Author Topic: Removing Dye/Ink/Paint from Backlit keycaps...  (Read 16292 times)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« on: Wed, 18 June 2014, 13:03:50 »
I am looking to try to remove the 'painted material' from some backlit keycaps. What would be a good solvent to use that won't damage or melt the plastic (i.e. Acetone)?
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline cmadrid
Re: Removing Dye/Ink/Paint from Backlit keycaps...
« Reply #1 on: Wed, 18 June 2014, 13:11:43 »
Not sure it would work on keycaps, but I googled how to get spray paint off of my hand, and ended up using a paper towel with a little bit of vegetable oil on it, lol
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2 on: Wed, 18 June 2014, 13:15:47 »
Acetone can and will dissolve the caps unless they are PBT.
Offline 00zeRO
« Reply #3 on: Wed, 18 June 2014, 13:16:30 »
If that would work, then we would have a lot of returned keyboards for people having their paint chip off because you do not want to know how many greasy fried chicken fingered keyboards we have had to process even for repair work, yuk!
Offline 00zeRO
« Reply #4 on: Wed, 18 June 2014, 13:17:26 »
That was why I put Acetone as an example of melting keycaps, sir... :thumb:
Offline cmadrid
« Reply #5 on: Wed, 18 June 2014, 14:27:23 »
Lol, when my son starts trying to use my pc instead of just his tablet I'm going to have to start swapping keyboards.  Greasy hands on my keyboard noooooo
Offline cmadrid
« Reply #6 on: Wed, 18 June 2014, 14:41:33 »
I looked around google for a while, and saw some suggestions for laquer thinner or dot 3 brake fluid for getting paint off of abs.  I haven't tried this myself, so I can't say for sure if it works or not!
Offline 00zeRO
« Reply #7 on: Wed, 18 June 2014, 14:52:39 »
I will definitely try the brake fluid. Thanks.
Offline cmadrid
« Reply #8 on: Wed, 18 June 2014, 15:01:59 »
Saw this advice on a auto forum..
Here's what I'd suggest. Get a foam (EPS = Expanded Polystyrene) coffee cup, pour in whatever chemical you want to strip with. If it doesn't melt the cup it will probably be safe on ABS as Styrene is more sensitive than ABS
Offline Oobly
« Reply #9 on: Thu, 19 June 2014, 02:25:35 »
Y, I think brake fluid will do it, DOT3 is best, DOT4 can damage most plastics... However, Castrol Super Clean is better. Many people use this stuff on plastic models and miniature figures when they want to strip and repaint them.
1. Wear nitrile rubber gloves. Important, this stuff will burn your skin. If you are using brake fluid, it can be absorbed through the skin and is toxic....
2. Soak the caps in it for a while (leave it long enough to soften the paint all the way through, overnight is probably a good choice).
3. Use a toothbrush to rub off the paint.
4. Wash with warm soapy water and rinse. Job done.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline 00zeRO
« Reply #10 on: Tue, 01 July 2014, 21:28:08 »
No dice. These Ducky ABS monsters are very resilient to Brake fluid, Non-Acetone Nail Polish remover, pure Acetone...the dye material ain't budging.
Okay, maybe around the edges, but it is not coming off easily at all...
Any more suggestions...
Offline Melvang
« Reply #11 on: Tue, 01 July 2014, 21:58:18 »
Very fine sandpaper.  I am talking in the realm of 1000 grit or higher.  Do this wet as well.
Offline 00zeRO
« Reply #12 on: Tue, 01 July 2014, 22:01:03 »
too much work...kudos to Ducky for making keycaps so resilient though...
 :thumb:
(by the way, these are leftover keycaps from a custom we did, and are not English <translation: not a big seller>)
