Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 5855337 times)
« Reply #14800 on: Tue, 01 March 2016, 09:28:18 »
Does a leeku PCB and plate fit in a OG cherry case?
Yup, both the 1800 and 3000 fit fine with a bit of modding to the cases. There's a few ribs that need to be cutaway.
Offline joey
« Reply #14801 on: Tue, 01 March 2016, 09:35:53 »
Thanks cptbadhwood!
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #14802 on: Tue, 01 March 2016, 09:49:05 »
Thanks cptbadhwood!
In fact, leeku actually incorporated holes in the PCB to fit the pegs in the cases
Offline joey
« Reply #14803 on: Tue, 01 March 2016, 09:51:38 »
Cool, looks like I'll finally be able to use my 1800 board. Just gotta figure out switches next!
Offline alienman82
« Reply #14804 on: Tue, 01 March 2016, 10:43:02 »
removed.
« Last Edit: Thu, 01 March 2018, 16:00:04 by alienman82 »
« Reply #14805 on: Tue, 01 March 2016, 10:44:53 »
can someone recommend a desoldering station?
I really like the Hakko 808. I heard the upgraded FR300 is everything great about the 808 but with improvements like an on/off switch.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14806 on: Tue, 01 March 2016, 11:06:16 »
If you are conscious of price, the Aoyue 701A++ is really great. I use it all the time.
Offline alienman82
« Reply #14807 on: Tue, 01 March 2016, 11:19:59 »
removed.
« Last Edit: Thu, 01 March 2018, 16:00:02 by alienman82 »
« Reply #14808 on: Tue, 01 March 2016, 11:22:06 »
You might also want to do a search within the Living Soldering Thread for "desoldering" and see what comes up.
Offline amanxmb
« Reply #14809 on: Tue, 01 March 2016, 17:40:01 »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14810 on: Tue, 01 March 2016, 20:18:57 »
Does it get both sides of the pad of the pcb?  That is my main concern.
It usually leaves a perfect hole where the solder is. I don't know if I totally understand what you mean though.
Offline swimmingbird
  • keyset hoarder
« Reply #14811 on: Tue, 01 March 2016, 20:41:11 »
are there any aftermarket PCBs for the old Skidata keyboards?
edit: talking about the one with the trackpad and huge amount of relegendables
« Reply #14812 on: Tue, 01 March 2016, 20:54:43 »
I've never seen one no
  • keyset hoarder
« Reply #14813 on: Tue, 01 March 2016, 20:57:09 »
Looks like handwiring time! :)
Offline THEMIKEBERG
« Reply #14814 on: Wed, 02 March 2016, 15:42:02 »
Hey all! I'm quite new to this, so bare with me here.
I'm having an issue identifying different keycaps. DSA, SA, etc.
I'm looking for a set of spherical keycaps for my Leopold FC750, but I just cannot for the life of me tell from pictures (and the info provided) if the keycaps I'm looking at are spherical or not.
I'm sorry if this was answered in the FAQ none of the questions under keycaps section seemed to be relevant to what I'm trying to find out.
EDIT/ I have found the answers I am looking for, the glossary is very handy thanks!
Thanks in advance,
Mike
« Last Edit: Wed, 02 March 2016, 16:26:21 by THEMIKEBERG »
Offline alienman82
« Reply #14815 on: Wed, 02 March 2016, 19:57:55 »
removed.
« Last Edit: Thu, 01 March 2018, 15:58:53 by alienman82 »
« Reply #14816 on: Wed, 02 March 2016, 19:59:02 »
has anyone used someone for desoldering??  I was looking towards a specific user, but they have blocked me for whatever reason...  Oh well they lost some good money for some grudge or something.
Don't know if anyone is offering just desoldering in CONUS. Maybe steezus
Offline alienman82
« Reply #14817 on: Wed, 02 March 2016, 19:59:28 »
removed.
« Last Edit: Thu, 01 March 2018, 15:58:50 by alienman82 »
« Reply #14818 on: Wed, 02 March 2016, 20:05:47 »
there lies the issue
I mean.... A desoldering tool from radio shack is like $10. A cheapo soldering iron and wick is just as cheap. It's really not that hard. Then you could just get it over with and not have to worry about who blocked you or whatever.
« Reply #14819 on: Wed, 02 March 2016, 20:10:55 »
Just a desolder?  I'd probably be willing to do that for you.  What board?
Offline Jokrik
« Reply #14820 on: Wed, 02 March 2016, 20:15:16 »
True , it isn't that hard as long as you have good temperature and good sucker
SS-02 is a good one I heard
Offline alienman82
« Reply #14821 on: Wed, 02 March 2016, 20:37:21 »
removed.
« Last Edit: Thu, 01 March 2018, 15:58:38 by alienman82 »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14822 on: Wed, 02 March 2016, 20:42:26 »
I could do it too.
Offline klennkellon
  • I like bottoming out
« Reply #14823 on: Thu, 03 March 2016, 01:51:38 »
Do the font and legends on Unicomps keycaps match with the original Model M's?
« Reply #14824 on: Thu, 03 March 2016, 07:05:57 »
Ha Ha
"sometimes"
- Oliver Willis 2026-08-01
Offline tassadarforaiur
« Reply #14825 on: Thu, 03 March 2016, 09:01:20 »
If you have a radioshack nearby, I would strongly recommend buying this https://www.radioshack.com/products/radioshack-45-watt-desoldering-iron?variant=5717855877 and a handful of replacement tips before they disappear forever https://www.radioshack.com/products/radioshack-replacement-tip-for-cat-6402060?variant=5717856005 standalone desoldering pumps require removing the iron, which lets the solder cool down, before you can position the pump for best suction. get a 1 piece unit, it's a game changer. (I would recommend an aoyue 474a++ or zd-985, but that's only if you do a lot of desoldering, but not enough to justify price of hakko)
« Reply #14826 on: Thu, 03 March 2016, 11:13:27 »
I will have a 360C pcb soon, but I am afraid to lift pads.  Do you think I (or you ^-^) should use a Hakko gun?  I desoldered lots of old WYSE boards with a pump without any lifted pads, but I had an issue once with a leeku PCB and lifting a pad.  I think I didn't get all the solder off, and when I ripped the switch out, it grabbed the pad too....
I've never lifted a pad with an 808 or FR-300.  I'd go that route.  If you have a gun and are familiar with it you should go for it.  :P
Offline alienman82
« Reply #14827 on: Thu, 03 March 2016, 11:18:29 »
removed.
« Last Edit: Thu, 01 March 2018, 15:58:23 by alienman82 »
« Reply #14828 on: Thu, 03 March 2016, 11:22:53 »
oh so you have an 808/FR300?
Used to have an 808, now have an FR-300.   :thumb:
Offline alienman82
« Reply #14829 on: Thu, 03 March 2016, 11:25:44 »
removed.
« Last Edit: Thu, 01 March 2018, 15:58:21 by alienman82 »
Offline piemancoder
« Reply #14830 on: Thu, 03 March 2016, 17:45:18 »
What are the pros and cons of a stepped caps lock and a normal one? This also includes using it as ctrl.
Yoda grammar best has
« Reply #14831 on: Thu, 03 March 2016, 18:58:49 »
I love stepped keys but there is a lot of ugliness towards them.
Offline alienman82
« Reply #14832 on: Thu, 03 March 2016, 19:50:18 »
removed.
« Last Edit: Thu, 01 March 2018, 15:57:27 by alienman82 »
  • keyset hoarder
« Reply #14833 on: Thu, 03 March 2016, 21:14:18 »
I use stepped since it's what OG cherry uses which is the best feeling
also looks cool
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #14834 on: Thu, 03 March 2016, 23:25:06 »
also looks cool
+1  stepped Capslock looks the best.  It also makes it harder to accidentally hit it with your pinky.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #14835 on: Fri, 04 March 2016, 02:26:32 »
Can someone please tell me the exact size screws that are used on the bottom of the KMAC2 (the 10 screws that hold the two halves of the case together)?
WTB/WTS/WTT ---->
Offline yasuo2
« Reply #14836 on: Fri, 04 March 2016, 04:57:45 »
If im wiring keyboard like lowpoly style mean cut off the cord wire
and the wires touch diodes is it effect when keypressed?
Offline Fyodor
« Reply #14837 on: Fri, 04 March 2016, 05:55:37 »
Is there any place that can print custom keycaps if I upload my layout, including side text and multiple colors?
Example:
Offline piemancoder
« Reply #14838 on: Fri, 04 March 2016, 06:26:24 »
Example:
WASD Keyboards can do multiple colors, but I'm not sure about side text.
Offline Fyodor
« Reply #14839 on: Fri, 04 March 2016, 06:52:11 »
Example:
I don't think they have side text option, anyone knows an alternative?
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #14840 on: Fri, 04 March 2016, 07:23:23 »
Example:
Dymo label maker? Clear with white...
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline Fyodor
« Reply #14841 on: Fri, 04 March 2016, 08:44:27 »
Example:
Well, I thought of using some posca markers or some transparent adhesive vinyl. Really would like to save these for a last option  :rolleyes:
Offline klennkellon
« Reply #14842 on: Fri, 04 March 2016, 16:09:31 »
If a Model M uses the two-piece keycaps will keycaps from variants with the one-piece keycaps still work? and vice versa.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #14843 on: Fri, 04 March 2016, 16:51:45 »
Does anyone have an outline of 1800 PCB screw hole locations and such? I'm trying to have a case made for an MX1800
Offline user 18
« Reply #14844 on: Fri, 04 March 2016, 16:55:03 »
Yes. You just need to remove both pieces of the two-piece cap to be able to insert the one-piece cap (seems obvious, I know :p)
Avatar by ashdenej
Offline KaLam1ty
« Reply #14845 on: Sat, 05 March 2016, 12:43:39 »
Has anyone else experienced a difference in tactility between Milky Housing (PCB 5Pin Mount) and Clear Housing (Plate 3 Pin Mount) Gateron Switches?
I built a keyboard yesterday using Milky Gateron Blues and noticed they felt a lot 'mushier' than my KC60, which has the Clear Gateron Blues.
(This is a difference in housing/body, not the actual stem type/color).
Is there a reason for this? The keycaps I'm using are the same between boards and both are using Costar stabilizers.
Also, if this issue is caused by the housing or stem, could I just swap out the tops and stems with a 'Clear' one?
I REALLY don't want to desolder everything and replace the entire switch  :-X...
« Reply #14846 on: Sat, 05 March 2016, 12:51:08 »
How much force does the spring under the hhkb spacebar add again? 5 or 10g? I forget OnO
Offline LechnerDE
« Reply #14847 on: Sat, 05 March 2016, 13:03:30 »
Where can I get those stabilizer inserts for cheap in Europe?
http://www.wasdkeyboards.com/index.php/cherry-mx-keycap-stabilizer-insert-2pcs.html
WASD wants like 30$ for shipping which is ridiculous for such an item...
Offline zombiegristle
« Reply #14848 on: Sat, 05 March 2016, 16:47:11 »
Are there any ortholinear fullsize keyboards?
EDIT: Not counting SPOS-style keyboards, looking for something with a more traditional height/aspect ratio instead of the massive grid.
« Last Edit: Sat, 05 March 2016, 16:51:15 by zombiegristle »
« Reply #14849 on: Sat, 05 March 2016, 16:51:41 »
http://www.keyboardco.com/product/4-filco-white-stabilizers.asp
Or I'm more than happy to proxy some for you from wasdkeyboards.
