Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6278422 times)
0 Members and 7 Guests are viewing this topic.
Offline pr0ximity
« Reply #14200 on: Sun, 03 January 2016, 09:23:21 »
Should I have any concerns putting dampening material between the PCB and plate of an MX or Alps keyboard? Only thing that really came to mind (aside from getting it in there) was heat dissipation from the components, am I just naive? Just a bunch of resistors on there for the most part, it's a single-layer PCB with the traces on the other side.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #14201 on: Sun, 03 January 2016, 09:45:55 »
I haven't ever heard of anyone having those sorts of problems using shelf-liner or something similar. You should be fine :thumb:
Offline xondat
  • i'm not a star
« Reply #14202 on: Sun, 03 January 2016, 16:17:24 »
Bottom out forces of all MX switches?
Offline user 18
« Reply #14203 on: Sun, 03 January 2016, 16:50:21 »
Should be somewhere in this ballpark:
blue/red/brown: 60cN
black/green: 75cN
clear: 80cN
(haven't measured, these are educated guesses)
Avatar by ashdenej
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #14204 on: Sun, 03 January 2016, 17:04:24 »
does anyone have pics of the final lynn hangul cap sets?
Offline xondat
  • i'm not a star
« Reply #14205 on: Sun, 03 January 2016, 17:07:01 »
black/green: 75cN
clear: 80cN
**** I bought some 62g springs thinking they'd be a bit harder than browns... fml I need 67g I guess, brown waaaaay too light and clears are waaaaaaaaaaaaaaaay too heavy. :mad:
« Reply #14206 on: Sun, 03 January 2016, 17:09:20 »
black/green: 75cN
clear: 80cN
But with clears you don't have to bottom out, so they aren't that heavy.
Offline xondat
  • i'm not a star
« Reply #14207 on: Sun, 03 January 2016, 17:12:23 »
black/green: 75cN
clear: 80cN
Yeah, still getting used to that but I like to travel a bit after the actuation on each key press. Looking at graphs it makes me think 67g might be my jam.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14208 on: Sun, 03 January 2016, 18:50:42 »
Actuation of browns is 45cN and Clears are around 90cN at bottom out.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #14209 on: Sun, 03 January 2016, 18:52:17 »
black/green: 75cN
clear: 80cN
https://geekhack.org/index.php?topic=46449.0
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14210 on: Sun, 03 January 2016, 22:09:01 »
Can someone explain the shark avatars to me?
Offline jerue
  • (Whenever that happens :P)
« Reply #14211 on: Sun, 03 January 2016, 22:27:13 »
Read the Church of Halverson thread
gimme a moment and I'll find the specific thing
edit: I think he ran something in the keycap subforum, not sure. but ok
« Last Edit: Sun, 03 January 2016, 22:32:31 by jerue »
Offline piemancoder
« Reply #14212 on: Sun, 03 January 2016, 22:43:20 »
This was also a reason: https://geekhack.org/index.php?topic=77964.0;topicseen
Yoda grammar best has
Offline jerue
« Reply #14213 on: Sun, 03 January 2016, 22:48:56 »
That was the thread I was looking for, thanks for that  :thumb:
Offline Solo
  • Unreal
« Reply #14214 on: Sun, 03 January 2016, 23:52:12 »
Where were the FMJ Aluminum Poker cases manufactured?
Offline n__dles
« Reply #14215 on: Mon, 04 January 2016, 06:35:30 »
What size screws does a Poker II case use? I tried M2 6mm, and it's too long.
Offline xondat
  • i'm not a star
« Reply #14216 on: Mon, 04 January 2016, 06:36:08 »
IIRC Pokers use 4mm.
Offline tofgerl
« Reply #14217 on: Mon, 04 January 2016, 06:52:39 »
I've used 10 no problem on pok3r, but never tried 2.
Offline jerue
« Reply #14218 on: Mon, 04 January 2016, 12:24:26 »
yup
these are the ones you need: http://www.mcmaster.com/#92000a011/=10jdcxb
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #14219 on: Mon, 04 January 2016, 15:14:29 »
I know, it's a shame but, I use a mac and I like it ^^'
Anyway, I know I could use any windows keyboard and remap the keys to get it working, but I would like to know if there were some "native" mechanical keyboard for macs :)
thanks a lot!
Offline piemancoder
« Reply #14220 on: Mon, 04 January 2016, 16:50:36 »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14221 on: Mon, 04 January 2016, 19:53:49 »
thanks a lot!
Matias and Razer sell modern Mac compatibles and you can use any Apple mechanical with a converter like the iMate.
Offline piemancoder
« Reply #14222 on: Mon, 04 January 2016, 20:43:32 »
thanks a lot!
Das makes some Mac compatible keyboards. Or, you could build a custom  ;)
Offline davkol
  •  Post Editing Timeout
« Reply #14223 on: Tue, 05 January 2016, 05:46:34 »
A couple of quick questions about MX clones:
  • Is there any incentive to get Gaote, Greetech or other clone switches instead of Gateron? (I'm looking for smooth non-clicky switches, tactile or linear. Higher actuation point would be nice.)
  • Are Zealio switches higher quality, or just custom weight (or stem)? (I don't care about backlight.)
  • Are there any active group buys for these switches? If not, any idea, when gaterons will be back on Massdrop? I'm looking for options, that are cheaper than 120 gaterons for £33 shipped from Amazon.co.uk. MechanicalKeyboards.com have gaterons for $0.3/switch, but I'd have to find a shipping proxy to avoid their default $85 option.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #14224 on: Tue, 05 January 2016, 06:26:16 »
Nope
Just custom spring and totally trans housing
No active GBs and I'm not sure if they'll be back on Massdrop since they've already run it probably 15 times.
Offline xondat
  • i'm not a star
« Reply #14225 on: Tue, 05 January 2016, 06:40:03 »
How do I assemble these? Video preferable. Treat me like I'm 5.
Offline azhdar
  • Praise the AZERTY god
« Reply #14226 on: Tue, 05 January 2016, 11:19:16 »
Azerty Propagandiste
Offline jerue
« Reply #14227 on: Tue, 05 January 2016, 11:23:42 »
thanks a lot!
https://geekhack.org/index.php?topic=63028.0
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #14228 on: Tue, 05 January 2016, 13:15:50 »
thanks a lot!
As a Mac user, I haven't had any problems using any modern keyboard.
The only change I make is in System Preferences\Keyboards\Modifier Keys to swap the Option Key with the Command Key to match the Mac layout. Physically swap those two keys on the keyboard and I'm good to go.
The only part that kinda sucks is that you'll have a "Windows" key on your keyboard, but that's what custom key cap sets are for.  :p
Offline tofgerl
« Reply #14229 on: Tue, 05 January 2016, 14:14:11 »
If you connect to a laptop you'll be without a proper fn-key for the native mac mediakeys and stuff as well.
Offline mashby
    • Mashby
« Reply #14230 on: Tue, 05 January 2016, 15:48:45 »
Good point. I forgot about that.
If you use the Function Row AND the media keys, then you'll need to use a specific keyboard. Personally, I don't use the function row, so I set the function row to be the media keys by default.
Offline Connly33
« Reply #14231 on: Wed, 06 January 2016, 00:54:31 »
I was wondering a couple things about Cherry stabilizers. I got some PCB mount Cherry stabs for my new build and i'm going to lube them when i put it together.
But i have seen a few people clip the feet from the bottom of the stabs that hit the PCB when they bottom out so that the switch bottoms out instead.
 But i looks like those tabs are what keeps the stem from being pulled out of the stabilizer when you remove a keycap.
I was wondering if anyone has experience clipping them and if the stem being pulled out is an issue.
Custom 60% with Cherry MX Clear
Offline Melvang
« Reply #14232 on: Wed, 06 January 2016, 00:56:03 »
Not an issue clip away.  For the record, there have been cherry stabs that didn't have those feet from the factory.  Both pcb and plate mount can be clipped with no adverse effects.
Offline Connly33
« Reply #14233 on: Wed, 06 January 2016, 01:20:43 »
Thank's :p. Definitely going to clip them then.
Offline xondat
  • i'm not a star
« Reply #14234 on: Wed, 06 January 2016, 03:19:35 »
I only have one set of stabs, why should I clip them? I know it's preference but I'd rather know the advantages and disadvantages
Offline ideus
  • Björkö.
« Reply #14235 on: Wed, 06 January 2016, 04:35:23 »
Cherry stabs tend to feel mushy due to those extra small legs pairs, if you clip them the feeling of the stabilized keys will be more close to non stabilized keys. That is the advantage, and the mod does not have any disadvantage known; however, if you are not aware of that feeling it may not worth for you to make the mod. In my experience that was the only thing that prevented me to enjoy my first non ALPS board, some years ago, as you know, an ALPS keyboard comes with Costar stabilizers that are designed with smaller gauge wire and with inserts that go directly into the keycaps, that design makes the stabilized caps as if they were normal keys, that is a great feeling, all the keyboard feels the same with no mushy keys, you will get a similar final effect with clipped Cherry stabilizers. It is up to you.
Offline davkol
« Reply #14236 on: Wed, 06 January 2016, 06:22:37 »
Oh, well… thanks.
Gaterons were on Massdrop 2-3 months ago ($26 for 120 switches) or last month (some special version), so it might be possible to save a little bit. I just have to decide, if I hate Amazon, or Massdrop less.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #14237 on: Wed, 06 January 2016, 09:42:13 »
Oh, well… thanks.
Actually, looking at the Massdrop page for the switches, 277 people have requested a drop again, so they could very well do another run soon
Offline jerue
« Reply #14238 on: Wed, 06 January 2016, 10:36:27 »
If I want silenced Realforces (the ones with purple sliders), am I just looking for boards with the -S affixed at the end? Like 91UKB-S, etc.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #14239 on: Wed, 06 January 2016, 10:48:13 »
for the most part.
I believe the only American board that was silenced was the anniversary board.
The rest I found where Japanese boards.
I ended up buying a cheap used one from amazon.jp and had evo_spec proxy it for me.
Offline jerue
« Reply #14240 on: Wed, 06 January 2016, 11:00:31 »
for the most part.
Gotcha. Thanks! I would mostly just harvest the sliders and replace them with stock sliders so I don't think JIS is too much of an issue. I want to join the purple slider club someday :))
Offline ajx
« Reply #14241 on: Wed, 06 January 2016, 13:24:32 »
Anyone has a picture of HHKB PCB in real size?
Thanks
Offline tofgerl
« Reply #14242 on: Wed, 06 January 2016, 13:29:14 »
Pictures on the internet don't have "real size". They scale according to your monitor, the resolution you use and the application you view it with.
Offline xondat
  • i'm not a star
« Reply #14243 on: Wed, 06 January 2016, 15:53:07 »
What thickness should each piece be if I am making a sandwich style case?
Offline Solo
  • Unreal
« Reply #14244 on: Wed, 06 January 2016, 16:00:35 »
There's a 91UBK-S on eBay right now if you don't mind spending 280 bones lol.
Link
Offline user 18
« Reply #14245 on: Wed, 06 January 2016, 17:02:28 »
They can be as thin or as thick as you like!
The only true restrictions are:
1) If you want the plate to be one of the sandwich layers, that layer needs to be proper plate thickness (1/16", iirc)
2) The total room inside the case needs to be enough for what you want to put inside it (obviously).
A basic sandwich case only has three layers -- one for the plate, one for a "spacer" layer of whatever thickness you want (within reason), and one for a bottom layer. You can split up your spacer layer into multiple thinner layers for the same overall thickness, or you can add multiple spacer layers to make a thick keyboard. You can also add a layer or layers above the plate, forming a raised bezel.
Avatar by ashdenej
Offline ideus
  • Björkö.
« Reply #14246 on: Wed, 06 January 2016, 17:07:47 »
If you can wait, I can give you the exact thickness of each of the layers of my GON layered acrylic case.
Offline xondat
  • i'm not a star
« Reply #14247 on: Wed, 06 January 2016, 18:44:40 »
That would be wonderful if you could do that! The style I have is 4 parts, top and bottom would be 2/3mm (?) but the other two I'm not sure what heights I'd need.
Thanks for the help guys :-*
Offline ideus
  • Björkö.
« Reply #14248 on: Wed, 06 January 2016, 19:29:12 »
OK, I'll take my caliper with me to the office, tomorrow, to get those measurements for you. I'll post them here then.
Offline jerue
« Reply #14249 on: Wed, 06 January 2016, 19:34:49 »
Link
Yeesh. That is crazy. I'd rather just proxy it; so much cheaper on Yahoo Auctions JP
