Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 4139427 times)
Offline Awoke
« Reply #16900 on: Mon, 24 April 2023, 21:07:26 »
I'm looking for a full size keyboard, with aluminium or zinc (metal) frame, and Cherry MX Clear switches.
Any idea of one or where I could search for one?
Offline Miscfu
« Reply #16901 on: Mon, 01 May 2023, 11:41:25 »
Hello! Doing my first keyboard build, was just wondering if there were any potential compatibility issues I may have overlooked.
I've ordered:
  • Portico68 Obsidian build kit from KeyCompany
  • Tangerine Light switches / stabs
  • SLK Dessau Dark Base Kit
Thank you!  ^-^
Offline user 18
« Reply #16902 on: Tue, 02 May 2023, 09:05:08 »
I've ordered:
Thank you!  ^-^
I am not familiar with this board or keyset, but have looked it up. As far as I can tell, everything looks compatible. The only odd keycaps you will need for this layout are a 1.75u right shift, and different-row home/end/pgup/pgdn. The keyset you mention includes the 1.75u shift, and because it doesn't seem to have different profiles per row, you don't run into any concerns with the home/end/pgup/pgdn like you would with, for example, Cherry profile caps.
The switches are PCB mount, and your PCB looks to have the additional holes drilled to be compatible with these. In the event that you get a PCB without these holes, or there is a size mismatch, you can turn PCB mount switches into plate mount switches by cutting off the plastic legs on the side, but it doesn't appear like that will be necessary in your case.
The stabilizers are also PCB mount, and includes the correct number and size of wires. You will need the shorter of the two spacebar stabilizer wires.
Good luck with your first build :)
Avatar by ashdenej
Offline Prince Valiant
« Reply #16903 on: Mon, 08 May 2023, 10:42:41 »
Are there any clicky hall effect or optical switches which are MX compatible (mount and stem)?
Offline Simon11777
« Reply #16904 on: Mon, 08 May 2023, 20:17:54 »
Hello, I need help finding a mechanical keyboard pad on AliExpress Keyboard 60% in iso
Offline Awoke
« Reply #16905 on: Tue, 09 May 2023, 12:26:24 »
I got my first MK. It's a lot more impressive than I was expecting. Now, I want to make it as quiet as possible. Any help of suggestions on where to start or the appropriate place to find information will be greatly appreciated.
Thanks in advance.
Offline ander
  • I type, therefore I am
« Reply #16906 on: Tue, 16 May 2023, 01:25:03 »
Should you wear brown shoes with a blue suit?
We are not chasing wildly after beauty with fear at our backs. – Natalie Goldberg
Offline ShangWang
« Reply #16907 on: Wed, 24 May 2023, 12:07:58 »
I found this 4mm thick foam in my room that I could potentially use for dampening my HyperX Alloy Origins but I'm not sure what kind of material it is or if it's appropriate for the task. I just know that if the foam is not electrically conductive, it would work.
299295-0
299297-1
299299-2
https://imgur.com/a/YjFSftK
The foam is a bit hard, with some rigidity and has a somewhat smooth texture with little pores. Does anyone know what material this is? Would it be good for keyboard dampening?
« Last Edit: Wed, 24 May 2023, 12:10:07 by ShangWang »
Offline ShangWang
« Reply #16908 on: Fri, 09 June 2023, 09:55:28 »
I plan on purchasing a soldering matt for resoldering a HyperX Alloy Origins which presumably has an aluminum plate on the exterior and the switches are plate mounted.
The silicone matt has these magnetic areas for placing your screws, but my keyboard is just big enough that it takes up the whole matt space and overlaps these magnetic areas.
If my PCB or any part of the keyboard touches these magnetic parts while soldering, can it cause any damage whatsoever, or is it completely safe?
If there was any damage, would the magnets have to be extremely strong for it to do anything?
Offline invariance
  • ...here with all the other boson's
« Reply #16909 on: Thu, 29 June 2023, 08:43:28 »
Nothing to worry about. Think of a generator where the fast motion of many wires in a loop through a magnetic field creates a voltage. Moving a circuit board over a magnet will not do anything.
If you drag your feet over polyester carpet and then touch the circuit board, that might be a different story  :))
Discharge yourself by touching someone‘a earlobe first.
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline ShangWang
« Reply #16910 on: Thu, 29 June 2023, 10:49:39 »
Thanks! I don't think I'll always have a person to discharge myself, but I do have a metal ruler that is sitting on my wooden table. Hopefully that does a decent enough job!
Offline ShangWang
« Reply #16911 on: Mon, 03 July 2023, 06:09:47 »
When soldering do I need to add more solder to my iron if I applied a can of tip tinner, or does that not help? Will it make the iron worse?
« Reply #16912 on: Mon, 03 July 2023, 10:58:13 »
Tip tinner is mostly for cleaning and protecting the iron, for a keyboard you can probably just get straight to soldering without adding more to the tip itself, just start feeding to the joint after heating it up a bit.
Offline ShangWang
« Reply #16913 on: Mon, 03 July 2023, 14:05:09 »
Thanks! I was thinking tip-tinner is just an easier alternative to adding solder to your iron yourself. I was thinking I would have to re-tin every time I clean the iron with a brass sponge, but I guess it's not necessary if the tip looks unoxidized and shiny, but it wouldn't hurt to re-tin it again even if it's already shiny?
I'm thinking you could re-tin after cleaning the iron twice from oxidation.
« Reply #16914 on: Mon, 03 July 2023, 15:30:46 »
You can do it before and after the soldering session as well as periodically in between during soldering after cleaning.
Offline ShangWang
« Reply #16915 on: Mon, 03 July 2023, 16:11:31 »
Sorry, to clarify I haven't used the solder iron yet. I re-read on tip tinner and it appears to be only used when absolutely needed. I think on a new iron I should just apply solder to tin it normally.
I think the procedure is to clean the tip, apply the tinner, and then clean the tip again to get rid of the residue. In most cases the tip should be shiny at that point even after cleaning, but I wanted to know if I'm not 100% sure is it ok to add more solder on the tip even after tinning if it doesn't appear shiny enough? What if it's already shiny and you apply more?
If it's possible to add too much solder on your tip, how do you remove the excess? Do you just use the brass sponge again, and if you do would you have to re-tin it again with solder?
Offline zot3
« Reply #16916 on: Tue, 24 October 2023, 17:15:43 »
Hello,
Is it possible to make a macropad (like the DOIO ones) to output MIDI instead?
Thanks
Offline Mr. Perfect
« Reply #16917 on: Fri, 27 October 2023, 16:19:13 »
Hey all,
What's the favorite active PS/2 to USB converter these days? All the ones I'm familiar with seem to be out of production. Thanks!
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline ClaireAbitbol
« Reply #16918 on: Sat, 11 November 2023, 05:21:57 »
Why do people just leave their coiled cable retracted on their desk and have a long normal cable connecting to the PC, to me the point of a coiled cable was that you're able to extend it so why just leave it sitting there like a less space efficient regular cable? I'm assuming a big part of it is just aesthetics.
« Reply #16919 on: Sat, 11 November 2023, 07:41:48 »
just aesthetics.
I despise coiled cables and think that they are clumsy and ugly.
From the US Constitution, Article 1, Section 8 :
The   Congress   shall have Power
To declare War,  grant Letters of Marque and Reprisal, and make Rules concerning Captures on Land and Water;
To provide for calling forth the Militia  to execute the Laws of the Union, suppress Insurrections and repel Invasions;
Offline Exquite
  • GeekAnubis
« Reply #16920 on: Wed, 15 November 2023, 20:35:05 »
How can I upload my pictures to the profile pictures section? I have tried uploading jpeg, png, and heic.
I'm a Color lover and a designer.
Offline Buckling_Summer
    • http://www.elitesportservices.com
« Reply #16921 on: Tue, 21 November 2023, 05:23:45 »
Hey all,
I have been using this:
ps/2 to USB adapter converter for keyboards + short USB cable
PRESENT POSSESSIONS:
 Buckling Spings: IBM Model M 82G2383 Lexmarkian (1995) / IBM Model F PC-AT keyboard 84 keys (6450200)
XM Simplified 1 (Monterey K110 or AK-CN2 or Hua-Jie) Siig MiniTouch KB-1948 GeekHack Spacesaver edition
Offline mohawk1367
  • Typing on: HHKB Pro Hybrid Type-S
« Reply #16922 on: Mon, 27 November 2023, 07:23:37 »
the coiled cables people use these days arent meant to be extended they are just coiled for aesthetics
its weird
someone needs to make an aussie keyboard community called QMƎɹ┴⅄. get it? haha :D
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #16923 on: Wed, 29 November 2023, 05:35:18 »
Aside from mechanical keyboards .com (out stock for a while now), any suggestions where I can find some Cherry PCB mount NOT screw in (Ergo Dox doesn't support screw in to my knowledge unless I am mistaken) stabilizers?  I only need 4 2U stabs.
Also, any suggestions for a single sides keypad for gaming aside from custom built Ergo Dox.
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #16924 on: Thu, 30 November 2023, 07:55:22 »
If you are talking about clip ins, than cannonkeys sells them.
https://cannonkeys.com/products/cherry-stabilizers?variant=32257338998895
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline ShangWang
« Reply #16925 on: Sat, 02 December 2023, 15:23:44 »
I have this RK ROYAL KLUDGE RK84 keyboard where I lubed the stabilizer wires with dielectric grease and the housing with G-lube. I made sure to put a thin layer for the housing a relatively thick coating on the wires. I also put a band-aid under the stabilizers and applied a bit of dielectric grease on them.
The keyboard comes with EVA foam already but I put one layer of painters tape on the PCB for more sound dampening.
It seemed like a tight fit when screwing the PCB back on the plate, but there were no issues with the stabilizers until I repeatedly pressed down on my spacebar and eventually it started rattling. It's more of a wriggle sensation/sound when pressing down on the keys, but it seems like it's permanently like this despite
Is this normal for these stabilizers, or is it because of the tape mod somehow?
Offline Melvang
« Reply #16926 on: Thu, 21 December 2023, 06:46:43 »
Would anyone have or know where I could get CAD files for Ergo Dox PCBs so I can start designing a case for my kiddo?
Offline Rhienfo
« Reply #16927 on: Thu, 21 December 2023, 07:05:52 »
This should have the files for the ergodox pcb
https://github.com/Ergodox-io/ErgoDox
the ergodox website should also have it (or at least a way to find it) just in case the github doesn't - https://www.ergodox.io/
Hope this helps and the project turns out well, always love seeing stuff like this.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline Rhienfo
« Reply #16928 on: Thu, 21 December 2023, 07:18:43 »
If lube isn't the issue than maybe the wires are unbalanced. This seems helpful with fixing that - https://www.keebtalk.com/t/how-do-you-straighten-your-stabilizer-wires/13012
If there is still persistent rattle another thing that I have seen is that it is a spacebar issue and you need to put a little bit of thin cling wrap loosely where the ticking is happening (this is if you are talking about a ticking noise that occurs instead of rattle, only do this if you have tried everything and there is still ticking, and don't cram it in there as there is a risk that the spacebar stem may crack)
If literally nothing works than replacing the stabilizer would be an option, and also isn't too expensive.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline ShangWang
« Reply #16929 on: Thu, 21 December 2023, 07:54:42 »
Thanks! I got the same set of stabilizers and it seemed to still persist, I think it's just how the stabilizers are so I'll just replace it with a different kind in the future.
Offline transeurasian
« Reply #16930 on: Sat, 23 December 2023, 04:33:07 »
Is there a wiki or list somewhere of new & notable keyboard releases?
Offline Rhienfo
« Reply #16931 on: Sat, 23 December 2023, 05:30:32 »
https://docs.google.com/spreadsheets/d/185irtVlavKB7a21TwWsaU6iZVvfeVqY3XrIn87obPpQ/edit
I mainly look at this spreadsheet when it comes to anything notable. It also has a review of every product by a big community member that you can look at, but even if you don't care about that/agree with him, it's still useful with seeing everything.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline killazys
« Reply #16932 on: Fri, 19 January 2024, 09:18:01 »
Looking to replace my dying Archiss MX Brown keyboard for my desktop. I tried the REALFORCE R2 silent 45g switches and they were way too stiff/actuation bump felt really fatiguing, even though technically they are less weight than the browns. I have the Ducky One SF with Kailh Box Browns for travelling which I like, maybe if they were just a big lighter and lubed.
I tried the Niz 35g switches at the store and I found them to be too close to a linear switch for me, also the key travel distance felt a bit short.
So I'm looking for something in between the Kailh Box Browns and Niz 35g, preferably silent and smooth/pre-lubed but not sure what... maybe Niz 45g like this one? Thanks for any tips.
I live in Japan btw so something I can easily buy here would be preferred.
Offline Rhienfo
« Reply #16933 on: Fri, 19 January 2024, 16:09:46 »
Any of the haimu silent tactiles are a reccomendation for me in terms of mx silents, however the spring weighting may not be right for you, so I would reccomend spring swapping with aftermarket springs like tx springs, I think 55-57g medium springs would be right for you. You would just need a switch opener since they are factory lubed.
I did see 40g kalih box springs out there, which are slightly lighter than the box browns from what I'm aware, but no one is selling them so I think they stopped production, but if you ever find them you can replace them with the box browns stock springs.
Also weighting in topre is different to mx since it's not the spring that causes the resistance, the tactile domes are the things that cause resistance, if you want to go the topre route then you would have to find aftermarket domes that are lighter than 45g but heavier than 35g, I'm not a topre person so I can't really help you out there. But hope the other info helps you.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline mohawk1367
« Reply #16934 on: Fri, 26 January 2024, 10:03:51 »
ngl when i tried 45g topre for the first time it still felt unspeakably light compared to 45g mx style linears
Offline Nerif
« Reply #16935 on: Sat, 03 February 2024, 13:55:54 »
Can someone explain to me why Clickjacket-based switches lose their click after years of usage?
̷C̷M̷ ̷Q̷F̷ ̷X̷T̷ ̷[̷C̷h̷e̷r̷r̷y̷ ̷M̷X̷ ̷B̷l̷u̷e̷ ̷→̷ ̷C̷h̷e̷r̷r̷y̷ ̷M̷X̷ ̷B̷l̷a̷c̷k̷ ̷H̷y̷p̷e̷r̷g̷l̷i̷d̷e̷]̷
Anne Pro 2 [Gateron CAP Brown → Kailh BOX Dark Yellow]
Offline Rhienfo
« Reply #16936 on: Sat, 03 February 2024, 17:34:30 »
There might be a few reasons
1. The switches are really dirty, which would block the click mechanism and the switches need to be cleaned.
2. If the switches have been lubed, any of it near the click jacket will remove the click as well, this can happen even if you didn't lube near it initially because the lube with spread around in the switch. You can clean it but it requires a ultrasound cleaner.
3. The switch has wear and tear from years of usage and either the jacket part of the leaf has been damaged (probably not the reason)
Hope this helps.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline fuzzybyte
« Reply #16937 on: Sat, 24 February 2024, 01:10:24 »
Where could I buy a single-piece keyboard with a layout like this?
306306-0
« Last Edit: Sat, 24 February 2024, 21:49:18 by fuzzybyte »
Offline Rhienfo
« Reply #16938 on: Sun, 25 February 2024, 23:29:27 »
I don't think there is a keyboard with this layout, I think your best bet would be to handwire the board in that layout, and use acryllic stacks for the case for example.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline _rubik
« Reply #16939 on: Tue, 12 March 2024, 16:18:57 »
That's a very specific layout. You're going to have to either make it yourself, or buy a larger ortholinear board and retrofit your keymap. Maybe the XD75?
« Reply #16940 on: Wed, 13 March 2024, 12:52:42 »
As others have said, your best bet is going to be making it yourself. If you haven't explored the Making Stuff Together subforum and dug up this resource, I recommend it as a good way to achieve what you're after.
swill's plate building tool
Offline gokufire
« Reply #16941 on: Wed, 27 March 2024, 14:44:20 »
Anyone else here with hope to see a Halo96 V2 as soon as possible?
Things that I'd like to see on it:
1. VIA/QMK supported
2. Barebones option
3. Southpaw version? Not sure if would be nice with their cramped layout
4. Priced under $160
This would be the closest to find the keyboard that I'm waiting or I may go with a Keychron V5 Max barebones and accept the fact that there is no keyboard with the features that I want yet.
Anyways, just checking if there is some hype for this one to happen.
« Last Edit: Fri, 29 March 2024, 10:55:54 by gokufire »
Offline _rubik
« Reply #16942 on: Wed, 27 March 2024, 14:48:58 »
What is it about the Halo96 that you can't find elsewhere? QMK is pretty easy to find these days. Southpaw isn't as common at that price point (that I know of). Pretty much every keyboard is barebones at one point or another :)
That layout is unique-ish but not so unique that I haven't seen competitive options. Basically what I'm getting at is: there are always alternatives. What are your "must haves"?
Offline gokufire
« Reply #16943 on: Wed, 27 March 2024, 15:36:52 »
I guess, those are the things that I'm looking:
1. 100% or 90ish% layout
2. Support of VIA/QMK
3. Gasket Mounted
4. Hotswap
5. Wireless
6. No low profile
The ones that attended those criteria are:
1. Zoom98
2. Keychron V5/V6/Q5/Q6/Q12 (Max series)
3. Wind X98 R2
4. Odin R4
I couldn't find more. Not sure if I'm looking it right.
If NuPhy releases the Halo96 next version with VIA/QMK support then it would also be part of this list and if priced below the Keychron Q5 and Q6 for me it will be a winner.
Do you know about some other options?
« Last Edit: Thu, 28 March 2024, 14:41:52 by gokufire »
Offline pessi80
« Reply #16944 on: Sat, 27 April 2024, 13:52:48 »
My dads old membrane (not buckling spring) keyboard is actually bouncy and almost feels tactile :eek:
Crazy right? I mean I could probably use it if the spacebar worked that's how good it was imagine a mac keyboard with holy pandas???
What is this keyboard?
Offline mohawk1367
« Reply #16945 on: Mon, 29 April 2024, 06:58:34 »
arent most membrane keyboards tactile tho? lol
Offline _rubik
« Reply #16946 on: Mon, 29 April 2024, 17:52:56 »
That's pretty normal. Most feel pretty spongy and mushy though, especially after extended use. Topre keyboards are plenty tactile and they have similar electrocapacitive "switches". I remember Microsoft's Natural Elite feeling pretty good, for example.
Offline Rhienfo
« Reply #16947 on: Mon, 29 April 2024, 19:50:49 »
Yeah the mechanism of a collapsing dome creates the tactile feedback, I think you could make a linear rubber dome, but what's the point the point of rubber domes is that they are cheap.
Might as well make a mechanical keyboard at this point.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline enchong
« Reply #16948 on: Tue, 30 April 2024, 11:35:23 »
Planning to buy a rubber dome from deskeys for my HHKB. What would be the closest to the Realforce 55g? Should I get the 49g?
 Enchong | HHKB Pro2 Blank, DES Silencing Ring #3, DES Domes Carrot 49g | HHKB Pro2 Stamped, DES Silencing Ring #2 | HHKB Hybrid Type-S Snow Blank
Offline _rubik
« Reply #16949 on: Tue, 30 April 2024, 15:16:40 »
Which type dome are you getting? There are BKE redux, round, carrots etc etc
