Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6278760 times)
« Reply #13950 on: Sat, 05 December 2015, 19:57:36 »
I do agree with all your points here, fohat (I always read your name as foghat),
The Northgate was white Alps. A blue Alps under $200 would be a good deal.
http://www.teosofia.com/Mumbai/7208fohat.html
https://en.wikipedia.org/wiki/Foghat
- D Trump 2026-10-24
Offline E3E
« Reply #13951 on: Sat, 05 December 2015, 20:07:47 »
The gold label Omnikey 102s typically have blue alps, fohat.
Here's one and here's another.
Also, that must be where I kept getting "foghat" from, hahaha. Thanks for the clarification, as they are two very different things. XD
« Last Edit: Sat, 05 December 2015, 20:10:37 by E3E »
« Reply #13952 on: Sat, 05 December 2015, 20:22:05 »
Your link is not gold label, and the seller even noted "white" Alps.
Offline trenzafeeds
  • **** off
« Reply #13953 on: Sat, 05 December 2015, 20:27:58 »
Out of curiosity, what is so special about blue alps?
demik will never leave.
Unless he gets banned.
Offline E3E
« Reply #13954 on: Sat, 05 December 2015, 20:30:46 »
It's not?
 Because it seems that way to me.
No mention of white Alps here. Perhaps the link got broken since it's a board I sent an offer on or perhaps you're looking in the wrong place.
Blue Alps, like most of the older complicated Alps varieties, have a long contact plate, which imo gives a more solid and stable feel to the switch. Blue Alps has a light-ish 65g actuation and a click that sounds very refined.
Unlike Cherry MX, which uses a two-piece slider that slaps into itself to create the click, Alps switches use metal click leaves (leaf springs). Blue Alps combines a light actuation with a solid feel, nice tactility and clickiness. It somehow just got it all right. :P
They're very popular for those reasons, I guess. I haven't found another Alps clicky switch that quite matches blues.
« Last Edit: Sat, 05 December 2015, 20:39:23 by E3E »
« Reply #13955 on: Sat, 05 December 2015, 20:42:26 »
As E3E said, they're really solidly built and smooth-operating clicky switches so they're nice.  CPTBadAss also accidentally hyped them up a bunch after he tried some, which raised people's attention to them.  akimbo also hosted a tour for a blue alps board, which got them into people's hands to try.
quality switch + exposure + hype = high demand
Offline trenzafeeds
  • **** off
« Reply #13956 on: Sat, 05 December 2015, 20:43:24 »
And I'm guessing also lack of supply?
« Reply #13957 on: Sat, 05 December 2015, 20:44:36 »
Yep, that too.  They're not a super common alps switch and they're snatched up pretty quick.  IIRC, going rate is $1+/switch.  Getting a board to harvest switches from for $100 is a good deal.
Offline E3E
« Reply #13958 on: Sat, 05 December 2015, 20:52:02 »
Yeah. They're not exactly the most uncommon of the Alps switches, but they are probably the highest in terms of demand, so it makes it even harder to get one if they do pop up. Bidding wars are fierce and people are quick to snatch up BIN deals.
They do come around pretty often though, you just have to keep an eye out for them. Talking with people who have gotten boards from e-cyclers, it seems they tend to find more blue alps than green alps for whatever reason. This coming from two US haulers and one from Australia. No idea why green Alps seem harder to find out in the wild offline world.
Offline Vozella
« Reply #13959 on: Sat, 05 December 2015, 23:05:28 »
What is Satan GH60? I can't find any information on it.
Offline davkol
  •  Post Editing Timeout
« Reply #13960 on: Sun, 06 December 2015, 05:06:02 »
Try to google "satan gh60 site:geekhack.org". One of the top threads here.
tl;dr It's an actually available Asian implementation of GH60, the DIY 60% keyboard, that originated here (thus the name) and became infamous for group-buy length (competing with 7bit's GBs).
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #13961 on: Sun, 06 December 2015, 14:12:00 »
However, I believe that it is one revision behind the production GH60.
Offline tofgerl
« Reply #13962 on: Sun, 06 December 2015, 14:15:33 »
It is also not stictly software compatible with the normal GH60 TMK repo, so you need to tweak a few things.
However, I think it has the same features, though not the same layout.
« Reply #13963 on: Sun, 06 December 2015, 14:57:51 »
I remember someone swapping their screws on their Kingsaver from this site, but I forget what size/length screws they were.
Offline alienman82
« Reply #13964 on: Mon, 07 December 2015, 09:46:17 »
removed.
« Last Edit: Thu, 01 March 2018, 16:52:07 by alienman82 »
Offline Jixr
« Reply #13965 on: Mon, 07 December 2015, 10:50:56 »
cheapest place to get 100 mx blues ( or gaterons, don't care )
« Reply #13966 on: Mon, 07 December 2015, 10:51:49 »
MK.com or Amazon for Gaterons.
Offline E3E
« Reply #13967 on: Mon, 07 December 2015, 10:55:17 »
https://mechanicalkeyboards.com/shop/index.php?l=product_list&c=56
I can't seem to find any Gateron blue switches on Amazon atm. It's like the only one they don't have in stock. No browns either!
« Reply #13968 on: Mon, 07 December 2015, 14:56:24 »
Any one know what size the bolts are that screw into blockers such as KMAC 1.2 and Duck boards?
I believe it's M3x6mm but I just wanna double check. I'm not sure if it's M2 or M3.
Offline tofgerl
« Reply #13969 on: Tue, 08 December 2015, 01:54:26 »
For Pok3r-compatible cases it's usually M2x6, but those spacers are built into the bottom of the board, so I'm not sure those are the same as the ones you mean.
Offline ika
« Reply #13970 on: Tue, 08 December 2015, 02:02:01 »
normally Corus-KB stocks them but I guess they're out of stock. The latest massdrop is going to land within the week though so there will probably be some people selling theirs soon.
Offline tofgerl
« Reply #13971 on: Tue, 08 December 2015, 02:14:42 »
I wonder if Gateron are running into supply chain issues due to success...
Offline Jixr
« Reply #13972 on: Tue, 08 December 2015, 10:39:25 »
I'll just pick up some cherrys, i really just need them for the stems and springs.
And while gaterons feel better out of the box, broken in cherry housings are much nicer to me.
« Last Edit: Tue, 08 December 2015, 10:45:35 by Jixr »
Offline jonathanyu
« Reply #13973 on: Tue, 08 December 2015, 17:39:37 »
i believe it's m3
Offline xondat
  • i'm not a star
« Reply #13974 on: Tue, 08 December 2015, 18:18:26 »
Is there a database for all keycap sets and/or sold artisans?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #13975 on: Tue, 08 December 2015, 18:27:24 »
It would be an impossible task to maintain a list of every keycap set ever but you can check the DT wiki and retailers.
Offline byker
  • Literally Canada
« Reply #13976 on: Tue, 08 December 2015, 18:30:26 »
There is this site, not sure how comprehensive it is though. http://keypuller.com
Offline trenzafeeds
  • **** off
« Reply #13977 on: Tue, 08 December 2015, 18:36:34 »
They're working on it. Pretty solid for your basic cap sets, I think artisans are coming along, but nowhere close to the individual catalogues you might be able to dig up on GH if you search hard enough.
Offline nmur
  • ಠ_ಠ
« Reply #13978 on: Tue, 08 December 2015, 18:42:21 »
there's no giant list with all artisans, but some particular designs/makers have pretty extensive catalogues, eg this awesome BBv2 catalogue
Offline xondat
  • i'm not a star
« Reply #13979 on: Wed, 09 December 2015, 05:31:22 »
Didn't realize there were so many V2s never mind other ones. Just thought it'd be a fun Christmas project but seems more than a months work. I'll do some more research before I build anything :thumb:
« Reply #13980 on: Wed, 09 December 2015, 08:38:53 »
i believe it's m3
yeah I ordered m3, that's what I thought as well. Thanks yo
Offline ideus
  • Björkö.
« Reply #13981 on: Wed, 09 December 2015, 08:49:26 »
Does someone know which set is this one? and if there is something similar that is comercially available in double shot? In particular I am interested in that caps lock style with 1.5u step.
That's an Alps keyset, ideus. Those are caps from the SGI Granite. I call that style of stepping "Alps stepped," since it is different from Cherry's kind of stepping and is only seen on OEM Alps boards. You won't see Cherry-stepped caps on any Alps boards and vise versa, as far as I know.
The Duck Mini allowed either Alps or Cherry MX.
Thank you for the feedback. Someone offered me a set but I do not have any ALPS keyboard anymore, but I like that type of stepped capslock with 1.5u top.
Offline tofgerl
« Reply #13982 on: Wed, 09 December 2015, 10:03:43 »
I have a switch on a homemade board which I've assembled, but not used much since I (STILL) don't have the stabilizers.
The switch doesn't activate when I press the button normally, only when I first press it all the way down, THEN push really hard. Does that sound like something that can be fixed without soldering, or should I replace the switch right away?
I'd just replace the switch.
I finally got around to it, and it turns out it was a bad soldering job. The solder hadn't covered the pin, but was aaaaaaaaaalmost touching it. Every time I pressed hard down, I also pressed the PCB down since the board is plateless, and the solder touched the pin.
Anyway, I didn't have to replace the switch :)
Offline BlueNalgene
« Reply #13983 on: Wed, 09 December 2015, 19:19:15 »
Has anyone taken a custom board in carry-on luggage before?  I'm going out of the country for a week+ with only a tablet.  I'm worried that TSA might give me grief for having a suspicious bare circuit.
Offline alienman82
« Reply #13984 on: Wed, 09 December 2015, 19:30:06 »
removed.
« Last Edit: Thu, 01 March 2018, 16:51:26 by alienman82 »
Offline swimmingbird
  • keyset hoarder
« Reply #13985 on: Wed, 09 December 2015, 19:31:08 »
I've carried both a Gon Nerd 60 with my terrible soldering and an HHKB in the same carry on bag and didn't experience any problems
Offline BlueNalgene
« Reply #13986 on: Wed, 09 December 2015, 19:45:23 »
Thanks.  I didn't want to lose one of my babies!
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #13987 on: Wed, 09 December 2015, 19:52:27 »
Worst case, they make you take it out and price it is a functioning keyboard.
« Reply #13988 on: Wed, 09 December 2015, 20:05:04 »
I carried 3 custom keyboards with me to Keycon this year. And several bare PCBs. And some switches on the way home. I never check luggage, and I didn't have one problem.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #13989 on: Wed, 09 December 2015, 20:26:07 »
I actually did get stopped at the airport with my massive xerox board. But I'm sure just carrying any small regular board you'll be fine; frankly I just think I got a bit unlucky.
« Reply #13990 on: Wed, 09 December 2015, 21:16:07 »
For full keyboard backlighting, what is the common implementation of resistors?  What I mean is each led has its own, one resistor for a group, one for the entire board.
Does the common convention from mass produced boards follow into custom community driven boards or does it change?
Does anyone know about how much current a USB teensied board with mx switches draws?
Does the layout size affect current draw?
Simple questions man...
I have yes. It wasn't an issue. The Xray guy just gets confused.
Mod Edit: Fixed a double post.  Hi CPT.
« Last Edit: Wed, 09 December 2015, 21:41:10 by infiniti »
Offline tofgerl
« Reply #13991 on: Thu, 10 December 2015, 02:43:17 »
I confused the hell out of them once by carrying an old pendulum clock through customs. They couldn't make heads or tails of it even after I took it out and showed it to them. The insisted I put the pendulum and weights on it before they understood it.
I think it would have been faster if I just said 'it's a bomb, here's 20 bucks'.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #13992 on: Thu, 10 December 2015, 16:18:01 »
« Reply #13993 on: Thu, 10 December 2015, 16:19:43 »
Any of these worth considering?
http://sanantonio.craigslist.org/sys/5336906689.html
As a keyboard nerd? Meh. The switches kinda feel like variants of MYs.
As a vintage computer nerd? Yeah
As a retro game enthusiast? **** yes
Edit: I got so excited when I looked over the haul again. That's vintage computing and video game gold.
« Last Edit: Thu, 10 December 2015, 16:21:54 by CPTBadAss »
Offline Bromono
  • Wanabe Cicerone
« Reply #13994 on: Thu, 10 December 2015, 16:22:46 »
Hmmmmm... Noted...
What would be the most valuable thing in the lot? the Commodore looks cool
Offline Dernubenfrieken
« Reply #13995 on: Thu, 10 December 2015, 16:50:05 »
The TI-99/4A Might have T-Stem Alps which are pretty nice.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #13996 on: Thu, 10 December 2015, 17:07:25 »
They used too many switch types in them though, I have six of them; three with Alps SKCC, two with rubber dome, and one with Mitsumi.
Offline Vozella
« Reply #13997 on: Thu, 10 December 2015, 20:52:46 »
Before I start a dedicated thread, I must ask. Is it possible to cut off the numpad of a membrane keyboard and have it still work?
Offline alienman82
« Reply #13998 on: Thu, 10 December 2015, 20:54:00 »
removed.
« Last Edit: Thu, 01 March 2018, 16:51:13 by alienman82 »
« Reply #13999 on: Thu, 10 December 2015, 20:54:05 »
hmmm....I know with like a Model M you can fold the membrane back and with keyboards with PCBs, you can rewire them to work. I don't see why it wouldn't but I don't know 100%.
