Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6278754 times)
« Reply #13900 on: Thu, 03 December 2015, 08:54:40 »
Having the option to remap a second or third layer key assignments is not the same as having full keyboard programability. The confusion comes from manufacturers that use the term programmable keyboard to describe a keyboard featuring layer remapping capabilities. A programmable keyboard allows the user to define all key assignments with no restrictions.
That's a great way to put it. Thanks :)
Offline tofgerl
« Reply #13901 on: Thu, 03 December 2015, 08:58:34 »
I don't think Vortex are saying the Pok3r is programmable? They talk about "increased programmability" and I would agree with that statement, but what I would REALLY call it is "remappable with macro functions".
For example, no matter what I do, I can't get a pok3r to send a Mac media key code. That's a simple edit in TMK. (And then a far from simple compilation and uploading, but if you're going to make your own keyboard, those are the breaks :)
Offline element72
« Reply #13902 on: Thu, 03 December 2015, 09:37:16 »
Very nice explanation. I'm looking at the pok3r manual to see how I can make the arrow keys like the pure pro and my brain is farting because I'm looking at the DIP switch functions and I'm still very new to this. Is it possible? I want the left, down, and right arrow keys on either of the 4 right-side keys of the spacebar. Also if you look at the very bottom of the manual it has a feature for arrow keys kinda like how I wanted. Is that extra feature a toggle or do I have to hold r_alt + spacebar ?
Edit: I am really trying to understand what exceptions there are to remapping the keys. It seems to me that the r_ctrl  is something you can't change because it is used to enter and exit programming mode.
« Reply #13903 on: Thu, 03 December 2015, 09:39:44 »
It's a momentary thing. So you'd have to hit function + layer 2 key. Anything not on the main layer will be like that unless there's a way to toggle on the secondary layer and stay there always. Think about how a laptop's layers work. When you have an up and down arrow that also doubles up as like brightness adjustment.
Offline tofgerl
« Reply #13904 on: Thu, 03 December 2015, 10:02:29 »
If you switch layers, it won't change back uness you manually do so. No matter what. Take out the cable, dismount the board and put it back together again. It will stay there.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #13905 on: Thu, 03 December 2015, 11:41:28 »
Since the site was reverted it looks like my question was deleted so I'll ask again: Does anyone know what profile this keycap is?
Offline ideus
  • Björkö.
« Reply #13906 on: Thu, 03 December 2015, 11:46:27 »
You should have some known key-caps besides it to compare, without that reference it is very hard to tell. With that warning, it looks like a top row (function row) or row 1 in DCS, OEM or Cherry.
« Last Edit: Thu, 03 December 2015, 11:50:53 by ideus »
« Reply #13907 on: Thu, 03 December 2015, 11:47:28 »
Maybe the KT profile from SP? If not, maybe this thread helps
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #13908 on: Thu, 03 December 2015, 13:58:06 »
That looks like it might be it. It came from an editing board and I've never seen the flat backside before. The keycaps are doubleshot and they look just like SP caps.
Sorry, I don't even really know what profile the rest of my keyboards have. It is R4, from the top of a video editing board.
Offline E3E
« Reply #13909 on: Thu, 03 December 2015, 20:46:25 »
What's the opinion on Vintage MX Blues/Whites compared to their modern counterparts? I know that the oldest blues apparently lacked dye and thus were translucent.  I'm trying to figure out whether I want to use my linear Zealios as is for my next Octagon, or throw in some vintage clear stems, or some vintage white stems.  I want the switches to be completely colorless. :D
From my experience with vintage clears and blacks, there is more of a smoothness, though whether that's from being worn in or not, I can't say.
Offline ctm
  • Hello, world!
« Reply #13910 on: Thu, 03 December 2015, 20:47:44 »
Is there a way to determined the year of manufacture of a Kinesis board? I got one with serial number 30127CMD. Curious about when this board was made.
Coming:
Ellipse Model F F62.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #13911 on: Thu, 03 December 2015, 21:14:11 »
Vintage blues don't really feel too different to me. They might feel a wee bit smoother but that's probably just from the wear and not a difference in the mold. I could be wrong about this but I don't think Blues were ever clear. I do have a vintage white switch with a translucent slider though and it feels almost linear even with the bump and click. I moved the stem into a modern blue switch bottom and it has a nice smooth click. Good luck finding any vintage white stems though, they are as rare as Blue Alps if not rarer. Indeed, I've never seen a full board with vintage whites. You might look at buying some Gateron stems since they are translucent.
Offline E3E
« Reply #13912 on: Thu, 03 December 2015, 21:17:47 »
I've got a good source on a board with these babies in them, so I think I might just buy that :)  I love linear switches, so the way you describe them sounds quite nice. The linear Zealios have translucent stems as well, which is a huge reason I picked them.
« Last Edit: Thu, 03 December 2015, 21:20:44 by E3E »
« Reply #13913 on: Thu, 03 December 2015, 21:55:46 »
Mr Kinesis himself (Input Nirvana) says that it's late 90's vintage. But to get a more accurate date of manufacture, you'll have to contact Kinesis themselves. The contact is techsupport@kinesis.com
« Last Edit: Thu, 03 December 2015, 22:02:53 by CPTBadAss »
Offline ctm
  • Hello, world!
« Reply #13914 on: Thu, 03 December 2015, 22:02:47 »
Thanks a lot!
Coming:
Offline davkol
  •  Post Editing Timeout
« Reply #13915 on: Fri, 04 December 2015, 07:06:15 »
https://geekhack.org/index.php?topic=72626.0
Offline Hzza
« Reply #13916 on: Fri, 04 December 2015, 07:32:35 »
Probably pushing the simple part a little but thought I'd try here first...
I've got a plate from a Dell AT102w that I want to use with my Alps64; if I wanted to mod the bottom row to be winkeyless could I just remove the vertical parts of the plate in between the switches like they do on universal Cherry plates or would this affect the switches stability?
119072-0
« Last Edit: Fri, 04 December 2015, 07:35:09 by Hzza »
« Reply #13917 on: Fri, 04 December 2015, 08:43:48 »
I'm actually not sure. In theory it sounds fine but I'm not 100% on how the Alps switches mount.
Offline Hzza
« Reply #13918 on: Fri, 04 December 2015, 08:49:26 »
That's what I was thinking...maybe I'll try it by splitting the backspace and then try it on the bottom row if it works OK. I'll keep you posted :D.
« Last Edit: Fri, 04 December 2015, 08:52:46 by Hzza »
« Reply #13919 on: Fri, 04 December 2015, 09:16:02 »
The problem you're going to have, even if the swtiches clip into the plate (which I think they will), is that the spacebar switch position for the 7u spacebar is different from the 6.25u position. You're going to need new stabilizer holes in the plate.
Offline Hzza
« Reply #13920 on: Fri, 04 December 2015, 09:19:35 »
Oh balls, I never even thought of that...thanks JD.
Offline E3E
« Reply #13921 on: Fri, 04 December 2015, 11:19:42 »
I use universal plates for two Alps builds of mine. It won't affect anything in practical experience unless you forcibly push forward against a key (Alps like to rock ;)). Overall, I think the difference is pretty negligible and I'm happy with the stability! YMMV.
Testing it now.  ...Even pushing forward barely does much compared to a switch that is securely "land locked" by a plate. I'd say go for it. :D
EDIT: Er, like JD said, stabilizing might be an issue. For my builds, I used alps keys that had cherry stab mounts and used PCB-mounted cherry stabilizers. If you could find a way to create stab positions in the plate for 6.25u 7u, then you should be alright.
« Last Edit: Fri, 04 December 2015, 11:23:35 by E3E »
Offline Hzza
« Reply #13922 on: Fri, 04 December 2015, 13:19:47 »
Ah cool, good to know it works in theory. I've got a spare plate so I'll give it a go and try and figure out something for the spacebar stabs.
Offline ideus
  • Björkö.
« Reply #13923 on: Fri, 04 December 2015, 17:09:08 »
Does someone know which set is this one? and if there is something similar that is comercially available in double shot? In particular I am interested in that caps lock style with 1.5u step.
Offline E3E
« Reply #13924 on: Fri, 04 December 2015, 17:41:56 »
That's an Alps keyset, ideus. Those are caps from the SGI Granite. I call that style of stepping "Alps stepped," since it is different from Cherry's kind of stepping and is only seen on OEM Alps boards. You won't see Cherry-stepped caps on any Alps boards and vise versa, as far as I know.
The Duck Mini allowed either Alps or Cherry MX.
« Last Edit: Fri, 04 December 2015, 17:43:45 by E3E »
Offline Vozella
« Reply #13925 on: Fri, 04 December 2015, 17:45:17 »
Does making a custom keyboard with plate mounted switches and no PCB still require soldering?
« Reply #13926 on: Fri, 04 December 2015, 18:04:29 »
Of course! In fact, it requires an amount of soldering and a technique that some would consider difficult and/or tedious.
Soldering switches to a PCB is far and away the easier route.
Offline Vozella
« Reply #13927 on: Fri, 04 December 2015, 18:32:56 »
Are there any videos instructing how to do it? I have trouble learning how to do something when I can't see it visually. WhiteFireDragon only has videos of PCB keyboards.
Offline Roibhilin
  • Saver of Humens
« Reply #13928 on: Fri, 04 December 2015, 18:43:46 »
Is the meta key on the HHKB useless if I use windows and don't program?
QFR | Poker II | Quickfire TK
« Reply #13929 on: Fri, 04 December 2015, 19:18:09 »
If you set it to "Windows Mode" (SW1 ON, SW2 OFF - IIRC) then the meta key will act as the Windows Key.  :thumb:
Offline alienman82
« Reply #13930 on: Sat, 05 December 2015, 10:24:17 »
removed.
« Last Edit: Thu, 01 March 2018, 16:52:30 by alienman82 »
Offline trenzafeeds
  • **** off
« Reply #13931 on: Sat, 05 December 2015, 10:25:15 »
Can one retrobrite Cherry doubleshots?
I believe yes
demik will never leave.
Unless he gets banned.
« Reply #13932 on: Sat, 05 December 2015, 10:30:08 »
Yes, one can retrobrite any ABS.
Offline alienman82
« Reply #13933 on: Sat, 05 December 2015, 10:34:06 »
removed.
« Last Edit: Thu, 01 March 2018, 16:52:27 by alienman82 »
Offline Vozella
« Reply #13934 on: Sat, 05 December 2015, 12:12:28 »
Are there none?
Offline tofgerl
« Reply #13935 on: Sat, 05 December 2015, 12:15:57 »
Not on youtube that I've seen, but I've got this bookmarked: http://deskthority.net/workshop-f7/brownfox-step-by-step-t6050.html
I ended up buying Satan GH60s at 30 bucks each, and I'm very glad I did. I would have spent a weekend being frustrated and getting my fingers burned otherwise.
« Reply #13936 on: Sat, 05 December 2015, 12:35:53 »
Are there none?
Yup, That's what I'd use to learn how to handwire boards. Also this thread.
Offline Vozella
« Reply #13937 on: Sat, 05 December 2015, 15:03:25 »
What is Satan GH60? I can't find any information on it.
Offline chiptea
« Reply #13938 on: Sat, 05 December 2015, 16:23:28 »
Hi, I've got a quick question.
I found a pretty good deal on some model Ms, but I've got an issue with them. On the top right of the boards, there are some numbers and letters engraved into the plastic. They are not too deep, so I was wondering if there was a way of filling the marks with some kind of putty, sanding it a little to match the texture, and dab some paint on it? Maybe someone has done something like this? Any help is appreciated!
« Reply #13939 on: Sat, 05 December 2015, 17:29:04 »
My advice is: "Don't try to put lipstick on a pig."
If you are selling them, discount the price by $5 and let the buyers make their best try at it.
If I had one, depending, my first thought would be to glue something over it. I have a "Geekhack" plastic badge-type label, and a larger metal "Impala" badge that I have been wondering what to do with.
If you are determined to do something yourself, less is always better than more.
- D Trump 2026-10-24
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #13940 on: Sat, 05 December 2015, 17:39:02 »
You might consider some silicone too.
Offline E3E
« Reply #13941 on: Sat, 05 December 2015, 17:46:00 »
Sanding it isn't going to match any speckled texture if that's what the Model M has. While restoring my FAME keyboard, the texture got sanded off thanks to trying to remove a stain that went deeper into the plastic than I had realized. In order to restore the texture to the board, I sanded off all the original texture and using some matte clear coat (Eastwood 2K urethane aerosol), and it worked really well (idea came from perusing Photoelectric's painting thread). I've heard that a light sandblasting can give plastic texture again too.
Caveat here is that the FAME didn't have heavy texturing on it like some boards I've seen where they practically look like they have tiny scales, so it didn't take much. I don't know how the Model M's texture is. You could try filling it in with an epoxy putty, or plast-aid, but you're looking into far more work than you realize if you want to try and blend it in and paint and retexture it. Especially if this is just to resell.
I'd say be straight up with your customers and just sell what you have. If this was for a personal restoration project, I'd be all for it, but if this is just for profit, er... People do bump up prices heavily for restored boards.
« Last Edit: Sat, 05 December 2015, 17:50:39 by E3E »
Offline chiptea
« Reply #13942 on: Sat, 05 December 2015, 18:07:13 »
Thanks for the advice guys. I guess I should have specified: I don't think removing the etchings on an SSK is putting lipstick on a pig  :p It sounded like I had regular old model Ms now that I look back. Sorry for the confusion.
They aren't too deep, so I think I could do an ok job with some putty and paint. I dug around and found a bad photo of the damage: http://i.imgur.com/3jMi8Pu.png
It doesn't appear to be too deep, or too wide. Still a bit on the edge, but I'm getting a pretty good deal on them. My thoughts are that with a little work it could turn out looking almost as good as new.
Edit: A bit more info... I'm getting two; one for personal use, and one to sell. I'd like to restore them fully (bolt mod, possible usb mod, and fix the etching problem). I'll be selling the one at a reasonable price, as I got a good deal, and I don't want to charge an insane amount. I was thinking $250 USD if it ends up looking good. That's fine for a bolt/usb modded SSK, right? I would rather like to take care of the problem than sticking something over it. Bringing them back to their former glory would be worth the time for me. Let me know what you guys think!
« Last Edit: Sat, 05 December 2015, 18:18:39 by chiptea »
« Reply #13943 on: Sat, 05 December 2015, 18:09:38 »
People do bump up  *asking*  prices heavily for restored boards.
And rarely get them.
Offline E3E
« Reply #13944 on: Sat, 05 December 2015, 18:19:11 »
Seeing yellowed old logo salmon Alps Dell AT101s go for around $150 and blue alps Omnikeys go for somewhere above $100 and below $200 (the last guy tried to sell for $290, as delusional as he was), Acer KB101As sell for 100-150, all of the above being yellowed and not in "like-new" condition.... Well, I can imagine some people do pay a bit more for restored boards.
Don't restored models often sell on the ClickyKeyboards site and the site of that one guy who restores and repairs Northgates?
« Reply #13945 on: Sat, 05 December 2015, 18:28:33 »
Thanks for the advice guys. I guess I should have specified: I don't think removing the etchings on an SSK is putting lipstick on a pig  It sounded like I had regular old model Ms now that I look back. Sorry for the confusion.
As somewhat of a collector myself, I'd prefer to have the keyboard in pure stock condition, no bolt mod, no USB, no cosmetic refinishing. If I wanted to do anything to it, I'd prefer to be the one to make that decision. You would probably reduce the value, rather than increase it, by messing with them.
If you want to try something on yours first, maybe hit it with a Mr Clean Magic Eraser first, and see how that works.
Offline chiptea
« Reply #13946 on: Sat, 05 December 2015, 18:34:14 »
Allright, I might go ahead and do that. What do you think they'd be worth stock, considering that they have those markings that you saw in the above picture? I'd like to see if It's worth buying.
« Reply #13947 on: Sat, 05 December 2015, 18:58:47 »
I'm not 100% sure, as I haven't been following the market lately. You might ask in the Price Check thread.
« Reply #13948 on: Sat, 05 December 2015, 19:02:04 »
I would think that a blue Alps Northgate would be worth a good deal more than an salmon Alps Dell, but I am not really in the market any more.
But I think that you should take jdcarpe's advice: sell it as-is.
Although a certain person might well pay another person $100 to do a restoration job, you should not assume that a restoration job, in and of itself, would raise the market value by $100.
Offline E3E
« Reply #13949 on: Sat, 05 December 2015, 19:16:41 »
I do agree with all your points here, fohat (I always read your name as foghat, lol  :rolleyes:).
Like JD, I'd also rather buy a yellowed or otherwise disheveled keyboard so I can restore it myself. That alone increases personal value due to the investment and effort made in bringing the board back to a nice condition.  Restored boards do tend to get listed for a bit more than unrestored, and while I find that to be pretty justified thanks to the work put in... for anyone who can do it themselves, that's usually work that wasn't asked for, haha.
Here's some crazy examples: I thought this was a salmon alps, but it was actually a black alps model AT101 that sold for $150.
Meanwhile, we have a likely blue alps Northgate Omnikey 102 that went for $100.
In the end, I think its hard to set prices on things as they vary so much. I've seen AT101s go for around $150, but there was another recently that went for $100 that was salmon alps and I got mine for $29.99 before shipping. There was that guy who set another 102 Omnikey at $290 BIN but ended up taking a best offer (the price of which is anyone's guess). I think the prices for a lot of these boards are overblown though. :-X
