 19:07:04 »
So this?
  • keyset hoarder
« Reply #14183 on: Wed, 30 December 2015, 19:08:22 »
So this?
Oh and stabilisers if you don't have them yourself
Offline xondat
  • i'm not a star
« Reply #14184 on: Wed, 30 December 2015, 19:32:01 »
So this?
Cheers, are the resistors for LEDs?
  • keyset hoarder
« Reply #14185 on: Wed, 30 December 2015, 19:36:42 »
So this?
Exactly  :thumb:
Offline piemancoder
« Reply #14186 on: Wed, 30 December 2015, 20:37:00 »
How do people make the drawings for interest checks to show the colors and layouts, and how do they draw the novelties?
Offline mason
« Reply #14187 on: Thu, 31 December 2015, 16:53:50 »
Easy way to repair a stretched out coiled cable?
« Reply #14188 on: Thu, 31 December 2015, 17:04:50 »
I have had moderate success by wrapping it tightly around a wooden dowel and letting it relax for a while. If possible, lay it out in the sun on a railing or something and let it cycle through hot and cold a few times.
- D Trump 2026-10-24
Offline trustinkiss
« Reply #14189 on: Fri, 01 January 2016, 04:25:33 »
Anybody know if the Duck Octagon case will fit any 75% layout PCB? For example, a Keycool 84 PCB fitting into an Octagon case?
Offline Eszett
« Reply #14190 on: Fri, 01 January 2016, 07:18:40 »
Can you tell me please what's the difference in meaning between the terms "sampling, scanning, probing" in respect to a keyboard's matrix?
« Last Edit: Fri, 01 January 2016, 07:20:38 by Eszett »
Offline Vozella
« Reply #14191 on: Fri, 01 January 2016, 22:45:11 »
Where can I learn more about LED changers?
Offline Akamig
  • It's A-ka-meegh, Not AKA Mig.
« Reply #14192 on: Sat, 02 January 2016, 08:10:09 »
Um... I found the deal selling industrial Model M (1394946).
It's about 105000 Won (100$), and I'm really considering bite this or not.
If I bite this, my whole custom TKL project will canceled. but got nice full-fatty-sized keyboard without super key, but look! dat gray color is fabulous!
but not bite this, at least I can wait untill TEX release new Aluminum TKL Cases. but Model M will gone forever, mayby.
what you gonna do if you were me?
Not Aka"MLG 360 NO SCOPE GET REKT" either.
http://steamcommunity.com/id/Akamig/
« Reply #14193 on: Sat, 02 January 2016, 09:42:01 »
You should be able to re-sell the industrial for a profit, if it is complete, undamaged, and working properly.
Offline Akamig
« Reply #14194 on: Sat, 02 January 2016, 10:17:54 »
yeah... I heard that gray one is expensiver than normal Model M
but is it that much?
I think shipping fee would be around 30$, so it must worth at least 130$ or moar?
Offline xondat
  • i'm not a star
« Reply #14195 on: Sat, 02 January 2016, 16:06:21 »
Do you mean SIP sockets? https://geekhack.org/index.php?topic=51792.0
MY Q: How do you take apart the WASD V2?
Offline jerue
  • (Whenever that happens :P)
« Reply #14196 on: Sat, 02 January 2016, 20:11:11 »
Hopefully a similar question for those who have had both sets of these keycaps:
Do the Cherry lasered PBT really *feel* similar to OG dyesubs? I know the looks are awful, curious about feel.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14197 on: Sat, 02 January 2016, 20:31:25 »
I know this question has probably been asked a thousand times but is there a substance that will dissolve ink from keycaps but not ABS/PBT?
Offline trenzafeeds
  • **** off
« Reply #14198 on: Sat, 02 January 2016, 20:34:12 »
To me they don't feel as silky smooth as dyesubs do, but I could also just be imagining that.
demik will never leave.
Unless he gets banned.
« Reply #14199 on: Sun, 03 January 2016, 03:25:00 »
A couple of threads with some ideas:
https://geekhack.org/index.php?topic=51958.0
https://geekhack.org/index.php?topic=59676.0
