Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6278411 times)
0 Members and 7 Guests are viewing this topic.
Offline Bucake
« Reply #14100 on: Wed, 23 December 2015, 06:52:28 »
Is there a way to switch \| and ~` on the HHKB? I've looked in Karabiner, but didn't find anything.
i thought AutoHotKey could do that kind of stuff?
(sorry if i'm wrong, never used it myself.)
Looks like that's windows only :\
KeyRemap4MacBook?
i found this: http://matthewpalmer.net/blog/2014/01/19/remap-keyboard-keys-caps-lock-os-x-mavericks/
sorry if it's nothing :D
Offline tofgerl
« Reply #14101 on: Wed, 23 December 2015, 07:03:28 »
Nah, Karabiner is the stuff, it's just possible you have to write your own rule about that... Give me half an hour...
Offline tofgerl
« Reply #14102 on: Wed, 23 December 2015, 07:11:08 »
Yeah, go to Misc & Uninstall in Karabiner, click 'open private.xml', rightclick the file and open in textedit, and replace the contents with this. This will give you a new rule which you can toggle.
Code: [Select]
<?xml version="1.0"?>
<root>
  <item>
    <name>Swap backslash and backtick</name>
    <identifier>private.swap_backslash_and_backtick</identifier>
    <autogen>__KeyToKey__ KeyCode::BACKQUOTE, KeyCode::BACKSLASH</autogen>
    <autogen>__KeyToKey__ KeyCode::BACKSLASH, KeyCode::BACKQUOTE</autogen>
  </item>
</root>
Offline xondat
  • i'm not a star
« Reply #14103 on: Wed, 23 December 2015, 07:30:49 »
Can you render CAD files?
« Reply #14104 on: Wed, 23 December 2015, 07:48:10 »
Offline xondat
  • i'm not a star
« Reply #14106 on: Wed, 23 December 2015, 08:14:44 »
Yes
How?
Dunno you'll have to look it up. Depends on the program. You might have to import it into a rendering software or your cad package might have it built in.
Offline ajx
« Reply #14107 on: Wed, 23 December 2015, 13:49:04 »
Hello, does anyone feel HHKB silenced modded keys as scratchy?
I have on some keys, some keys producing a little friction at light pressure
When you bottom-out, it tends to be absorbed
It annoys me because i have an inconstant feeling on all keys
Some keys dont have detectable frictions while others do
Btw i m using landing pads
I thought it was spring+dome alignment but i aligned several times and still have this scratchy feeling
I also did inverting sliders into another housing
https://vid.me/vIxP
https://vid.me/MrPS
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #14108 on: Wed, 23 December 2015, 17:48:26 »
what cases even exist for 1800?
« Reply #14109 on: Wed, 23 December 2015, 17:59:46 »
ask flynn :P
Offline xondat
  • i'm not a star
« Reply #14110 on: Wed, 23 December 2015, 19:05:49 »
Reasonable amount to pay for a one piece, anodized aluminium case? Trying to work out numbers but don't know how much people would pay.
Offline user 18
« Reply #14111 on: Wed, 23 December 2015, 19:08:32 »
Depends on the case. They've been seen as cheap as $60 for a simple one, but they can be much more expensive.
Avatar by ashdenej
Offline zombimuncha
« Reply #14112 on: Wed, 23 December 2015, 19:15:18 »
Maybe this is a dumb question, or has been asked 1001 times before, but are fancy metal cases just for looks, or do they affect the feel of the keyboard in some way too?
Offline xondat
  • i'm not a star
« Reply #14113 on: Wed, 23 December 2015, 19:21:39 »
It depends on the numbers sold as far as I'm aware too - are there figures around for cases sold such as the Duck Eagle/Viper? What's the most expensive one that has been sold?
More sturdy etc, but mainly looks for most.
Offline pr0ximity
« Reply #14114 on: Wed, 23 December 2015, 20:59:57 »
Feel, weight, resonance, looks can all affected to varying degrees.
Offline trenzafeeds
  • **** off
« Reply #14115 on: Wed, 23 December 2015, 21:00:43 »
I actually notice a difference when my keyboard is heavier. Makes typing on it feel more solid.
demik will never leave.
Unless he gets banned.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #14116 on: Wed, 23 December 2015, 21:36:57 »
The case is just one part of a multifaceted system that affects typing feel and sound.  Other factors that affect both feel and sound are, dampening material between case and plate/pcb mounts, desk surface, size and mass of desk, anything between case and desk, case material, case construction details, PCB or not, thickness of PCB, material of plate, thickness of plate, springs, stems, lube, and even sound acoustics play a larger part than what a lot of people realize.
Offline ctm
  • Hello, world!
« Reply #14117 on: Thu, 24 December 2015, 06:24:03 »
Anyone has the dimensions of the metal badge on top left corner of IBM Model F? Thanks!
Coming:
Ellipse Model F F62.
« Reply #14118 on: Thu, 24 December 2015, 21:03:19 »
@wcass might know
Offline trenzafeeds
  • **** off
« Reply #14119 on: Thu, 24 December 2015, 22:53:15 »
Is there a quick and dirty way to tell which end of a 1n4148w resistor is which (besides the label). A large number of the ones I received from winkeyless appear to have had the labels melted off.
Offline Vozella
« Reply #14120 on: Thu, 24 December 2015, 23:00:54 »
Are all Topre switches the same?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14121 on: Thu, 24 December 2015, 23:23:50 »
The weighting may be different between springs.
« Reply #14122 on: Fri, 25 December 2015, 01:02:37 »
Domes, not springs.  Springs are the same.
Also, HHKB is plastic plate and PCB, other Topre boards have a metal backplate that affects the feel.
Offline Vozella
« Reply #14123 on: Fri, 25 December 2015, 08:41:49 »
Are Greetech switches worse than MX Cherry? How do they compare?
Also, what's with the shark icons?
Offline Roibhilin
  • Saver of Humens
« Reply #14124 on: Fri, 25 December 2015, 12:20:59 »
I just got my HHKB and I really like it but is there a way to get caps lock to work on windows?? fn+tab isn't doing anything
« Last Edit: Fri, 25 December 2015, 12:58:24 by Roibhilin »
QFR | Poker II | Quickfire TK
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #14125 on: Fri, 25 December 2015, 12:31:49 »
In my experience with both, the Greetechs stock certainly feel a bit nicer. But I have no idea about the quality of Greetech long-term
Offline Vozella
« Reply #14126 on: Fri, 25 December 2015, 16:41:41 »
I didn't except them to be nicer. I thought they were cheaper alternatives.
How did they feel nicer?
Offline xondat
  • i'm not a star
« Reply #14127 on: Fri, 25 December 2015, 17:15:39 »
Are the GMK Dolch set from Originative Co. legit?
MX Brown too soft, MX Clear too hard; what weight spring do I want?
« Last Edit: Fri, 25 December 2015, 17:27:14 by xondat »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #14128 on: Fri, 25 December 2015, 18:07:04 »
The set is legit gmk yes
65g
Offline xondat
  • i'm not a star
« Reply #14129 on: Fri, 25 December 2015, 18:08:58 »
65g
Merci - do you know if the keypop JTK Debut sets are legit too?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #14130 on: Fri, 25 December 2015, 18:09:48 »
65g
reputable site so I'm sure they are. I don't think I've heard of knockoffs of either of those sets
Offline Melvang
« Reply #14131 on: Fri, 25 December 2015, 18:37:25 »
65g
If you are thinking about buying directly from Originative's web site, I wouldn't spend that money unless you can afford to throw it at a casino to never see it again.  As a site, they have a very shoddy reputation at best.
Offline xondat
  • i'm not a star
« Reply #14132 on: Fri, 25 December 2015, 18:51:27 »
65g
Is that because of the price or that they tend not to fulfill orders? Is there anywhere else that sells them new?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #14133 on: Fri, 25 December 2015, 18:54:01 »
65g
The former
Offline heedpantsnow
  • Old enough to know better
« Reply #14134 on: Fri, 25 December 2015, 19:08:39 »
65g
They have a long history of not fulfilling, but recently some people have had good experiences. Most of us who have been around here a long time don't feel it's worth the risk, but to each his own.
I will say that I emailed them a couple of months ago and they were very helpful. But a bad reputation is a hard thing to overcome.
I'm back.
Offline alienman82
« Reply #14135 on: Fri, 25 December 2015, 19:17:35 »
removed.
« Last Edit: Thu, 01 March 2018, 16:46:14 by alienman82 »
Offline raymogi
« Reply #14136 on: Fri, 25 December 2015, 20:13:03 »
Do I need to do any kind of drilling if I were to put Novatouch stems on my FC660C? Is it just a simple swap?
Please feed my addiction.
Offline xondat
  • i'm not a star
« Reply #14137 on: Sat, 26 December 2015, 01:48:53 »
Is the USB port for a 60% board always in the same exact place?
« Reply #14138 on: Sat, 26 December 2015, 02:31:02 »
No, it depends on the board. Many might be common but they won't all be the same.
Offline xondat
  • i'm not a star
« Reply #14139 on: Sat, 26 December 2015, 12:29:35 »
What are diodes and resistors used for in a PCB?
Offline E3E
« Reply #14140 on: Sat, 26 December 2015, 14:17:59 »
These are really basic descriptions: Diodes are used for the matrix to avoid conflicts when multiple keys are pressed and to by-pass the need for blocking to be programmed into the controller. They needed to be soldered for a key to work, otherwise a connection won't be made. It acts as a one-way jumper.
Resistors are used to lower the current and voltage of the circuit so it doesn't burn out the LEDs.
Offline Solo
  • Unreal
« Reply #14141 on: Sat, 26 December 2015, 19:31:43 »
No drilling is required. You can swap everything including the stabilizer housings.
However, you're pretty much stuck using Topre spacebars after it's all said and done. The FC uses a 6u space bar with a centered stem, while Cherry 6u spacebars are off-centered.
Offline trenzafeeds
  • **** off
« Reply #14142 on: Sat, 26 December 2015, 20:02:17 »
65g
Like hwood said, they are legit, but I believe bunny will sell you some if you PM him, and they'd be cheaper from him I believe.
Offline raymogi
« Reply #14143 on: Sat, 26 December 2015, 21:17:52 »
Oh yea almost forgot about spacebar. Well that means I'm stuck with either black or white sets.
Thanks for the answer :)
Offline Giorgio
« Reply #14144 on: Sun, 27 December 2015, 04:12:14 »
I'm looking for cherry keyboards that uses mx compatible mounts. To scavenge keycaps.
Surely cherry my switches are compatible, at least for the non stabilized keycaps.
What kind of mount do the non mx my cherry keyboards use?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14145 on: Sun, 27 December 2015, 08:20:23 »
AFAIK, only Cherry MY can be used with MX (MX isn't even MY compatible).
Offline bcredbottle
« Reply #14146 on: Sun, 27 December 2015, 13:03:55 »
I have Topre artisans but no Topre board.
Is there a converter/slider that will allow Topre caps to fit on MX switches?
I know, of course, that the reverse is possible.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #14147 on: Sun, 27 December 2015, 13:15:58 »
The full sets are compatible. IIRC most MY boards use something like a costar stab
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #14148 on: Sun, 27 December 2015, 13:28:36 »
The best bet is to trade for MX or try to get a hold of a Novatouch and some Topre sliders.
« Reply #14149 on: Sun, 27 December 2015, 13:35:18 »
Sounds like you need some Topre keychains. ;)
