Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6200942 times)
« Reply #4850 on: Tue, 05 November 2013, 11:36:48 »
Someone tell me! Why I No CC!! Any way to hack EK to get a CC?! T T
http://geekhack.org/index.php?topic=45955.0
because you not one with the CC
Dat keycap in your avatar lol. That keycap in China is CC on GH.
You mean like these?
http://geekhack.org/index.php?topic=49542.msg1102743#msg1102743
« Reply #4851 on: Tue, 05 November 2013, 11:37:14 »
Ok enough about the EK sale please.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #4852 on: Tue, 05 November 2013, 11:38:05 »
Why you gotta do that to the poor guy?  Thats like rolling up to a homeless guy in your limo, rolling down the window and asking him if he has change for $100.
« Reply #4853 on: Tue, 05 November 2013, 11:44:41 »
He mentioned your avatar being like CC's in china and I was asking if those keycaps like feng is making is what he meant.
On topic: Does anyone know of any other key caps that have found such fame around the world?
Offline yicaoyimu
« Reply #4854 on: Tue, 05 November 2013, 11:48:04 »
I see.. By CC in China, I mean the price, the fame and the popularity.
Offline MKULTRA
  • telling it how it is
« Reply #4855 on: Tue, 05 November 2013, 11:50:08 »
$250 Red Cherry Esc
Offline Melvang
« Reply #4856 on: Tue, 05 November 2013, 11:51:17 »
$250 Red Cherry Esc
But only the orignals which were only made in 2 very limited edition runs.
« Reply #4857 on: Tue, 05 November 2013, 11:53:21 »
This thread is deteriorating quickly.
THREAD QUALITY [▓▓▓░░░░░░░░░░░░░░░░░] 15%
« Reply #4858 on: Tue, 05 November 2013, 11:54:52 »
$250 Red Cherry Esc
Have links for the two GBs you mentioned? I never heard that before.
Other than that, please stop the Clack/rare cap discussion stuff here. Not the thread for this.
Offline Melvang
« Reply #4859 on: Tue, 05 November 2013, 12:04:38 »
$250 Red Cherry Esc
The orignals were not group buys but done by Cherry before they sold their tooling.   This was where I was getting that info.  And as we know Ivan is the master when it comes to this totally obscure info.
Offline MKULTRA
« Reply #4860 on: Tue, 05 November 2013, 13:23:28 »
The Cherry Red Esc's came off the wNv Raptor keyboards.
http://geekhack.org/index.php?topic=8491.0
« Reply #4861 on: Tue, 05 November 2013, 14:27:01 »
Was you able to get that measurement for me cpt?
Anyone know the distance from the plate to the bottom of the cap using DCS caps?
If you don't get an answer, I'll take this measurement for you later.
Distance from plate to bottom of the cap is .360" for Cherry/GMK caps.
Distance from plate to bottom of the cap is .380" for DCS caps.
Measurement taken on my Epsilon from top of the plate to bottom of the cap on the lip that faces closest to the typist.
Offline Melvang
« Reply #4862 on: Tue, 05 November 2013, 15:22:44 »
Yup I guess that was one of two sources.  With the other run being about the same size of production numbers.
Thanks CPTBadass
Offline attackcow
« Reply #4863 on: Wed, 06 November 2013, 08:35:10 »
Hey!
I've got a KBT Pure that uses a mini USB cable to connect it to the computer. I was wondering if I would be able to use a retractable mini USB cable to connect it to the computer. The only reason why I'm asking is because all the eBay listings say that they're all for charging and I don't know if that means it won't work with the keyboard.
An example of what I'm looking at are these: http://www.ebay.com.au/itm/Retractable-USB-2-0-A-to-Mini-USB-B-Only-Charge-Cable-for-Camera-MP3-4-PDAs-/190813377043?pt=AU_Television_Accessories&hash=item2c6d5d1213
The cable I'm using now is quite thick and can get quite cumbersome at times (I move my keyboard around for extra space for writing).
« Reply #4864 on: Wed, 06 November 2013, 08:37:45 »
Hey!
Should work fine.
Offline attackcow
« Reply #4865 on: Wed, 06 November 2013, 08:39:25 »
Hey!
Should work fine.
Wonderful. Thanks! :)
Offline BlueBär
« Reply #4866 on: Wed, 06 November 2013, 08:41:06 »
That cable says "only charge" so it shouldn't work imo? Sounds like it just has VBUS and GND connected.
Edit: looking at the picture, that cable also seems too small for 4/5 inner cables.
« Last Edit: Wed, 06 November 2013, 08:42:49 by BlueBär »
« Reply #4867 on: Wed, 06 November 2013, 08:44:59 »
I could totally be wrong. Never seen just a charging cable like that. But I think you're right BlueBär
Offline attackcow
« Reply #4868 on: Wed, 06 November 2013, 08:45:21 »
Oh... would there be anything like the retractable cable that would work with the KBT Pure? Could you explain the VBUS and GND thing too? Curious as to what those are haha.
« Reply #4869 on: Wed, 06 November 2013, 08:46:37 »
I see those cables all the time at Walmart, etc. They are made by Targus, Belkin, others. Should be easy to find.
« Reply #4870 on: Wed, 06 November 2013, 08:49:07 »
Would there be anything like the retractable cable that would work with the KBT Pure?
Now that I think about it and look at nubbinator's custom cable creation guide, I think the cable thickness has to be there so there's all the proper connections. I'm not sure about the retractable cable thing. You could custom order a shorter length cable if that helps.
See jdcarpe's post above me. Sniper...
Offline BlueBär
« Reply #4871 on: Wed, 06 November 2013, 11:40:39 »
Basically the + and - pins of USB that deliver 5V to whatever is attached. The other pins are for data transfer.
« Reply #4872 on: Wed, 06 November 2013, 13:47:34 »
They make retractable USB cables that carry power and data (though many are power only for charging). My friend is a big fan of them. Keep in mind the superthin cables are more prone to breakage though.
Offline stancato9
« Reply #4873 on: Thu, 07 November 2013, 00:51:51 »
Where can I get the go-to LEDs for keyboard modding?
Poker 2 - MX Red
Offline genkidama
« Reply #4874 on: Thu, 07 November 2013, 04:21:03 »
Yesterday I recieved my new Shine 3 with brown switches :) I am really happy about this mech, but I experience some strange sound noise while typing.
So this question mostly goes out to ducky owners, as I think this maybe a ducky related thing.
Yesterday I've experience a metal-ish sound or reverberation after I bottom out on the keys. I tested this on a lot of the keys and the sound is present. I can hear the sound even when I just "tickle" the keys although it's considerably quieter, but still it's there.
What I've tried so far: (I'm using the stock keycaps which are delivered with the keyboard)
- Putting a mat underneath the mech but the sound is still present although it's a little dampened.
- I pulled one of the keycaps and wanted to look at the switch. When I press down the switch I the sound is much quieter but still there (tested this just now) and with the keycaps on it seems the sound gets louder.
I heard of modding the mech with some kind of foam putting it in between PCB and case from BlueBär. I guess this is my next step and try this.
Here is a sound example: (I'm not really pressing that hard bottoming out)
http://www46.zippyshare.com/v/12537360/file.html
Hopefully someone knows this and can calm me down that this can be easily fixed.
P.S.: For the first few hours of typing and enjoying my new mech I didn't experience anything like that metal-ish sound while typing. I recieved her in the morning and the metal-ish sound came in the evening and I didn't eat near her or spilled anything and if I did I used the plastic cover to protect it from the food and drops of water.
Somehow this makes me crazy  :eek:
« Last Edit: Thu, 07 November 2013, 04:22:53 by genkidama »
My finger training is over 9000!!!!
Offline BlueBär
« Reply #4875 on: Thu, 07 November 2013, 05:33:08 »
Ebay, look for 2x3x4mm rectangular LEDs, they work very well.
« Reply #4876 on: Thu, 07 November 2013, 06:29:23 »
In the OP.
Offline Permeability
« Reply #4877 on: Thu, 07 November 2013, 09:49:19 »
Does anyone know if the LED color changers(http://geekhack.org/index.php?topic=49704.0)  work with the 2x3x4 LEDs?
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
Offline stancato9
« Reply #4878 on: Thu, 07 November 2013, 09:52:03 »
Poker 2 - MX Red
Offline BlueBär
« Reply #4879 on: Thu, 07 November 2013, 10:15:16 »
They should work since they are not as high as normal 3mm LEDs and generally smaller.
Offline kgrad5
« Reply #4880 on: Thu, 07 November 2013, 10:25:48 »
Where would I find that sheet with the keycaps on it that people place their actual keycaps on when they take pictures of them? I assume it is on this site somewhere but I haven't found it yet and I don't really know how to search for it.
Thanks kindly!
« Reply #4881 on: Thu, 07 November 2013, 10:28:01 »
Thanks kindly!
Check the OP I believe captn put a link there if not shoot me a pm.
Offline kgrad5
« Reply #4882 on: Thu, 07 November 2013, 10:37:33 »
Thanks kindly!
It is there, number 33! Thanks! I only saw the keyboard generator ones when I went through that list before.
« Reply #4883 on: Thu, 07 November 2013, 10:40:04 »
I'm going to cal him Cap'n from now on. Like the Crunch. You can thank Ray for that one, Cap'n.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #4884 on: Thu, 07 November 2013, 11:36:27 »
Are there any 75% boards with 1.5x mods that aren't a custom?
« Reply #4885 on: Thu, 07 November 2013, 11:39:03 »
I've got so many nicknames now. I've even responded to ******* on occasion :P. My favorite is still CPTDatAss though :D.
Don't think so. Noppoo Choc Mini and one of the Keycools are the only stock 75% boards I can think of and they have 1.25x mods I believe.
Thanks kindly!
The OP is constantly being updated, I just don't announce it. :D
« Reply #4886 on: Thu, 07 November 2013, 11:40:31 »
I believe the Noppoo Choc Mini 84 has 1.5x mods, not 1.25x.
Offline MKULTRA
« Reply #4887 on: Thu, 07 November 2013, 11:41:17 »
However there is a group buy starting right now for a 75% PCB and case, if you don't want to assemble then I'm sure you could find somebody to do it for you.  It comes out to about $155 for PCB + plate + case which is relatively cheap compared to other customs.
« Reply #4888 on: Thu, 07 November 2013, 11:44:02 »
Image borrowed from Neogaf
Yes you're right nubbinator. I stand corrected.
Offline digi
  • elite af tbh
« Reply #4889 on: Thu, 07 November 2013, 11:50:16 »
That right Alt tho :(
« Reply #4890 on: Thu, 07 November 2013, 12:04:57 »
What is this wizardry?
« Reply #4891 on: Thu, 07 November 2013, 12:09:38 »
Did they change the layouts between the 2012 and 2013 Editions of the Choc Mini? NOPPOO Y U DO DIS 2 ME, Making us all confused and shiz.
« Reply #4892 on: Thu, 07 November 2013, 12:11:58 »
« Reply #4893 on: Thu, 07 November 2013, 12:12:07 »
perhaps their designers have been browsing geekhack, isn't that very close to the epsilon layout?
« Reply #4894 on: Thu, 07 November 2013, 12:17:01 »
Yes, this is the case. 2013 Noppoo Choc Mini 84 has changed to 1.25x mods as pointed out by Surnia's review. Compare this to the 2012 Noppoo Choc Mini 84 Codehead has in his review which has the 1.5x mods.
Offline MKULTRA
« Reply #4895 on: Thu, 07 November 2013, 14:57:15 »
Or MX-Mini for that case.
Offline Lastpilot
  • Power stance
« Reply #4896 on: Thu, 07 November 2013, 15:15:42 »
Super noob question here. Can you freely install switches backwards so that the LED is top facing? Or does the PCB also have to be "backwards"?
« Reply #4897 on: Thu, 07 November 2013, 15:18:42 »
PCB needs to have the holes/traces setup to accept the LEDs. Can't just flip em at will. PCB will determine LED location.
Offline Lastpilot
  • Power stance
« Reply #4898 on: Thu, 07 November 2013, 15:20:30 »
Thank you.
Offline Melvang
« Reply #4899 on: Thu, 07 November 2013, 16:13:01 »
You could but it would take a TON of work.  If you want to do this my suggestion would be to cut a large hole in the PCB where all the switches go and hand wire the switches back to what is left of the PCB.  Of course this would only be feasible on a plate mount board.
