Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6200959 times)
Offline BlueBär
« Reply #4700 on: Mon, 28 October 2013, 13:15:15 »
Stop listening for the ping and you won't hear it.
I use thick PBTs for my Alphas on 65g vintage blacks, they sound lovely. The spacebar sound really sticks out.
Yeah I think it's what moose was saying with the heavy spring's return. You have a light spacebar (Thin ABS) and a heavy spring. Maybe swap in a PBT spacebar? Or swap the spring out for something lighter?
I only have the one that's currently on the board and another thin ABS one. The switch also pings with the spacebar removed, so yes, it's the spring that's too heavy for the keycap :(
I changed it to 67g and that fixed it. Thanks!
« Reply #4701 on: Mon, 28 October 2013, 13:16:40 »
I love happy endings :D
Offline esoomenona
  • Gnillort?
« Reply #4702 on: Mon, 28 October 2013, 13:21:07 »
Me too, buddy. Me too...
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #4703 on: Mon, 28 October 2013, 17:09:48 »
I'm pretty sure the Cherry G80-1813HFX is 2KRO, is it possible to modify it to 4KRO or 6? HOW TO DO THIS?!  ;D
Offline MKULTRA
  • telling it how it is
« Reply #4704 on: Mon, 28 October 2013, 17:52:05 »
Not possible to my knowledge.  They have in-switch diodes which limit you to 2KRO
Offline digi
  • elite af tbh
« Reply #4705 on: Mon, 28 October 2013, 17:59:56 »
 :( oh well, thanks anyways.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #4706 on: Mon, 28 October 2013, 19:26:52 »
Probably a stupid question, but whatever...  I see a bunch of 'replacement keycaps' GBs happening.  What is stopping you from just buying a whole set?
Links?
The only two I see in the first few pages are R3 and R4 replacements, which I understand to be replacement for faulty or missing sets from the original R3 and R4 GBs.
I thought this one had 'Replacements' in its title originally: http://geekhack.org/index.php?topic=50159.0
This one also has 'replacements' in the title: http://geekhack.org/index.php?topic=20485.0
I thought I had seen another example of this from a while ago when doing some searching as well.  I was just wondering if there was a concept of being able to get only a few replacements keys, but not an entire set.  I am not thinking of a specific GB right now, but I saw it in a couple places, so I figured I would ask.
« Reply #4707 on: Mon, 28 October 2013, 19:29:03 »
Links?
7bit and the GB runners at DeskThority are just calling the buy "replacements", it's actually a full set GB.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #4708 on: Mon, 28 October 2013, 19:58:29 »
Links?
Thank you.  :)
« Reply #4709 on: Mon, 28 October 2013, 20:06:22 »
The reason they are called "replacements" is because they are designed to completely replace the keycaps on your Filco, QFR, etc. without the need for any special caps. For instance, you can use keycaps from old Cherry boards to replace your modern keycaps, but you will need to find a certain number of additional keycaps (aka moogle kit) to be able to use them with your modern keyboard.
Since they were called "replacements" in the original mass order, the naming convention stuck for subsequent rounds of full set keycap group buys.
« Reply #4710 on: Tue, 29 October 2013, 10:27:38 »
What profile are topre caps?
« Reply #4711 on: Tue, 29 October 2013, 10:30:33 »
I'm not quite sure but I think they're Topre OEM. The profile felt very close to Cherry Profile when I tried mkawa's RealForce.
Offline Pacifist
  • on hiatus
« Reply #4712 on: Tue, 29 October 2013, 22:49:04 »
How are korean and cherry stock spring weight calculated? I heard that koreans do it by how much force it takes to bottom out, but cherry is by how much it takes to actuate the switch.
So that leads to the second question, what conversion would 62g korean to cherry turn out to be?
NVM ITS IN THE OP
Offline goobus
  • HHKB Elite
« Reply #4713 on: Wed, 30 October 2013, 00:54:06 »
Which screws on the KMAC 2 are used for the WKL aluminum blocks? I think it's the ones with the rounded top in the pic, but just double confirming.
Question 2: those round screws are also used to screw the plate onto the case bottom right? I only count 10 screw holes for the plate->case is this right?
Reason I'm asking is because I'm sending moose my alu blocks (I prefer WK layout) and want to know how many screws I can safely send him :P
Offline ouimeansyes
« Reply #4714 on: Wed, 30 October 2013, 14:32:02 »
No easy way to get a hold of a Realforce 23u (white) now that ek are out of stock? Is my only option a proxy?
Thanks.
« Reply #4715 on: Wed, 30 October 2013, 15:47:02 »
Thanks.
I'm not really sure where the best place to get one is. I know Bro Caps spent a while looking for one.
« Reply #4716 on: Wed, 30 October 2013, 15:48:32 »
Thanks.
Didn't get get a black one?
« Reply #4717 on: Wed, 30 October 2013, 16:05:49 »
As you all know, there is a new Clack sale on EliteKeyboards. I thought it might be helpful to create a mini FAQ. I've also worked on this Clack Info Thread if anyone wants a little more detail.
  • What is a Clack and why are they expensive outside of this sale?
Novelty caps created by ClickClack and the ClackFactory. Currently they are wildly popular and collectors will pay a lot of money for them. I hold the personal belief that Clacks are worth the price 4Grabs and EK sell the for
  • How do I buy them?
You enter the raffle. If your name is drawn you'll get an email and an invoice to pay for the Clack. The drawing date is listed on the website. In the past, there has been other EK raffles like this current one. And ClickClack will sell them in his 4Grabs thread.
  • When will they invoice me if I've won? How long after the sale will it take for EK to send me my Clack.
Typically the total turnaround time is two weeks. A week to get the invoice, a week for shipping. Times obviously vary but this is a good time frame.
« Last Edit: Thu, 31 October 2013, 09:04:00 by CPTBadAss »
Offline Pacifist
  • on hiatus
« Reply #4718 on: Wed, 30 October 2013, 19:29:12 »
How good is this: http://www.amazon.com/Elenco-AmeriKit-Learn-Solder-Kit/dp/B0009Z3JJA/ref=sr_1_3?ie=UTF8&qid=1383178992&sr=8-3&keywords=soldering+kit
soldering kit? Its designed for beginners(which I am) and includes a practice PCB to solder on.
So is this worth it to practice soldering and then use the iron again for another project, namely soldering 31 switches for a qazpad from metalliqz?
« Reply #4719 on: Wed, 30 October 2013, 19:32:19 »
Just looking at it, it looks like a really cheap soldering iron and nothing all that great.  It also doesn't state the wattage of the iron.  It may work, but if you can afford it, I'd get something a little nicer.  As for practice, I'd see if you can find something cheap with a PCB at a thrift store or an e-waste recycler.
Offline Pacifist
  • on hiatus
« Reply #4720 on: Wed, 30 October 2013, 19:40:44 »
What kind of solder would you recommend?
« Reply #4721 on: Wed, 30 October 2013, 19:44:20 »
Have a look through this thread
http://geekhack.org/index.php?topic=42824.0
Offline vivalarevolución
« Reply #4722 on: Thu, 31 October 2013, 10:29:21 »
Is there a God?
« Reply #4723 on: Thu, 31 October 2013, 10:30:23 »
Is there a God?
You can't prove there's not, so...
« Reply #4724 on: Thu, 31 October 2013, 10:31:36 »
Is there a God?
Thank you.  That was a simple answer for my simple question.
« Reply #4725 on: Thu, 31 October 2013, 10:33:22 »
Is there a God?
JD is good with the answers!!! ;)
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #4726 on: Thu, 31 October 2013, 11:38:34 »
Is Ray the Batman?
« Reply #4728 on: Thu, 31 October 2013, 11:44:36 »
Is Ray the Batman?
They say to dress for the job you want,not the job you have!!
« Reply #4729 on: Thu, 31 October 2013, 12:00:33 »
Is Ray the Batman?
i.e. princess, apparently.
Offline lcs
  • はやく
« Reply #4730 on: Thu, 31 October 2013, 12:04:56 »
Is Ray the Batman?
Princess Batman, please.
« Reply #4731 on: Thu, 31 October 2013, 12:12:23 »
Is Ray the Batman?
Honestly if I could be a batman princess.....I would be the coolest dad ever, I could finally get my 2 and 5 yr old daughters into batman!!
Offline lcs
  • はやく
« Reply #4732 on: Thu, 31 October 2013, 12:15:19 »
Is Ray the Batman?
Teen Titans!
« Reply #4733 on: Thu, 31 October 2013, 17:44:43 »
Is there a God?
More to the point - what keyboard does he use?
Offline Pacifist
  • on hiatus
« Reply #4734 on: Thu, 31 October 2013, 17:54:35 »
Will the price of switches go lower in the future?
« Reply #4735 on: Thu, 31 October 2013, 17:56:30 »
I wouldn't count on it.
« Reply #4736 on: Thu, 31 October 2013, 18:06:44 »
Doubtful. The switch prices seem pretty good right now. You can get the big four (Red, Black, Blue, Brown) from Sherry for like $.50/switch. MK.com is selling Clears for like $.45/switch. Hell you can get Blacks from WhiskyTango right now for $.25/switch. I don't know how much lower there is to go.
Offline Pacifist
  • on hiatus
« Reply #4737 on: Thu, 31 October 2013, 18:40:58 »
Thanks. I plan to make a 31 key pad in the near future, and a 76 key ergodox in the late future. Didn't know if I should buy the 50 pack at .60 a switch or 110 for .5 a switch.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #4738 on: Thu, 31 October 2013, 19:14:48 »
I would just get the 110 pack if the cost doesn't hurt to bad and just sell what you don't need here.
Offline bMind
« Reply #4739 on: Fri, 01 November 2013, 11:07:01 »
MX Brown is considered a safe choice for first keyboard, for both typing and gaming. But..what would you recommend for a second keyboard? Would it be better to pick a different switch now or wait, type on Browns and then decide?
in flames we trust..
Offline lcs
  • はやく
« Reply #4740 on: Fri, 01 November 2013, 11:08:20 »
Switch type preference is preference. You should try, if you can, to see which one you like the best.
Offline BlueBär
« Reply #4741 on: Fri, 01 November 2013, 11:16:29 »
So you have an MX Brown board on the way already? If you do, you can probably judge better after trying browns what switch you want to try next. Also, as already recommended, get a switch test kit to see what you like.
Offline bMind
« Reply #4742 on: Fri, 01 November 2013, 14:07:10 »
Haven't ordered my Browns yet but I will, so definitely this will be this type of switch. I will try to get my hands on a tester, but it's kinda expensive to ship it to Poland.
Anyway thanks for the answers :)
« Reply #4743 on: Fri, 01 November 2013, 14:12:44 »
BlueBar is planning on starting a GeekHack European Switch Tester tour. If that finishes up soon, you might be able to join that tour?
Offline BlueBär
« Reply #4744 on: Fri, 01 November 2013, 14:20:20 »
That is another idea, however it might still take a while until my tour starts.
Offline bMind
« Reply #4745 on: Fri, 01 November 2013, 17:54:23 »
For first switch I'm decided for Browns, so no hurry. It won't be right away that I will be looking for another keyboard so I think I'll be able to join the tour when it will be organized :)
Offline Dubsgalore
« Reply #4748 on: Fri, 01 November 2013, 20:13:30 »
Anyone have experience with retrobrite? how easy is it to make? expensive to make?
going to need it for an incoming board
Offline Dreamre
    • kbdlife
« Reply #4749 on: Fri, 01 November 2013, 20:15:47 »
I need help choosing LEDs:
Which one guys? Flat top or rectangular?
http://www.ebay.com/itm/10pcs-2x3x4mm-WHITE-Water-Clear-LED-Lamps-With-12v-Free-Resistors-234W-amy-/321089670304?pt=LH_DefaultDomain_0&hash=item4ac26f8ca0
VS
http://www.ebay.ca/itm/100pcs-3mm-White-Flat-Top-Waterclean-White-LED-Light-Lamp-Leds-955-/261315351890?pt=LH_DefaultDomain_0&hash=item3cd79bd552&_uhb=1
I'm a fan of the 2x3x4mm LEDs.
Is there any particular reason? I ordered flangeless ones off eBay and it's been 4 weeks...so I'm trying to buy from someone else. I need these for my DS2! I even got my Clear switches before these came and I ordered them last week :(...My ergo clear DS2 is waiting for me!
