Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 5855349 times)
0 Members and 14 Guests are viewing this topic.
Offline klennkellon
  • I like bottoming out
« Reply #14900 on: Mon, 14 March 2016, 04:27:36 »
So, I don't think the problem is with my Blue Cube.
It works perfectly on my moms PS/2 board, it seems to only have issues when I convert it from AT to PS/2 then to USB.
It also didn't work properly when I converted a USB board to PS/2 and then back to USB.
I'm not sure if another converter would work, any suggestions?
« Reply #14901 on: Mon, 14 March 2016, 05:52:41 »
The one techkeys.us sells has always worked for me even with AT -> PS/2
techkeys.us/products/usb-to-ps2-serial-multimode-adapter
Offline xondat
  • i'm not a star
« Reply #14902 on: Mon, 14 March 2016, 05:57:04 »
Where is the list for all Korean customs?
« Reply #14903 on: Mon, 14 March 2016, 06:08:41 »
A quick search found this
 https://geekhack.org/index.php?topic=69711.0
But I was thinking there was another one somewhere
« Reply #14904 on: Mon, 14 March 2016, 08:46:02 »
I still think either your PS/2 to USB or AT to PS/2 adapter is off.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #14905 on: Mon, 14 March 2016, 11:28:05 »
Will a Leeku PCB fit into a g81-1800 case?
If so I think I know what I want for my next project o.o
« Reply #14906 on: Mon, 14 March 2016, 11:34:45 »
Yes. You might have to do a little bit of cutting but I'm pretty sure I test fit mine into a G81-1800 case. It's been a little while since I've tried it.
Offline Bromono
  • Wanabe Cicerone
« Reply #14907 on: Mon, 14 March 2016, 11:36:43 »
Sweet! They are considerbly cheaper then their counterparts and I only want the case so that is perfect
Offline klennkellon
« Reply #14908 on: Mon, 14 March 2016, 14:38:27 »
Thanks, I'll check it out.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14909 on: Mon, 14 March 2016, 15:07:20 »
Oops
« Last Edit: Mon, 14 March 2016, 17:32:23 by Blaise170 »
« Reply #14910 on: Mon, 14 March 2016, 15:11:56 »
I just got a bunch of G81-1800s in today, I'd be willing to sell one for like $10+shipping.
Please don't use this thread to buy and sell stuff. PMs is fine but I'm trying to keep this thread clean so that people don't see it as a way to avoid the classifieds rules.
Offline klennkellon
« Reply #14911 on: Mon, 14 March 2016, 15:17:34 »
It could still be, I'm going to try that adapter that spamray recommended, if it doesn't work, the Model M i'm getting is coming with an AT > PS/2 adapter so I'll try that one too.
Offline davkol
  •  Post Editing Timeout
« Reply #14912 on: Mon, 14 March 2016, 17:37:46 »
Anyone know the difference between these two? Which one would you get?
http://gaming.coolermaster.com/en/products/keyboards/rapid-i/ vs http://gaming.coolermaster.com/en/products/keyboards/quickfirerapidred/
QFR-i is backlit and uses a much more powerful SM ARM controller. OTOH, the original QFR wasn't backlit and had a simpler controller (with PS/2 support), but it was possible to replace it by The Frosty Flake by bpiphany, enabling the user to run a custom firmware (at the cost of losing PS/2 compatibility).
Offline yasuo
  • spanengan puyeng newbie
« Reply #14913 on: Mon, 14 March 2016, 22:27:14 »
i dont remmeber the name keybosrd it the idea wt using different
height keycap for left and right hand stagger from japan site?
« Last Edit: Mon, 14 March 2016, 22:35:24 by yasuo »
Logitech MK220 Colemak DH
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #14914 on: Wed, 16 March 2016, 23:47:16 »
If i have a cherry MX keyboard with a single key that works 99% of the time, what should i be troubleshooting? Its really only a quick miss that autocorrect or a quick backspace and repeat corrects... but i'd like to make this my workhorse at the office so hopefully I can fix it.
Should i desolder and replace or can i pull it apart with out desoldering and check the contacts? Point me in the right direction. K thanks.
-Dana
« Reply #14915 on: Thu, 17 March 2016, 06:59:44 »
Assuming it's the ducky board you posted about elsewhere it will be plate mounted and require desoldering to replace the switch.
Offline OfTheWild
« Reply #14916 on: Thu, 17 March 2016, 08:57:47 »
yup, thats the one ;D
Ok i will give that a try first. It looks to be straight forward.
-Dana
Offline klennkellon
« Reply #14917 on: Thu, 17 March 2016, 14:38:42 »
If I wanted to convert my Model M to DVORAK or COLEMAK would it be as simple as swapping the keycaps and autohotkey?
« Reply #14918 on: Thu, 17 March 2016, 14:43:54 »
yes
- Oliver Willis 2026-08-01
« Reply #14919 on: Thu, 17 March 2016, 14:58:15 »
That would work, as fohat confirmed.  If you ever take the Model M to another machine (and want those changes to transfer with) or swap keyboards on that computer (and want the new keyboard to *not* have these changes), you may want to investigate hasu's TMK USB to USB converter, which allows you to reprogram a board by essentially acting as an external controller to swap key inputs.  Here is a review.  Here is hasu's artisan thread to purchase.  Fair warning, I am not sure how a Model M will perform with it (hasu is uncertain, and njbair doesn't touch on it in his review unless I missed it).
Alternatively, Phosphor Glow offers a replacement controller for Model M that will serve the same function but cannot be used with different keyboards.
Offline OfTheWild
« Reply #14920 on: Thu, 17 March 2016, 16:46:50 »
i'm not positive, but wouldnt the key profiles be different?
-Dana
« Reply #14921 on: Thu, 17 March 2016, 17:03:25 »
BS cap profiles are all the same. It's the bend in the plate that changes.
Offline alienman82
« Reply #14922 on: Thu, 17 March 2016, 17:51:33 »
removed.
« Last Edit: Thu, 01 March 2018, 15:50:09 by alienman82 »
« Reply #14923 on: Thu, 17 March 2016, 17:53:21 »
If I want to remove the floss mod from my ssk, how should I go about doing that?
Just pull it out....
« Reply #14924 on: Thu, 17 March 2016, 18:03:06 »
Half of them will probably fall out if you turn it upside down and shake it hard.
Offline alienman82
« Reply #14925 on: Thu, 17 March 2016, 18:05:01 »
removed.
« Last Edit: Thu, 01 March 2018, 15:50:07 by alienman82 »
Offline Bromono
  • Wanabe Cicerone
« Reply #14926 on: Thu, 17 March 2016, 18:09:13 »
Sometimes it's just hard.
Offline alienman82
« Reply #14927 on: Thu, 17 March 2016, 18:10:39 »
removed.
« Last Edit: Thu, 01 March 2018, 15:50:05 by alienman82 »
Offline alienman82
« Reply #14928 on: Thu, 17 March 2016, 18:38:12 »
removed.
« Last Edit: Thu, 01 March 2018, 15:50:02 by alienman82 »
« Reply #14929 on: Thu, 17 March 2016, 18:55:28 »
Is there a proper way to put IBM back on?  Or am I thinking too much as usual >.> ??
The keycaps?  You may need to tilt the keyboard back slightly to get the spring to seat properly in the cap.  Moreso with F than M (I literally tilt my Fs at a 90 deg angle).  Other than that, nah.  If it buckles properly, you're good, to the best of my knowledge.
Offline alienman82
« Reply #14930 on: Thu, 17 March 2016, 19:02:04 »
removed.
« Last Edit: Thu, 01 March 2018, 15:50:00 by alienman82 »
« Reply #14931 on: Thu, 17 March 2016, 19:06:57 »
Seriously? Just push the button back into place. If it doesn't click properly when you press down on the cap, pull it back off, and push it back in.
« Reply #14932 on: Thu, 17 March 2016, 19:10:39 »
backwards or forwards?
The way that doesn't push it against the wall and make it impossible to put the cap on (backwards ;) ).
« Reply #14933 on: Thu, 17 March 2016, 19:30:10 »
Or the other way. For me, at least 90% usually go on OK just sitting there. For the pesky ones, I usually rock the board forward, and if that doesn't work, then I try backward. On rare occasions, I have even held it upside-down. Whatever works. It can take half a dozen tries, but they usually go on easily.
Offline OfTheWild
« Reply #14934 on: Thu, 17 March 2016, 20:50:47 »
Little update on my ducky repair, i took it apart tonight and desoldered the H key and then swapped the switch out with a spare i had from a switch tester (gonna have to lower that price now lol) and so far everything seems to be working. I will know for sure tomorrow at work when it gets the full days use. Thanks for the help guys, i really appreciate it.
-Dana
Offline Fullcream
« Reply #14935 on: Fri, 18 March 2016, 11:06:19 »
I have a GH60 Rev. C.
I would like to install LED's and I dont care much for being able to do fancy controls with them or anything like that. None of that zones stuff. Just all one color, all on together.
Do I need to install resistors on all those allocated spots for them?
« Reply #14936 on: Fri, 18 March 2016, 13:50:24 »
I don't think the controller is currently setup to support LEDs. As far as I know, the GH60 was designed to include LEDs later but there needed to be a new module installed. I could have very very outdated information though.
Offline dgneo
  • Supervillain
« Reply #14937 on: Fri, 18 March 2016, 13:52:31 »
Zat iz korrekt.
http://blog.komar.be/projects/gh60-programmable-keyboard/#comment-133856
"Hi,
so far you have to use a 3rd party module if you need backlight, in the future there might be an expansion module for gh60 which will offer independent per-LED backlight, but that will cover only the gh60 board. Backlighting ghpad will require a separate solution.
According to our settlements with geekhack, the rev. C files will be released when the group buy ends, and it has been delayed.
Best regards,
Michał"
Offline klennkellon
« Reply #14938 on: Fri, 18 March 2016, 14:58:38 »
I just got my Model M today. I really like it, but the stabilized keys are acting weird.
The left shift key is binding really badly if you press it off center, and the right one seems to be binding on the upstroke and getting stuck.
I've tried reseating the keys but it hasn't helped.
Anyone know why this might be?
« Reply #14939 on: Fri, 18 March 2016, 15:00:23 »
Sometimes it can take multiple reseats to fix any issues. Could be the rivets have broken and your hammers aren't aligned anymore.
Offline klennkellon
« Reply #14940 on: Fri, 18 March 2016, 15:09:45 »
Only those keys though? I've done a keyboard test and every single key consistently worked, including the ones mentioned.
« Reply #14941 on: Fri, 18 March 2016, 15:11:18 »
I don't know exactly because I don't have the board in front of me. Keyboard test only tests for continuity electronically. Doesn't mean there's nothing physically wrong.
Maybe your stabilizers aren't seated right. Maybe your caps aren't seated right. Maybe the rivets are broken. I'd check all those.
Offline klennkellon
« Reply #14942 on: Fri, 18 March 2016, 17:09:30 »
I took out the stabilizers and cleaned them with glasses cleaner and a q-tip and now they work fine.
It wasn't the springs that were the problem, the switches worked fine with a smaller keycap on them.
Offline alienman82
« Reply #14943 on: Sat, 19 March 2016, 14:35:41 »
removed.
« Last Edit: Thu, 01 March 2018, 15:49:33 by alienman82 »
Offline ironpup
  • Good feeling of oneness with cup rubber
« Reply #14944 on: Sat, 19 March 2016, 15:44:34 »
I just updated my mac to El Capitan and my HHKB stopped being able to wake it from sleep. It's a 2011 iMac and I did a clean install of El Capitan with the keyboard plugged in, using it to type in all the set up stuff for a "new" mac. I have tried with and without the driver installed, different usb cables, different usb ports, restarting my computer, a bunch of dip switch combinations, and I even unplugged and replugged the controller. I have also updated the "change keyboard type" setting every time I changed something. My planck wakes my computer from sleep just fine, and the HHKB wakes up my 12" MacBook running the same version of OS X. It was working fine when I was running Yosemite.
The real kicker, and why I don't want to just use my house is - It will also be unresponsive for the first 5 or so keypresses after sleep
Any suggestions on fixes past buying a hasu controller?
« Reply #14945 on: Sat, 19 March 2016, 15:47:07 »
Does this sound ok?  I listened to music while typing to remove any bias I had towards the sound since I have only ever typed with the floss mod installed:
Sounds fine.
Offline swimmingbird
  • keyset hoarder
« Reply #14946 on: Mon, 21 March 2016, 00:42:08 »
Im putting together a VE.A for someone and im not getting any reads on the keys f7 through to f12 - any idea on what the likely culprit is?
« Reply #14947 on: Mon, 21 March 2016, 05:00:44 »
I've also heard that those barrel inserts on the longer keys can get slightly out of alignment, and might need to be straightened a bit.
That worked for one of my SSKs.
« Reply #14948 on: Mon, 21 March 2016, 08:35:06 »
Cold solder joints
Offline mrbishop
  • Evil Genius
    • Bishop Computer Design web
« Reply #14949 on: Mon, 21 March 2016, 08:59:55 »
do any of the keys on that row work? if not check the end of the trace to the controller. may be a broken solder joint or separated resistor. i can't seem to find a diagram of the PCB so its kinda hard to tell.
Projects
Build to give back, 40% | Alps/Matias Removal ToolUltraHack 67% Hackdura  | ErgoDox case
